12-27-2019, 14:09 | #1 (permalink) |
Major Poster Join Date: Aug 2013
Member: 1997780 Status: Offline Thanks Meter: 6 | how to remove oppo screen lock with umt emmc tool drivers detected like this but not detected by tool https://www.directupload.net/file/d/...s5xkwj_jpg.htm |
12-27-2019, 14:19 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | i think it's detect only your interface .. like you have plugged only card reader without card what type of interface are you using ? it's memory card reader ? if its a card reader then first check your isp connection also try to put charger on phone without using vcc/ vccq on board |
12-27-2019, 18:57 | #4 (permalink) | |
Member: 1997780 Status: Offline Thanks Meter: 6 | Quote:
thanks for the reply 1.yes,it takes only c/r interface 2. memory card reader 3. yes 4. checked the connection many times & did all as you described what is the solution,where can I get UMT isp hardware?. the reseller says he had currently no stock | |
12-28-2019, 05:57 | #7 (permalink) | |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | Quote:
can you provide your card reader tool screenshot ..made by you | |
12-28-2019, 07:16 | #8 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You need to connect pinouts and then isp box to PC. If your connections are OK, it must list it when you click Scan. Now select device from list and click Connect. Br, UMT |
12-28-2019, 07:32 | #9 (permalink) | |
Member: 1997780 Status: Offline Thanks Meter: 6 | I did all things as you described Quote:
I have connect it with many card readers but not successd thats way I asked for the isp hardware where can i find the emmc isp h/w tool? | |
12-28-2019, 10:23 | #10 (permalink) | |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | Quote:
or find an usb stick that have emmc instead of SSD remove emmc and make some R&D lets google it ... wait i will do it for you https://lmgtfy.com/?q=emmc+isp+adapter+ | |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
