03-27-2019, 22:50 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Egypt
Member: 1327995 Status: Offline Thanks Meter: 13 | XT1676 boot repair failed Operation : Boot Repair Checking for existing devices...Found Port : ?Qualcomm HS-USB QDLoader 9008 (COM50)? Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 00006803 OPK_DATA : F325A4673F8E0E899A6C1E6D335CCEA756E7D4D89AB25D146E A0CA2A53FCD2AF Initializing Protocol...OK Sending Loader...Write Error! Please use correct loader and check USB port / cable. Operation Failed. QcFire Ver. 3.9 |
03-29-2019, 20:58 | #8 (permalink) | |
Member: 1327995 Status: Offline Thanks Meter: 13 | Quote:
Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : ?Qualcomm HS-USB QDLoader 9008 (COM50)? Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 00006803 OPK_DATA : F325A4673F8E0E899A6C1E6D335CCEA756E7D4D89AB25D146E A0CA2A53FCD2AF Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [8937]...Write Error! Please use correct loader and check USB port / cable. QcFire Ver. 3.9 | |
03-10-2020, 11:57 | #10 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hey guys.. this device is supported by umt..? i found the suitable loader but not booting completely.. Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM67) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 00006803 OPK_DATA : F325A4673F8E0E899A6C1E6D335CCEA756E7D4D89AB25D146EA0CA2A53FCD2AF Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8937_ddr.mbn]...Done Executing Loader...OK Device did not reconnect in timely manner. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.3 |
