10-25-2021, 16:40 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: W-no
Member: 310418 Status: Offline Thanks Meter: 13 | Huawei Honor Qualcomm HS-USB QDLoader 9008 Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 69001500 OPK_DATA : F12E055978792825880C5C3730B1E9E35187524B1A1FC782B5 3ECAF30816C871 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [8976_011]...Error Please use correct loader and check USB port / cable. Operation Finished. |
10-26-2021, 09:46 | #2 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
it's not smart move to edit the log u provided and deleted the UMT version u used..and by the way which honor device you are having problem with??? b.r. | |
10-27-2021, 18:02 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | The "version" from PS means version of QcFire you used. Btw, it is clear in log that loader was not found and software tried to use compatible loader. We will try to add loader if only you can tell us exact Model Name and Number. Br, |
10-27-2021, 21:23 | #7 (permalink) |
Member: 310418 Status: Offline Thanks Meter: 13 | And the main board pcb looks like this...20211027_222250.jpg Wys?ane z mojego SM-N960F przy u?yciu Tapatalka |
10-27-2021, 22:57 | #9 (permalink) |
Member: 310418 Status: Offline Thanks Meter: 13 | some UPDATE, i donwloaded the firmware where the loader where, i dont know if the firmware is good for this phone (Ares-AL10-BD 1.0.0.59_Board Software_general_8.1.0_r1_EMUI8.2_05022MAH) but the result is: Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 69001500 OPK_DATA : F12E055978792825880C5C3730B1E9E35187524B1A1FC782B5 3ECAF30816C871 Initializing Protocol...OK Sending Loader [prog_emmc_firehose.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, EMMC, ERASED GPT WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [xbl.elf] -> [xbl] ...Failed Operation Finished. QcFire Ver. 7.3 |
10-28-2021, 02:06 | #10 (permalink) |
Member: 310418 Status: Offline Thanks Meter: 13 | other firmware : Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 69001500 OPK_DATA : F12E055978792825880C5C3730B1E9E35187524B1A1FC782B5 3ECAF30816C871 Initializing Protocol...OK Sending Loader [prog_emmc_firehose.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, EMMC, ERASED GPT WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [xbl.elf] -> [xbl] ...Done Writing [tz.mbn] -> [tz] ...Failed Operation Finished. QcFire Ver. 7.3 |
10-28-2021, 02:15 | #11 (permalink) |
Member: 310418 Status: Offline Thanks Meter: 13 | Operation : Disable Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 69001500 OPK_DATA : F12E055978792825880C5C3730B1E9E35187524B1A1FC782B5 3ECAF30816C871 Initializing Protocol...OK Sending Loader [prog_emmc_firehose.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, EMMC, ERASED GPT Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK SYSTEM partition is missing! USERDATA : Encrypted Disabling Android Locks...Data Partition Missing! Operation Failed. QcFire Ver. 7.3 |
