j700f after frp now set only bl j700f after frp now set only black screen how to fix j700f 6.0.1 version Device: SM-J700F Operation: Reset FRP Searching for Device... Found Model: SM-J700F Baseband: Bootloader: J700FXXU2APE1 PDA: J700FXXU2BPH4 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:06 [Ultimate Samsung Flasher v0.7] |
try to flash but error Device: SM-J700F Operation: Flash Firmware Port: COM4 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7580 [HiSpeed] Sending Partition [BOOTLOADER]... Done Sending Partition [CM]... Rejected! Operation Finished. Elapsed Time: 00:06 [Ultimate Samsung Flasher v0.7] |
Is it latest firmware u tried to flash? Br Rachittelecom |
j700f work bypass 100% |
Flash with latest version of 5.1.1. J700FXXU2APD8_J700FODD2APD4_INS Download and flash with it first, then try FRP reset with UMTethod. Br, Ultimate Multi Tool |
Are you crazy? What everything you did? It is very simple. After patch FRP, you need to wait for Android Device to Install and then click on FRP Reset. After that you must click Next until you reach Home Screen, and then from Menu, goto settings and do Factory Data Reset. Don't tell me it does not work, all other users using same technique and they can do, but you can not? It simply means that you are doing mistake on your side, it is not on our side. And any more post with "again same, still lock" without screenshot will be deleted. Br, Ultimate Multi Tool |
in your case, your version is 5.1.1 so you can easly remove with our great umt. but here version is 6.0.1. so downgrade to 5.1.1 is a perfect solution |
