11-16-2020, 17:35 | #3 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2653152 Status: Offline Thanks Meter: 28 | CPU not found in database for Lenovo K10 L38111 in UMT Qcfire tool. First tried with auto loader but it shows error below. Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM56) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00D00 [E1B00D00] 00000000 OPK_DATA : 53FFA4BC1D7442D02C4F078671F21CF12BED89EA39F394BEC2 71187902D4B04E Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Finished. QcFire Ver. 6.3 Then tried with manual loader for Qualcom SDM710 now it works for read information in EDL mode. Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM56) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00D00 [E1B00D00] 00000000 OPK_DATA : 53FFA4BC1D7442D02C4F078671F21CF12BED89EA39F394BEC2 71187902D4B04E Initializing Protocol...OK Sending Loader [prog_firehose_lite.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : E1B00D00, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Lenovo Lenovo L38111 [kunlun2] Brand : Lenovo Prod.Name : kunlun2_row Software : PKQ1.190127.001 dev-keys, 11.0.224_191126 [Tue Nov 26 16:57:16 CST 2019] Android Ver. : 9 Patch Level : 2019-10-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 6.3 |
The Following User Says Thank You to vishkarma1122 For This Useful Post: |
11-23-2020, 13:14 | #5 (permalink) |
Member: 2653152 Status: Offline Thanks Meter: 28 | Sorry i couldn't test because that was came for Hardware issue after solved given to User. I have taken an backup of its security files for future software issue with that loader. so don't have right now that Lenovo K10 L38111 model, but i believe this loader can Reset the FRP and Factory Reset also. Logs. of backup of security files. Operation : Read Firmware Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM56) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00D00 [E1B00D00] 00000000 OPK_DATA : 53FFA4BC1D7442D02C4F078671F21CF12BED89EA39F394BEC2 71187902D4B04E Initializing Protocol...OK Sending Loader [prog_firehose_lite.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : E1B00D00, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK USERDATA : Encrypted Reading USERDATA will cause large firmware size and slow read speed. Reading Device Information...OK Device : Lenovo Lenovo L38111 [kunlun2] Brand : Lenovo Prod.Name : kunlun2_row Software : PKQ1.190127.001 dev-keys, 11.0.224_191126 [Tue Nov 26 16:57:16 CST 2019] Android Ver. : 9 Patch Level : 2019-10-01 Reading [fsg]...Done Reading [devinfo]...Done Reading [sec]...Done Reading [fsc]...Done Reading [modemst1]...Done Reading [modemst2]...Done Reading [persist]...Done Reading [keystore]...Done Saved to : C:\UMTool\QcFire\Read\Lenovo_Lenovo L38111_PKQ1.190127.001 dev-keys_2019-10-01\ Operation Finished. QcFire Ver. 6.3 |
