11-02-2016, 07:58 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Download Aircel Firmware from support and try to flash. This firmware seems to be Customized thus no Generic method supported. Br, Ultimate Multi Tool |
11-02-2016, 08:18 | #3 (permalink) |
Registered User Join Date: Jan 2010 Location: INDIA
Member: 1214756 Status: Offline Thanks Meter: 53 | Port : COM10 : ZTE Diagnostics Interface (COM10) Baud Rate : 921600 Device : ZTE MF190 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Jul 16 2014 13:10:39 Release : Jul 16 2014 13:10:39 Hw Ver. : SECMF825 IMEI : 359049021847557 Build : --- Software : BD_SECMF825AV1.0.0B01 Checking for Modem Device.. OK Modem Port : COM11 : ZTE Proprietary USB Modem Opening Port... OK Reading AT Mode Information... OK Model : Communication Err! IMEI : Communication Err! Version : Communication Err! Simlock : Unknown Sim Status : Unknown Port Closed. Operation Finished. Elapsed Time: 00:21 [Module Ver. 3.1] Log Saved to Logs\161102_124036.log this is reared info |
11-02-2016, 08:19 | #4 (permalink) |
Member: 1214756 Status: Offline Thanks Meter: 53 | try to write firmware but got error Port : COM10 : ZTE Diagnostics Interface (COM10) Baud Rate : 921600 Device : ZTE MF190 Operation : Flash Opening Port... OK Compile : Jul 16 2014 13:10:39 Release : Jul 16 2014 13:10:39 Hw Ver. : SECMF825 IMEI : 359049021847557 Preparing to Flash... Uprotecting Memory... OK Secure Operation Authorization... Err 0x03 ,Skipped! Setting Download Mode... OK Waiting for Modem... Modem Not Detected in Donwload Mode! Port Closed. Operation Failed! Elapsed Time: 00:44 [Module Ver. 3.1] Log Saved to Logs\161102_124912.log |
11-02-2016, 08:49 | #5 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Appears to be new security device. Currently not supported. There is a way only if you can flash with Aircel Firmware, and Modem Not Found means either Modem did not switched to download mode or download mode drivers failed to install. You check further if you want. Br, Ultimate Multi Tool |
