Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 07-08-2017, 10:51   #1 (permalink)
Shubhanshu~'s Avatar
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
LG H791 Nexus 5X Flashing ....
Flashing Failed in LG V0.1
Port	: COM36 : Qualcomm HS-USB QDLoader 9008 (COM36)
Baud Rate	: 115200 - Auto
Device	: LG D820
Operation	: Write Firmware
Opening Port...OK
Reading Information...Hello Failed!
Operation Failed.
Time taken: 00:03
[Module Ver. 0.1]
Log Saved to Logs\170708_151512.log
Firmware Extraction
Filename	: D:\LG Flash File\LG H791 Nexus 5X BullHead\TOT File bin_lgh791at-00-v20a-nxs-xxx-jul-22-2016-16g-nrd90m-user+0\LGH791AT-00-V20a-NXS-XXX-JUL-22-2016-16G-NRD90MFE-USER+0.tot
Model	: H791
Version	: LGH791AT-00-V20a-NXS-XXX-JUL-22-2016-16G-NRD90M-USER+0
Extracting PrimaryGPT_0 ...Done
Extracting modem_16384 ...Done
Extracting pmic_196608 ...Done
Extracting sbl1_197632 ...Done
Extracting tz_199680 ...Done
Extracting sdi_201728 ...Done
Extracting hyp_202752 ...Done
Extracting rpm_203776 ...Done
Extracting aboot_204800 ...Done
Extracting sbl1bak_208896 ...Done
Extracting pmicbak_210944 ...Done
Extracting tzbak_211968 ...Done
Extracting hypbak_214016 ...Done
Extracting rpmbak_215040 ...Done
Extracting abootbak_216064 ...Done
Extracting sec_227328 ...Done
Extracting misc_228352 ...Done
Extracting persist_261120 ...Done
Extracting imgdata_339968 ...Done
Extracting laf_378880 ...Done
Extracting keymaster_477184 ...Done
Extracting cmnlib_478208 ...Done
Extracting keymasterbak_479232 ...Done
Extracting cmnlibbak_480256 ...Done
Extracting boot_622592 ...Done
Extracting recovery_688128 ...Done
Extracting vendor_753664 ...Done
Extracting vendor_1015808 ...Done
Extracting vendor_1019872 ...Done
Extracting vendor_1177600 ...Done
Extracting cache_1261568 ...Done
Extracting system_1458176 ...Done
Extracting system_1721864 ...Done
Extracting system_1725920 ...Done
Extracting system_1986520 ...Done
Extracting system_2246152 ...Done
Extracting system_2250208 ...Done
Extracting system_2510808 ...Done
Extracting system_2770440 ...Done
Extracting system_2774496 ...Done
Extracting system_3035096 ...Done
Extracting system_3294728 ...Done
Extracting system_3298784 ...Done
Extracting system_3555328 ...Done
Extracting system_3559384 ...Done
Extracting system_3819016 ...Done
Extracting system_3823072 ...Done
Extracting system_4083672 ...Done
Extracting system_4345816 ...Done
Extracting system_4607960 ...Done
Extracting system_4870104 ...Done
Extracting system_5132248 ...Done
Extracting system_5390336 ...Done
Extracting system_5394392 ...Done
Extracting system_5656536 ...Done
Extracting system_5918680 ...Done
Extracting system_6180824 ...Done
Extracting system_6379656 ...Done
Extracting system_6674008 ...Done
Extracting system_6705112 ...Done
Extracting system_6962968 ...Done
Extracting system_6967256 ...Done
Extracting system_7487488 ...Done
Extracting system_7490560 ...Done
Extracting BackupGPT_30776320 ...Done
Extract Path	: D:\LG Flash File\LG H791 Nexus 5X BullHead\QFIL File\
XML File	: D:\LG Flash File\LG H791 Nexus 5X BullHead\QFIL File\rawprogram0.xml
Time taken: 00:56
[Module Ver. 0.1]
Log Saved to Logs\170708_150158.log
Using QC Fire to flash Extracted file
Operation	: Flash
Checking for existing devices... Found
Port	: COM36
Opening Port... OK
Init Handshake Sequence... OK
Hardware ID	: E1909600 [8992] 06103100
Initializing Protocol... OK
Using Auto Selection
Preparing Firehose Loader... Done
Sending Loader [8992.ufl]... Done
Executing Loader... Failed!
Please use correct loader and check USB port / cable.
Operation Finished.
Module Ver. 0.9
Operation	: Flash
Port	: COM36
Opening Port... OK
Sending Loader [8992_1.ufl]... Done
Operation Finished.
Module Ver. 0.9
Any solution??
Old 07-08-2017, 16:10   #2 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 11,133
Flashing with LG Tool needs phoen in Emergency Download Mode.
In EDL mode, you need to use Qualcomm Loader for you CPU type.
Wait for new QcFire update, possibly we mave have some good things for you.
Br,
Ultimate Multi Tool
The Following 4 Users Say Thank You to U.M.T For This Useful Post:
Old 07-24-2017, 12:11   #3 (permalink)
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
Hi,
Tested Piece with New update, But still its not working!!!
Operation	: Flash
Checking for existing devices...Found
Port	: COM63
Opening Port...OK
Init Handshake Sequence...OK
OPK_DATA	: E5310D58645CA1134142643F8D90BBAD32AE247D5E3188A1B88894F7C81D6F72
Initializing Protocol...OK
Using Auto Loader Selection [2]
Preparing Firehose Loader...Done
Sending Loader [8992_004.ufl]...Done
Executing Loader...Failed!
Operation Finished.
Module Ver. 1.0
Operation	: Flash
Port	: COM63
Opening Port...OK
Sending Loader [8992_1.ufl]...Done
Operation Finished.
Module Ver. 1.0
Operation	: Flash
Port	: COM63
Opening Port...OK
Sending Loader [8992_003.ufl]...Done
Operation Finished.
Module Ver. 1.0
Operation	: Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Found Port	: Qualcomm HS-USB QDLoader 9008 (COM63)
Driver Info	: Lenovo Inc., leusbser.sys, 2.0.9.6
Connecting to phone...OK
Waiting for response...OK
Sending Loader [8992_002.ufl]...Done
Operation Finished.
Module Ver. 1.0
Operation	: Flash
Port	: COM63
Opening Port...OK
Sending Loader [8992_001.ufl]...Done
Operation Finished.
Module Ver. 1.0
Operation	: Flash
Port	: COM63
Opening Port...OK
Sending Loader [8992.ufl]...Done
Operation Finished.
Module Ver. 1.0
LG V0.2 Flashing
Port	: COM63 : Qualcomm HS-USB QDLoader 9008 (COM63)
Device	: LG D820
Opening Port...OK
Operation Failed.
Time taken: 00:03
[Module Ver. 0.2]
Log Saved to Logs\170724_163647.log
Kindly Check ...
Old 07-24-2017, 12:14   #4 (permalink)
U.M.T's Avatar
Member: 2465108
Seems you do not understand what to do.
WITH LG MODULE, YOU NEED TO CONNECT PHONE IN LG DOWNLOAD MODE!!!!
About QcFire error, we will check it. But when LG Module can do it then why need QcFire?
QcFire is needed only when your phone is bricked.
Br,
Ultimate Multi Tool
The Following User Says Thank You to U.M.T For This Useful Post:
Old 07-24-2017, 12:38   #5 (permalink)
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
Hi,
Phone is bricked...
Only 9008 Port.
Old 09-15-2017, 13:47   #6 (permalink)
Member: 27706
Thanks Meter: 5
Did You manage problem with nexus?
Old 02-02-2018, 22:01   #7 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 111
Br,
Ultimate Multi Tool
wich file i have to select as loader?
Old 03-01-2018, 21:37   #8 (permalink)
Member: 2377800
Sonork: nono
Thanks Meter: 41
can you share the file with us ;?
pleas
Old 05-10-2018, 16:38   #9 (permalink)
Member: 2737990
me same problem i flashed wrong file .i have 16gb mobile and i flashed 32g and now dead and only 9008 port.any idea how to flash again?
Old 05-12-2018, 08:59   #10 (permalink)
Member: 2401939
Thanks Meter: 668
for google bricked devices first flash only recovery then boot one time your phone in recovery mode, then power off your phone and flash whole firmware in edl mode and boot it up normally, it will unbrick your device
already tested in so many nexus phones
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.16241 seconds with 7 queries
