mi 2014712 note1 4g.. logo hang. flashing error [ANSWERED] hang on logo flashing log Code: Operation : Flash not even detecting in edl mode also kindly assit regards! |
There is not that you phone will be completely dead. You must disconnect battery and connect again, and use Mi Deep Flash cable. Now you just try to Format FS instead of full flashing. Br, Ultimate Multi Tool |
done thanks umt team Operation : Flash Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM146) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1809100 [8x10] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Firehose Loader... Done Executing Loader... OK Hardware : 8x10, eMMC, 8 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 49152, Sector Size: 512 Writing sbl1.mbn ... Done Writing sbl1.mbn ... Done Writing rpm.mbn ... Done Writing rpm.mbn ... Done Writing tz.mbn ... Done Writing tz.mbn ... Done Writing sdi.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing dummy.img ... Done Writing dummy.img ... Done Writing NON-HLOS.bin ... Done Writing boot.img ... Done Writing recovery.img ... Done Writing system.img ... Done Writing cache.img ... Done Writing userdata.img ... Done Writing gpt_main0.bin ... Done Writing gpt_backup0.bin ... Done Applying Patches... Done Resetting device... Done Operation Finished. |
Unable to flash Redmi 2014712 Code: Operation : Flash |
Tried with other version too With Version 0.7.1 Code: Operation : Flash Code: Operation : Flash |
It seems eMMC issue. Please charge battery and try again. If not done, then it must be hardware issue. Br, Ultimate Multi Tool |
Hi, Can we have all qc fire version uploaded at support to give it a final try, on support only I found only above 3 versions. BR |
With Ver 0.8 Code: Hardware : 8x26, eMMC, Unknown Code: Hardware : 8x26, eMMC, 2 GB So Request you to Please Upload at support all previous version to give it a final try. BR |
You have to use 0.9. It is good, and if any issue, we will fix in future update. Br, Ultimate Multi Tool |
