06-22-2018, 17:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | vivo 1801 does not enter Qualcomm HS-USB QDLoader 9008 mode |
06-24-2018, 05:54 | #4 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | Vivo 1801 y71 password and frp removed with qcfire i removed viv0 y71 (1801) password and frp also via test point and must be remove battery connector .here is log Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM56) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8917_001.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1724 Software : OPM1.171019.011 release-keys, eng.compil.20180524.215936 [Thu May 24 21:59:36 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-04-01 Preparing Data...Done Formatting Userdata...Done Operation Finished. Module Ver. 2.3 frp removed log Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM56) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8917_001.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1724 Software : OPM1.171019.011 release-keys, eng.compil.20180524.215936 [Thu May 24 21:59:36 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-04-01 Resetting FRP Lock......Done Operation Finished. Module Ver. 2.3 |
The Following User Says Thank You to pakmobiles For This Useful Post: |
