03-27-2018, 13:54 | #1 (permalink) |
Freak Poster Join Date: Feb 2010 Location: jattari
Member: 1239360 Status: Offline Thanks Meter: 95 | micromax e4820 LOCK ONLY....PLZ HELP when i power on... its show only lock screetn i have full hard reset in recovery menu....but not done its show this massage "please contact 400-011-1366 or visit cloud-en.360shouji.com to unlock the phone." see this link...https://ibb.co/ex8m4n when i frp unlock in miscellaneous tab via fastboot mode..here is log Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Qualcomm FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : REFRESH Product : E4820 Warranty : Yes Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Failed Operation Failed. Elapsed Time: 00:02 [Module Ver. 4.8] plz help me team... |
03-28-2018, 15:27 | #3 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Quote:
it look like cloud locked or like privacy lock. i think UMT not supported yet but there is nothing wrong if you try format fs with QCFire. | |
04-01-2018, 05:38 | #7 (permalink) |
Member: 1239360 Status: Offline Thanks Meter: 95 | sir after connect edl mode..... loader problem....see this Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009900 [8976] 15150000 OPK_DATA : 9E07E8C5DB0A1392F7D1795B9FF90A7DA9BDB38CA18F807E38 21553D0DB24140 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8976.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.0 |
04-01-2018, 06:54 | #8 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | https://drive.google.com/file/d/1w_m...ew?usp=sharing Download this loader, and select in Custom Loader and post result here. For realtime support, you can contact us on Skype. Br, UMT |
04-01-2018, 07:01 | #9 (permalink) |
Member: 1239360 Status: Offline Thanks Meter: 95 | Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009900 [8976] 15150000 OPK_DATA : 9E07E8C5DB0A1392F7D1795B9FF90A7DA9BDB38CA18F807E38 21553D0DB24140 Initializing Protocol...OK Preparing Firehose Loader...Done Sending Loader [8976_012.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.0 when i use on firmware loader.....then Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1009900 [8976] 15150000 OPK_DATA : 9E07E8C5DB0A1392F7D1795B9FF90A7DA9BDB38CA18F807E38 21553D0DB24140 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8976_lite.mbn]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. |
06-22-2018, 05:26 | #11 (permalink) |
Member: 1239360 Status: Offline Thanks Meter: 95 | after flash this file via Qgdp tool.....6.0.033.P3.170320.QK1515 https://drive.google.com/uc?id=0B1hm...xport=download phone has blank display ...see this plzz have you any solution ....plzz help anyone |
06-22-2018, 20:06 | #12 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | firmware link try with this firmware again |
06-24-2018, 05:32 | #13 (permalink) | |
Member: 1239360 Status: Offline Thanks Meter: 95 | Quote:
i already try this firmware.....but same result i think....both are same firmware | |
