05-13-2024, 10:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,095 | OnePlus Nord Frp Done Using Patch Method Code: Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. SAMSUNG : Turn Off phone, hold EDL Cable Button and insert to phone and press VOL DOWN + POWER on phone more than 3 times rapidly and then leave EDL Cable Button. Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1E01100 [SM7250] 41515100 OPK_DATA : B55B7FF3F00B51F821204C6FE5E8BAC69682E8E3A5583E0413536462BAA5E941 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM7250]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SM7250, UFS, 256 GB LU Count : 6 [0x03ABE000] [0x00000800] [0x00000800] [0x00002000] [0x000AF000] [0x00025800] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK [Sign] Build : Int. Build : Resetting FRP Lock...Failed Using Patch Method... Done Done Operation Finished. QcFire Ver. 9.6 |
The Following 3 Users Say Thank You to raisalina For This Useful Post: |
