02-11-2021, 18:48 | #16 (permalink) |
No Life Poster Join Date: May 2006 Location: Marrakech
Member: 282206 Status: Offline Thanks Meter: 102 | or you have first solution by UMT If phone entered META mode, but software says not found, then must click button once again, and do not disconnect phone because if it is already in meta mode, software will detect it automatically on "Checking for existing META port..". |
03-07-2021, 09:24 | #17 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 362 | Quote:
if i press button again will become Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. No phone found. Operation failed! [UltimateMTK Ver. 3.9] | |
03-07-2021, 09:25 | #18 (permalink) |
Member: 172261 Status: Offline Thanks Meter: 362 | phone already in meta mode but Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. Found MediaTek USB Port (COM322) on COM322 Device Path : \\?\usb#vid_0e8d&pid_0003#5&155d656&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Mode : BROM Rebooting to META mode... Waiting for phone in META mode... No phone found. Operation Failed. Operation failed! [UltimateMTK Ver. 3.9] |
03-07-2021, 09:30 | #19 (permalink) |
No Life Poster Join Date: Jan 2010 Location: india Age: 43
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | oppo a15s cph2179 ok try brom mode not meta mode oppo a15s cph2179 ok Brand : Oppo Model : A15 (CPH2185) Operation : Format FS Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 Port Name: MediaTek USB Port_V1632 (COM4) Path: \\?\usb#vid_0e8d&pid_0003#5&2e5104df&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Could not read specified bytes. Unable to read! Userdata is NOT ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.9] |
The Following 4 Users Say Thank You to gkmobiles For This Useful Post: |
03-07-2021, 09:35 | #20 (permalink) | |
how did you do that im still stuck in meta mode | |
03-07-2021, 09:51 | #21 (permalink) |
Member: 172261 Status: Offline Thanks Meter: 362 | after install LibUSB Model : A15 (CPH2185) Operation : Format FS Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM322 Port Name: MediaTek USB Port_V1632 (COM322) Path: \\?\usb#vid_0e8d&pid_0003#5&155d656&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Handshake Failed! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.9] |
03-07-2021, 09:52 | #22 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,375 | Select Model in MTK v3.9 and do it in BROM mode. Br, UMT |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
03-07-2021, 09:59 | #23 (permalink) |
Member: 172261 Status: Offline Thanks Meter: 362 | after reboot PC and A15 now Brand : Oppo Model : A15 (CPH2185) Operation : Format FS Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM322 Port Name: MediaTek USB Port_V1632 (COM322) Path: \\?\usb#vid_0e8d&pid_0003#5&155d656&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM322) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Unable to read! Userdata is NOT ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.9] THANK YOU gkmobiles & UMT |
03-07-2021, 11:13 | #24 (permalink) |
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | open install-filter-wizard and add mediatek ELD POART THEN BY MODEL OPPO A15 AND FORMAT FS OK (NOT WORK MEDA POART) BROM MODE (FLASH MODE) OK HAPPY WORK |
03-14-2021, 14:04 | #25 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | Brand : Oppo Model : A15 (CPH2185) Operation : Oppo Reset Locks Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM16 Port Name: MediaTek USB Port_V1632 (COM16) Path: \\?\usb#vid_0e8d&pid_0003#6&13f4c3e&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM16) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Unable to read! Userdata is NOT ENCRYPTED Resetting Locks... Reset done --- IMPORTANT --- - You must start phone directly in recovery. - Hold Volume Down and Power ON to enter Recovery. [UltimateMTK Ver. 3.9] |
05-03-2021, 07:41 | #26 (permalink) |
Freak Poster Join Date: Dec 2017
Member: 2792776 Status: Offline Sonork: 1577835 Thanks Meter: 82 | Brand : Oppo Model : A15 (CPH2185) Operation : Format FS Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM100 Port Name: MediaTek USB Port (COM100) Path: \\?\usb#vid_0e8d&pid_0003#6&3378f16b&0&8#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM100) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Mon Dec 28 21:16:32 CST 2020 Build Flavor : full_oppo6765-user Build Desc. : full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Android Ver. : 10 Display ID : QP1A.190711.020 release-keys Patch Level : 2021-01-05 Platform : MT6765 Board : oppo6765 Platform : mt6765 Userdata is NOT ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
The Following User Says Thank You to rashid48581 For This Useful Post: |
05-06-2021, 22:19 | #27 (permalink) |
Banned Join Date: Jan 2015 Location: EARTH Age: 39
Member: 2332823 Status: Offline Sonork: 100.1662161:modern-mobile Thanks Meter: 463 | Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. Found MediaTek USB Port_V1633 (COM14) on COM14 Device Path : \\?\usb#vid_0e8d&pid_0003#5&1c38aec2&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Mode : BROM Rebooting to META mode... Waiting for phone in META mode... Found MediaTek ETS Port (COM6) on COM6 Device Path : USB\VID_22D9&PID_202D&REV_????&MI_03 Configuring Communication Channel... Reading phone information... CPU : MT6765 SW Ver. : MOLY.LR12A.R2.TC16.Q.G35.PR1.SP.V2.P168 HW Ver. : OPPO_Q0MP1_K65V1_64_BSP_HW Brand: OPPO Model: unknown Name: OPPO A15 Platform: MT6765 OEM Prod.: CPH2185 OEM Device: OP4F2F Build Date: Sun Feb 14 16:52:41 CST 2021 Display ID: CPH2185_11_A.21 OTA Version: CPH2179PU_11.A.21_0210_202102141556 Patch Level: 2021-02-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.2] done many 4 sets not any error any bugs u.m.t team rocks |
The Following User Says Thank You to modern-mobile For This Useful Post: |
10-03-2021, 19:13 | #29 (permalink) |
Junior Member Join Date: Nov 2016 Location: Pakistan
Member: 2649651 Status: Offline Sonork: 100.1677928 Thanks Meter: 5 | I've Done With Same Method its working FSFORMAT META isn't work anymore i think soo. Brand : Oppo Model : A15 (CPH2185) Operation : Format FS Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM3 Port Name: MediaTek USB Port_V1632 (COM3) Path: \\?\usb#vid_0e8d&pid_0003#5&2080e735&0&5#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_oppo6765_211003_231031.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM3) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Wed Aug 11 23:39:41 CST 2021 Build Flavor : full_oppo6765-user Build Desc. : full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Android Ver. : 10 Display ID : QP1A.190711.020 release-keys Patch Level : 2021-08-05 Userdata is NOT ENCRYPTED Formatting userdata... - Done. |
The Following User Says Thank You to Badsha7714 For This Useful Post: |
12-07-2021, 20:54 | #30 (permalink) | ||
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | Oppo CPH2185 Can you please check . it has failed to do the factory reset. Quote:
The Following User Says Thank You to luckycool For This Useful Post: |
