Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 05-13-2020, 10:11   #1 (permalink)
Member: 215919
Thanks Meter: 37
mi 9 se efs problem please help
mi 9 se I'm doing efs reset operation ok but efs is not reset
Operation : Wipe EFS (FastBoot)
Searching for Device in FastBoot Mode...OK
Reading Information...OK
FastBoot Ver. : GetVar Variable Not found
Product : grus
Bootloader : Unlocked
Wiping EFS...Failed
Wiping EFS [Method 2]...Done
QcFire Ver. 5.5
Old 05-13-2020, 19:09   #2 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
You can also try in Sideload mode, but only if phone has stock recovery.
If sideload mode also does not work, then check if you can do it manually in fastboot mode. Commands are following:
fastboot erase modemst1
fastboot erase modemst2
fastboot erase fsg
Be warned, no EFS backup can be made in Fastboot mode. So it will not be possible to recovery EFS if anything goes wrong.
Br,
UMT
Page generated in 0.12461 seconds with 8 queries
