02-04-2020, 10:21 | #1 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2866554 Status: Offline Thanks Meter: 26 | OPPO CPH1933 A5 2020 dead by Umt Emmc Isp pinout VCCQ & VCC pionout not found in Isp pinout so i use data cable for VVC voltage and phone show his qualcomm-hs-usb-qd loader 9008 port but not connect on Umt Emmc Isp Tool so i try to connect 3 or 4 time for connection on umt emmc software but after that my phone dead now. i cant's understand because no emmc work on this model phone & motherboard is fresh no damage on jumpering, when i connect handset on PC only qualcomm-hs-usb-qd loader 9008 port show but phone not power on dead now so UMT team please help me for this problem |
The Following User Says Thank You to MRT Creation For This Useful Post: |
02-04-2020, 12:29 | #6 (permalink) |
Freak Poster Join Date: Jun 2017 Location: Delhi_India Age: 30
Member: 2729296 Status: Offline Sonork: 100.1680251 Thanks Meter: 214 | OPPO CPH1933 A5 2020 isp not avilable at this time now avilavble cph 1931 isp both matherbord are diffrent |
The Following User Says Thank You to azaz_ahamad For This Useful Post: |
02-04-2020, 12:42 | #7 (permalink) |
Member: 2729296 Status: Offline Sonork: 100.1680251 Thanks Meter: 214 | clk ragistane remove and make jumer 1000% solve your problem |
02-04-2020, 12:50 | #8 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | jumper clk resistor and change cmd resistor if still desame check around emmc maybe you spoil some parts there when removing the shield |
