10-15-2020, 08:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | oppo f5 flash da error` Action : Firmware update. Selected Model: OPPO: F5 Exe version: Avengers Box MTK 0.6.1 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Keep VOL- button untill inserting USB cable. Detected : MediaTek USB Port (COM23) Boot mode: Brom Phone detected...Please wait BBCHIP: 6763 1 ca01 Using Algo 3. Helio MT6763 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Helio connect da error, aborting. Error[0xc0070004]: STATUS_DA_HASH_MISMATCH BBCHIP MT6763 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. Flash files count is :18 Action : Firmware update. Selected Model: OPPO: F5 Exe version: Avengers Box MTK 0.6.1 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Keep VOL- button untill inserting USB cable. Detected : Preloader And Gadget Serial (COM73) Phone detected...Please wait BBCHIP: 6763 1 ca01 Using Algo 3. Helio MT6763 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT6763 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. Last edited by .:D:.; 10-15-2020 at 08:58. |
10-15-2020, 09:08 | #2 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | Flash files count is :18 Action : Firmware update. Selected Model: OPPO: F5 Exe version: Avengers Box MTK 0.6.1 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Keep VOL- button untill inserting USB cable. Detected : MediaTek USB Port (COM23) Boot mode: Brom Phone detected...Please wait BBCHIP: 6763 1 ca01 Using Algo 3. Helio MT6763 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE BBCHIP MT6763 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM53) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Starting flash. [-1073545210]Error: STATUS_STORAGE_MISMATCH [helio]Wait untill phone will start charging. [0]All done. |
