10-03-2021, 17:08 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: india
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | Poco C3 FRP Reset Not Done..... Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM54 Port Name: MediaTek USB Port (COM54) Path: \\?\usb#vid_0e8d&pid_0003#5&13bfbfd5&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k65v1_64_bsp_211003_213632.bin DA : MTK_AllInOne_DA.bin Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] 2)Brand : Xiaomi Model : Poco C3 Operation : Reset FRP Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM54 Port Name: MediaTek USB Port (COM54) Path: \\?\usb#vid_0e8d&pid_0003#5&13bfbfd5&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k65v1_64_bsp_211003_213816.bin Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] How To Frp Reset ,Please help me... |
10-03-2021, 17:38 | #4 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
check your usb cable/drivers...it's communication problem due to bad usb cable or bad usb hub/drivers try with other clean pc.. b.r. | |
