Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 10-06-2015, 08:55   #31 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
ZTE s100 Read Info
Port : COM130 : ZTE CDMA Handset Diagnostics Interface (COM130)
Baud Rate : 921600
Device : ZTE S100
Operation : Read Info
Opening Port... OK
Reading Information... OK
Compile : Aug 17 2009 12:59:11
Release : Oct 24 2006 13:00:00
Hw Ver. : MTS_S100
ESN : 80C259A7
MEID : A100004744BCD1
Unlocking Security... OK
Build : QSC6010-SCNRZ-MTS_S100_RBTL40NV1.0.0B04
Unexpected reply from phone!
Soft Ver.
Detected : S100
User Code : 0000
Port Closed.
Operation Finished.
Time Taken: 00:01
Module Ver. [1.0]
Unlocking..................
Baud Rate : 921600
Device : ZTE S100
Operation : Unlock
Opening Port... OK
Hw Ver. : MTS_S100
ESN : 80C259A7
Soft Ver.
Detected : S100
User Code : 0000
Checking if Supported for Unlock... OK
Switching to Offline... OK
Sending Default SPC... OK
Unlocking Phone... OK
Resetting Phone... OK
Port Closed.
Operation Finished.
Time Taken: 00:02
Module Ver. [1.0]
The Following User Says Thank You to yusufali786 For This Useful Post:
Old 10-06-2015, 13:51   #32 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
lg 3520 successfully unlock.......................
Port : COM151 : LGE CDMA USB Serial Port (COM151)
Baud Rate : 38400 - Auto
Device : LG TS3520
Operation : Unlock
Opening Port... OK
Compile : Apr 23 2010 00:51:52
Release : Apr 23 2010 23:59:00
Hw Ver. : TS352F08
ESN : 80CxXXXX
MEID : A0000021XXXXXXX
Model : TS3520
Software : F08
Preparing Data... OK
Setting Offline Mode... OK
Security Unlock... OK
Setting Download Mode... OK
Preparing Bootloader... OK
Sending Bootloader... OK
Executing Bootloader... OK
Erasing Flash Memory... OK
Writing Flash Memory... OK
Port closed.
Operation Finished.
Time Taken: 00:29
Module Ver. [1.0]
Log Saved to Logs\151006_174739.log
Old 10-07-2015, 06:47   #33 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
zte s100 unlock done
Port    : COM71 : ZTE CDMA Handset Diagnostics Interface (COM71)
Baud Rate    : 921600
Device    : ZTE S100
Operation    : Unlock
Opening Port... OK
Compile    : Jul 06 2010 21:17:17
Hw Ver.    : MTS_S100
ESN    : 8093Fxxx
MEID    : A1000040xxxxxx
Build    : QSC6010-SCNRZ-MTS_S100_RBTL40NV1.0.1B02
Soft Ver.
Detected    : S100
User Code    : 0000
Port Closed.
Operation Finished.
Time Taken: 00:02
Module Ver. [1.0]
Log Saved to Logs\151007_111216.log
The Following User Says Thank You to rehmani For This Useful Post:
Old 10-07-2015, 06:58   #34 (permalink)
gsm_links's Avatar
Member: 561947
Sonork: 100.1580399
Thanks Meter: 948
Thumbs up MTS 131 Unlock Done by Ultimate Multi Tool!!!
Regards
The Following User Says Thank You to gsm_links For This Useful Post:
Old 10-07-2015, 08:08   #35 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
Lg 3610 successfully unlocked...........
Port : COM153 : LGE CDMA USB Serial Port (COM153)
Device : LG RD3610
Operation : Unlock
Opening Port... OK
Compile : Sep 02 2008 14:59:32
Release : Sep 02 2008 24:00:00
Hw Ver. : RD361F02
ESN : 80A9XXXX
MEID : A00000103XXXX
Model : RD3610
Software : F02
Port closed.
Operation Finished.
Time Taken: 01:26
Module Ver. [1.0]
Log Saved to Logs\151007_122820.log
Old 10-07-2015, 12:40   #36 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
samsung b229 unlock done
Port    : COM58 : Easy Jtag Control Port (COM58)
Baud Rate    : 9600 [Auto]
Device    : Samsung B229
Operation    : Unlock
Opening Port... OK
Setting Test Mode... OK
Step 1... OK
Step 2... OK
Step 3...
Port Closed.
Operation Finished.
Time Taken: 00:03
Module Ver. [1.0]
Log Saved to Logs\151007_143506.log
Old 10-07-2015, 12:42   #37 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
lima tab 601 pattern reset done
Port    : ADB Interface
Baud Rate    : Not Applicable
Device    : Android
Operation    : Remove Locks
Searching for Device... Found
Model    : Tx-601
Version    : 4.0.4
Hardware    : sun5i
Baseband    : I50A-MX-CM.BT.FM-H02-V08-U99.
SIM Card    : ABSENT
CPU    : armeabi-v7a
IMEI 1    : 9112555500xxxxx
IMEI 2    : Empty
Checking Root Access... OK
Root    : Rooted
Removing Google Locks... OK
Please Restart Device.
Operation Finished.
Elapsed Time: 00:02
Module Ver. [1.0]
Old 10-07-2015, 12:44   #38 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
zte c330 repair meid done
Port    : COM14 : Prolific USB-to-Serial Comm Port (COM14)
Baud Rate    : 115200
Device    : S100
Operation    : Write MEID
Opening Port... OK
Compile    : Sep 04 2008 18:47:57
Hw Ver.    : Shyam_C3
ESN    : 00000000
MEID    : 00000000000000
Auto Detection is Disabled!
Unlocking Security... Failed
Build    : QSC6010-SCNRZ-Shyam_C330_RBTL37NV1.0.0B02
Software
Detected    : Shyam_C3
User Code    : 0000
Writing MEID A100004A4xxxxx... OK
New ESN    : 804Exxxx
New MEID    : A100004A4xxxxx
Port Closed.
Operation Finished.
Time Taken: 00:02
Module Ver. [1.0]
Log Saved to Logs\151007_171332.log
Old 10-07-2015, 13:11   #39 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
zte m131 flash successfully
Port : COM162 : ZTE CDMA Handset Diagnostics Interface (COM162)
Baud Rate : 921600
Device : ZTE M131
Operation : Flash
Opening Port... OK
Compile : Nov 26 2014 14:22:47
Release : Apr 24 2009 24:00:00
Hw Ver. : V.MTS.M1
ESN : 80A12159
MEID : A100001A4896FB
Build : V.MTS.M131.B08
Soft Ver. : SSTL_S183_FM_RBTL40NV1.0.0B12
Detected : M131
User Code : 0000
Waiting for Reconnect... OK
Initializing Flash Chip... OK
Flash Chip : SPANSION S71VS128RC0
Chip Size : 16 MB
Firmware : ZTE-M131-V.MTS.M131.B04.bin
Fw. Size : 16 MB
Writing Firmware... OK
Port Closed.
Operation Finished
Time Taken: 07:24
Module Ver. [1.0]
after flash repair security
Baud Rate : 921600
Device : M131
Opening Port... OK
Compile : Apr 24 2014 22:06:45
Hw Ver. : V.MTS.M1
ESN : 00000000
Build : V.MTS.M131.B04
Software : SSTL_S183_FM_RBTL40NV1.0.0B03
Detected : M131
User Code : 0000
Writing MEID A100001A4896FB... OK
New ESN : 80A12159
New MEID : A100001A4896FB
Port Closed.
Operation Finished.
Time Taken: 00:01
Module Ver. [1.0]
Log Saved to Logs\151007_173837.log
Old 10-07-2015, 15:19   #40 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
zte s100 unlock successfully
Baud Rate : 921600
Device : ZTE S100
Operation : Unlock
Opening Port... OK
Compile : Sep 21 2010 09:45:02
Hw Ver. : MTS_S100
ESN : 8086XXXX
MEID : 00000000A00000
Build : QSC6010-SCNRZ-MTS_S100_RBTL40NV1.0.3B02
Read Not Supported
Soft Ver.
Detected : S100
User Code : 0000
Port Closed.
Operation Finished.
Time Taken: 00:02
Module Ver. [1.1]
Old 10-08-2015, 12:13   #41 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
samsung b189 read user code done
Port    : COM24 : SAMSUNG Mobile Modem
Baud Rate    : 921600
Device    : Samsung B259
Opening Port... OK
Compile    : Apr 24 2009 16:25:56
Release    : Feb 14 2008 07:00:00
Hw Ver.    : SCH-B189
ESN    : 804Cxxxx
MEID    : A10000473xxxxx
Executing Security Unlock... OK
Sending SPC (000000)... OK
User Code    : 6657
Port Closed.
Time Taken: 00:03
Module Ver. [1.0]
Log Saved to Logs\151008_161414.log
Old 10-08-2015, 12:15   #42 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
jivi c300 user password read done
Port    : COM68 : CDMA USB Diagnostics Interface (COM68)
Baud Rate    : 921600
Device    : Haier C2030
Opening Port... OK
Compile    : Nov 15 2013 19:45:59
Release    : May 06 2008 07:00:00
Hw Ver.    : L665_7_I
ESN    : 80F6xxxxx
MEID    : A4444444444444
BUILD    : QSC6010-L665_7_IND-3550
Reading Extended Information... OK
User Code    : 0987
SPC    : 000000
Port Closed.
Operation Finished.
Time Taken: 00:01
Module Ver. [1.0]
Log Saved to Logs\151008_164525.log
Old 10-08-2015, 12:19   #43 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
huawei c2856 fs.pm.log recover
Analyzing File...
EFS File    : cefs_modem.mbn
CHECKING SMARTCARD[OK].
Port    : COM9 : HUAWEI CDMA Handset - NMEA (COM9)
Baud Rate    : 921600
Device    : Huawei C2856
Operation    : Write APP/EFS
Opening Port... OK
Preparing Phone... OK
Authorizing Download... OK
Finalizing Process... OK
Fw. Size    : 1.94 MB
Determining EFS Region Size... OK
Erasing EFS Region... OK
Writing EFS region... OK
Port Closed.
Operation Finished.
Time Taken: 03:35
Module Ver. [1.0]
Log Saved to Logs\151008_164900.log
Old 10-08-2015, 13:26   #44 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
Zte s100 flash ok
Baud Rate : 921600
Device : ZTE S100
Operation : Flash
Opening Port... OK
Compile : Aug 10 2009 18:56:15
Hw Ver. : TM_S100_
ESN : A7B404AA
Build : QSC6010-SCNRZ-TM_S100_RBTL35NV1.0.0B04
Read Not Supported
Soft Ver.
Detected : S100
User Code : 0000
Initializing Bootloader... OK
Flash Chip : SAMSUNG K5L6331CA
Chip Size : 8 MB
Firmware : 100 unlock dump.bin
Fw. Size : 8 MB
Port Closed.
Operation Finished
Time Taken: 03:33
Module Ver. [1.1]
Old 10-08-2015, 13:27   #45 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
Zte s183 1 click unlock ok
Port : COM148 : ZTE CDMA Handset Diagnostics Interface (COM148)
Baud Rate : 921600
Device : ZTE S183
Operation : Unlock
Opening Port... OK
Compile : Nov 27 2013 15:03:05
Hw Ver. : RIC_S183
ESN : 80AXXXXX
MEID : A000003XXXXX
Build : RIC_S183_RBTL21FV1.0.0B07
Soft Ver. : RIC_S183_NL_RBTL21FV1.0.0B09
Detected : S183
User Code : 0000
Chip Size : 16 MB
Port Closed.
Operation Finished.
Time Taken: 00:15
Module Ver. [1.1]
Page generated in 0.26713 seconds with 9 queries
