05-24-2016, 15:06 | #481 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | Port : COM123 : HS-USB Wireless Diagnostics 3004 (COM123) Baud Rate : 921600 Device : Haier C381 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Nov 07 2014 15:20:18 Release : Apr 29 2011 05:00:00 Hw Ver. : S001 ESN : 808F3217 MEID : A1000045AAAF72 BUILD : HC-C381_R-S001 Setting Download Mode... OK Reconnecting Phone... OK Preparing Phone.. OK Sending Bootloader... OK Executing Bootloader... OK Syncing Phone... OK Initializing Flash Chip... OK Flash Chip : SAMSUNG K5N1229ACD Chip Size : 16 MB Patching Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:13 |
The Following User Says Thank You to sunny_luthras99 For This Useful Post: |
05-24-2016, 15:15 | #482 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Samsung SM-T231 Pin lock Remove DONE W/o Data Lost.... Port : Android Debugging/Recovery Baud Rate : Not Applicable Device : Samsung Universal Operation : Remove Locks Searching for Device in Recovery... Found Model : degaswifi Version : 4.4.4 Hardware : pxa1088 Platform : mrvl CPU : armeabi-v7a Serial No. : 30049daaf1cdc100 Preparing Data.... Done Removing Locks... Done Rebooting Phone... Done Operation Finished. Elapsed Time: 00:15 [Module Ver. 2.2] |
The Following User Says Thank You to -Mosin- For This Useful Post: |
05-24-2016, 19:22 | #485 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Ireland Age: 50
Member: 2038882 Status: Offline Sonork: 100.1663803 Thanks Meter: 67 | Xperia e2003 rooting method using kingroot Port : ADB Interface Baud Rate : Not Applicable Device : Android Operation : Read Info Searching for Device... Found Model : E2003 Version : 4.4.4 Hardware : mt6752 Baseband : MOLY.LR9.W1423.MD.LWTG.MPV13.TC9.SP.V1.P30-2.40.J.2.029, 2015/09/07 16:49 CPU : armeabi-v7a SIM Card : ABSENT Type : GSM IMEI(1) : 359603065060749 Root : Not Rooted Operation Finished. Elapsed Time: 00:12 [Module Ver. 2.2] after root Port : ADB Interface Baud Rate : Not Applicable Device : Android Operation : Read Info Searching for Device... Found Model : E2003 Version : 4.4.4 Hardware : mt6752 Baseband : MOLY.LR9.W1423.MD.LWTG.MPV13.TC9.SP.V1.P30-2.40.J.2.029, 2015/09/07 16:49 CPU : armeabi-v7a SIM Card : NOT_READY Type : GSM IMEI(1) : null Root : Rooted Operation Finished. Elapsed Time: 00:11 [Module Ver. 2.2] Port : ADB Interface Baud Rate : Not Applicable Device : Android MTK Operation : IMEI Repair Searching for Device... Found Model : E2003 Version : 4.4.4 Hardware : mt6752 Baseband : MOLY.LR9.W1423.MD.LWTG.MPV13.TC9.SP.V1.P30-2.40.J.2.029, 2015/09/07 16:49 SIM Card : NOT_READY CPU : armeabi-v7a Type : GSM IMEI(1) : null Checking Root Access... OK Root : Rooted Reading Data from Phone... Done Backup : NVRAM_E2003_mt6752_4.4.4_null_160524_182510.Bak IMEI To Repair - IMEI[1] : 359603065060749 Preparing Data.... Done Updating IMEI Information... Done Rebooting Phone... Done Operation Finished. Elapsed Time: 00:38 [Module Ver. 2.2] |
05-25-2016, 07:44 | #487 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g361h unlock done Port : COM46 : SAMSUNG Mobile USB Modem #5 Baud Rate : 115200 Device : Samsung G361H Operation : Unlock Opening Port... OK Reading Information... OK Model : SM-G361H IMEI : 351722073718--- Version Info : G361HXXU0APD1 : G361HOJV0APD1 : G361HXXU0APB2 : G361HXXU0APD1 Preparing Phone... OK Reading Lock Status... OK Status : SIM Locked* Phone May Be Hard Locked, Unlock May Not Work Reading Lock Levels.. OK Lock Level [0] : Locked Lock Level [1] : Unlocked Lock Level [2] : Unlocked Lock Level [3] : Unlocked Lock Level [4] : Unlocked Resetting Lock Codes... Done UnFreeze : 00712621 Level[1] : 83626762[Locked] Level[2] : 00000000[Unlocked] Level[3] : 00000000[Unlocked] Level[4] : 00000000[Unlocked] Level[5] : 00000000[Unlocked] Port Closed. Operation Finished. Elapsed Time: 00:16 [Module Ver. 2.2] Log Saved to Logs\160525_111027.log |
The Following User Says Thank You to rehmani For This Useful Post: |
05-25-2016, 09:32 | #488 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | b229 unlock done Port : COM18 : Z3X BOX Serial Port (COM18) Baud Rate : 9600 [Auto] Device : Samsung B229 Operation : Unlock Opening Port... OK Setting Test Mode... OK Step 1... OK Step 2... OK Step 3... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:08 Module Ver. [1.4] |
05-25-2016, 10:37 | #489 (permalink) |
Member: 2038882 Status: Offline Sonork: 100.1663803 Thanks Meter: 67 | Huawei Ascend G7 unlocked by UMT Operation : Huawei Code Calculator Calculating Codes... IMEI : 864324025817619 Algo v1 : 65738823 Algo v2 : 67100345 Algo v3 : 10351147 Flash Code : 61353352 Operation Finished. Elapsed Time: 00:01 [Module Ver. 2.2] That's amazing tool...!!!! |
05-25-2016, 11:07 | #490 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zte s100 repair security and unlock done Code: Port : COM54 : ZTE CDMA Handset Diagnostics Interface (COM54) Baud Rate : 921600 Device : S100 Operation : Write MEID Opening Port... OK Reading Information... Compile : Aug 17 2009 12:59:11 Release : Oct 24 2006 13:00:00 Hw Ver. : MTS_S100 ESN : 00000000 MEID : 00000000000000 Unlocking Security... OK Build : QSC6010-SCNRZ-MTS_S100_RBTL40NV1.0.0B04 Software : ----- Detected : S100 User Code : 0000 Writing MEID A000001F803---... OK New ESN : 8035C--- New MEID : A000001F803--- Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.5] Log Saved to Logs\160525_153207.log Code: Port : COM54 : ZTE CDMA Handset Diagnostics Interface (COM54) Baud Rate : 921600 Device : ZTE S100 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Aug 17 2009 12:59:11 Release : Oct 24 2006 13:00:00 Hw Ver. : MTS_S100 ESN : 8035C5-- MEID : A000001F803--- Unlocking Security... OK Build : QSC6010-SCNRZ-MTS_S100_RBTL40NV1.0.0B04 Soft Ver. : ----- Detected : S100 User Code : 0000 Checking if Supported for Unlock... OK Switching to Offline... OK Sending Default SPC... OK Unlocking Phone... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:02 Module Ver. [1.5] Log Saved to Logs\160525_153214.log |
05-25-2016, 11:39 | #491 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: Algeria is a North African Age: 35
Member: 1629321 Status: Offline Thanks Meter: 823 | s5301 Flash Done Ultimate Multi Tool Box Quote:
05-25-2016, 13:26 | #492 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 35
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Code: Port : ADB Interface Baud Rate : Not Applicable Device : Samsung Operation : All Sprint Unlock Searching for Device... Found Model : SM-T217S Version : 4.4.2 Hardware : qcom Baseband : T217SVPUBOH1 SIM Card : CARD_IO_ERROR CPU : armeabi-v7a Type : CDMA MEID(1) : 99000440234865 Executing All Sprint Unlock... Done Please Reboot Phone. Operation Finished. Elapsed Time: 00:42 [Module Ver. 2.2] Log Saved to Logs\160525_172116.log |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
05-25-2016, 14:14 | #494 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung s7262 flash done Device: GT-I8190 Operation: Flash Firmware Port: COM17 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8810 [HiSpeed] Sending Partition [SBL1]... Done Sending Partition [KERNEL]... Done Sending Partition [RECOVERY]... Done Sending Partition [modem]... Done Sending Partition [CSC]... Done Sending Partition [system]... Done Sending Partition [HIDDEN]... Done Sending Partition [PARAM]... Done Closing Session... Done Operation Finished. Elapsed Time: 09:04 |
The Following 2 Users Say Thank You to rehmani For This Useful Post: |
05-25-2016, 16:06 | #495 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | C381 UNLOCK DONE Port : COM38 : HS-USB Wireless Diagnostics 3004 (COM38) Baud Rate : 921600 Device : Haier C381 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Nov 07 2014 15:20:18 Release : Apr 29 2011 05:00:00 Hw Ver. : S001 ESN : 80FCF8A2 MEID : A1000045AA6895 BUILD : HC-C381_R-S001 Setting Download Mode... OK Reconnecting Phone... OK Preparing Phone.. OK Sending Bootloader... OK Executing Bootloader... OK Syncing Phone... OK Initializing Flash Chip... OK Flash Chip : SAMSUNG K5N1229ACD Chip Size : 16 MB Patching Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:14 Module Ver. [1.4] Log Saved to Logs\160525_203519.log |
