11-09-2017, 15:31 | #3601 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | Xt1609 frp Code: Port : USB Coonection Baud Rate : Not Applicable Device : Motorola Operation : Enable ADB Searching for device... Found Connecting to device... OK Model : XT1609 Bootloader : 0x810A Baseband : M8916_20250106.08.05.23.01R HARPIA_NA_CUST Build : Blur_Version.24.216.17.harpia_vzw.verizon.en.US Android : 6.0.1 Enabling ADB... OK Now Turn Off device, and put in Factory Mode again. When phone is completely ON, accept ADB Authrization on phone. Now use Reset FRP button. Operation Finished. Elapsed Time: 00:01 [Module Ver. 4.2] Code: Port : ADB Interface Baud Rate : Not Applicable Device : Motorola Operation : Reset FRP Searching for Device... Found Model : XT1609 Version : 6.0.1 Hardware : qcom Baseband : M8916_20250106.08.05.23.01R HARPIA_NA_CUST SIM Card : ABSENT CPU : armeabi-v7a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:07 [Module Ver. 4.2] |
The Following User Says Thank You to Ahsaan* For This Useful Post: |
11-09-2017, 17:02 | #3602 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Motorola Xt1585 1 July 2017 Frp Done With UMT Code: Port : Fastboot Inteface Baud Rate : Not Applicable Device : Motorola Operation : New FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1585 Boot Ver. : moto-msm8994-A8.63 Baseband : M8994_13206.84.03.45R KINZIE_VZW_CUST Software : Blur_Version.25.216.2.kinzie_verizon.verizon.en.US IMEI : 990005746049767 CPU : MSM8994 RAM : 3072MB Samsung S16 SDRAM DIE=6Gb M5=x1 M6=x3 M7=x0 ram[1]: M8=x4 Done EMMC : 32GB Toshiba REV=07 PRV=00 TYPE=57 PNM=032G72 Setting Factory Mode... OK Searching Network Interface... Found Connecting to device... OK Model : XT1585 Bootloader : 0xA863 Baseband : M8994_13206.84.03.45R KINZIE_VZW_CUST Build : Blur_Version.25.216.2.kinzie_verizon.verizon.en.US Android : 7.0 Searching Network Interface... Found Connecting to device... OK Model : XT1585 Bootloader : 0xA863 Baseband : M8994_13206.84.03.45R KINZIE_VZW_CUST Build : Blur_Version.25.216.2.kinzie_verizon.verizon.en.US Android : 7.0 Resetting FRP... OK Searching for Device in FastBoot Mode... OK Removing Factory Mode... OK Operation Finished. Elapsed Time: 04:30 [Module Ver. 4.3] Log Saved to Logs\171109_204456.log |
11-09-2017, 17:03 | #3603 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Motorola Xt1254 Frp Reset Code: Port : USB Coonection Baud Rate : Not Applicable Device : Motorola Operation : Enable ADB Searching for device... Found Connecting to device... OK Model : XT1254 Bootloader : 0x7096 Baseband : MDM9625_41.51.07.22.04R QUARK_CUST Build : Blur_Version.24.91.5.quark_verizon.verizon.en.US Android : 6.0.1 Enabling ADB... OK Now Turn Off device, and put in Factory Mode again. When phone is completely ON, accept ADB Authrization on phone. Now use Reset FRP button. Operation Finished. Elapsed Time: 00:01 [Module Ver. 4.2] Log Saved to Logs\171021_213926.log Port : ADB Interface Baud Rate : Not Applicable Device : Motorola Operation : Reset FRP Searching for Device... Found Model : XT1254 Version : 6.0.1 Hardware : qcom Baseband : MDM9625_41.51.07.22.04R QUARK_CUST SIM Card : READY CPU : armeabi-v7a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:11 [Module Ver. 4.2] Log Saved to Logs\171021_214237.log |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
11-10-2017, 08:11 | #3604 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | ls-5005 frp done Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : HS-USB Diagnostics 9008 (COM74) Driver Info : Mobile, qcusbser.sys, 2.1.0.3 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8916.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8916, eMMC, 16 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LYF LS-5005 [msm8916] Software : TBT575522_1002_V020025, TBT575522_1002_V020025 [Fri Jan 6 16:30:34 CST 2017] Android Ver. : 5.1.1 Resetting FRP Lock......Done Operation Finished. Module Ver. 1.2 |
The Following User Says Thank You to djj007 For This Useful Post: |
11-10-2017, 09:25 | #3605 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 697211 Status: Offline Thanks Meter: 44 | samsung j710f frp remove just one click enable adb via calculator method and select in method frp reset adb mode no need flash combination no need to flash nothing just do like this |
11-10-2017, 10:39 | #3607 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Lenovo A2020a40 PIN Lock removed without data loss Code: Operation : Reset Locks Checking for existing devices...Found Port : COM131 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Firehose Loader...Done Sending Loader [8909_012.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8909, eMMC, 16 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LENOVO Lenovo A2020a40 [msm8909] Software : A2020a40_S189_161109_ROW, A2020a40_USR_S189_1611091320_Q8909_ROW [Wed Nov 9 13:22:19 CST 2016] Android Ver. : 5.1.1 Resetting Google Locks...Done Operation Finished. |
The Following 3 Users Say Thank You to EjazATF For This Useful Post: |
11-10-2017, 13:11 | #3608 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | MI NOTE 4 2016100 MI Account Reset Done Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM32) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.3 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8953, eMMC, 32 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : MMB29M, V8.2.10.0.MCFMIDL [Fri Jun 2 20:53:58 WIB 2017] Android Ver. : 6.0.1 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. Operation Finished. Module Ver. 1.2 |
The Following User Says Thank You to ssony For This Useful Post: |
11-10-2017, 16:11 | #3610 (permalink) | |
Freak Poster Join Date: Mar 2010 Location: In Search of free BB5 rpl
Member: 1248595 Status: Offline Sonork: 100.1607313 Thanks Meter: 99 | Lenovo A6000 Hang on log Solve by flashing with UMT Hello, Quote:
The Following 2 Users Say Thank You to MTK CHIP For This Useful Post: |
11-11-2017, 08:15 | #3611 (permalink) |
Banned Join Date: Mar 2017 Location: F.S.D Age: 30
Member: 2691025 Status: Offline Thanks Meter: 234 | Samsung J111F FRP Remove Just 1 Click By UMT KEY Samsung J111F FRP Remove Just 1 Click By UMT KEY Real Multi King Umt BR MIRZA ASIM |
The Following User Says Thank You to Danishmirza For This Useful Post: |
11-11-2017, 09:23 | #3612 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | VIVO V7+ Pattern + FRP Removed Success Code: Operation : Format FS Checking for existing devices...Found Port : COM131 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4FFF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_003.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8953, eMMC, 64 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1716 [msm8953] Software : N2G47H release-keys, eng.compil.20171020.195147 [Fri Oct 20 19:51:47 CST 2017] Android Ver. : 7.1.2 Preparing Data...Done Formatting Userdata...Done Finalizing...Done Operation Finished. Module Ver. 1.2 Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM131) Driver Info : Qualcomm Incorporated, qcusbser.sys, 5.1.1.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4FFF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_003.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8953, eMMC, 64 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1716 [msm8953] Software : N2G47H release-keys, eng.compil.20171020.195147 [Fri Oct 20 19:51:47 CST 2017] Android Ver. : 7.1.2 Resetting FRP Lock......Done Operation Finished. |
The Following 4 Users Say Thank You to EjazATF For This Useful Post: |
11-11-2017, 10:13 | #3613 (permalink) |
Junior Member Join Date: Feb 2013 Location: mumbai india Age: 33
Member: 1890019 Status: Offline Thanks Meter: 21 | Vivo Y55s 1610 phone Unlock patch sept 2017 done with UMT QcFire V1.2 Vivo Y55s 1610 phone Unlock Vivo Y55s 1610 Pin Unlock Vivo Y55s 1610 Pattern Unlock press volume + & volume - together for Qualcomm mode here is logs Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8917_001.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8917, eMMC, 16 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1610 [msm8937] Software : MMB29M release-keys, eng.compiler.20170908.173221 [Fri Sep 8 17:36:55 CST 2017] Android Ver. : 6.0.1 Preparing Data...Done Formatting Userdata...Done Finalizing...Done Operation Finished. Module Ver. 1.2 |
11-11-2017, 10:44 | #3614 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Samsung S3 - Format phone AT mode success Code: Port : COM259 : SAMSUNG Mobile USB Modem #75 Baud Rate : 115200 Device : Samsung 01F Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SCH-I535 IMEI : 990xxxxxx Version Info : SCH-I535USMD03 : I535VZWBMD3 : I535VRBLMD3 : I535VRBMD3 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:09 [Module Ver. 4.0] Log Saved to Logs\171111_143833.log |
11-12-2017, 07:03 | #3615 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | redmi note 4 account disable by umt Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM74) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8953, eMMC, 64 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-mido-build-20170915223957, V8.5.8.0.NCFMIED [Fri Sep 15 22:39:55 WIB 2017] Android Ver. : 7.0 Reading Data...Done Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. Module Ver. 1.2 |
