04-17-2024, 17:29 | #12121 (permalink) |
Freak Poster Join Date: Mar 2020 Location: bolivia
Member: 2951556 Status: Offline Thanks Meter: 250 | frp tecno pova 2 (le7) done! Brand/Model : *Auto* / *Auto Detect* Operation : Reset FRP Waiting for Device...Found Port : MediaTek PreLoader USB VCOM (Android) (COM19) Device Path : \\?\usb#vid_0e8d&pid_2000#5&237d5c64&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.2.0.0 [usb2ser.sys] Mode : PRELOADER Hw ID : MT6768 [0707] Helio P65/G85 k68v1 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:False] [DAA:True] MEID : 470C616F4B93A30EB5A157B6DEB3BC43 SoC ID[0] : 6722DAC43701CD9936BFA5AB4A9502A7 SoC ID[1] : CB48B3296D554054D356B7D035C21E0D Sending 1st DA..OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : preloader Speed : HIGH-SPEED Reading RAM Configuration...OK Running PL_EXPLOIT [1]...Done Sending 2nd DA...OK Int. RAM : 0x0000000000070000 [448,00 KB] Ext. RAM : 0x0000000100000000 [4,00 GB] Flash ID : 3V6CAB CID : 150100335636434142023E5ECA678845 BOOT1 : 0x0000000000400000 [4,00 MB] BOOT2 : 0x0000000000400000 [4,00 MB] RPMB : 0x0000000001000000 [16,00 MB] USERAREA : 0x0000001D1EC00000 [116,48 GB] PRE EOL : NORMAL Life. Est.A : 0%-10% LIFE TIME USED Life. Est.B : 0%-10% LIFE TIME USED Reading Partition Table...OK And. Ver. : 11 Build Dt. : Tue Jun 20 17:41:40 CST 2023 Display ID : TECNO-R-64-230620V465 Ver. Inc. : 230620V778 Locale : en-US Patch : 2023-05-05 Bootloader : LOCKED Resetting FRP...OK Operation Finished. [UltimateMTK2 v1.2] Log Saved : 20240417_122334.log |
The Following 2 Users Say Thank You to RMESystems For This Useful Post: |
04-17-2024, 18:38 | #12122 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | FRP redmi note 11 done! Operation : Reset FRP (Sideload) Searching for phone in sideload mode...Found Device Id : spes_global Version : V13.0.15.0.RGCMIXM Code Base : 11 Serial : 0x539576b7 Ext Info : GB, en, F, 2, 2 Model : spes Reading Partition Table...[94] OK Resetting FRP...Done Operation Finished. QcFire Ver. 9.5 |
The Following 3 Users Say Thank You to RMESystems For This Useful Post: |
04-18-2024, 10:30 | #12123 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,710 | Redmi Note 8 Mi account bypass done Code: Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SDM665, EMMC, 64 GB LU Count : 4 [0x0747C000] [0x00002000] [0x00002000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : , V12.0.6.0.QCOMIXM [Sat Jul 24 13:53:24 WIB 2021] Android Ver. : 10 Patch Level : 2021-07-01 Reading Data[1]...Done Patching Data...Done Writing Data...Done Reading Data[2]...Done Patching Data...Done Account : 6********* Phone : +*********** Display ID : ************ Writing Data...Done Operation Finished. QcFire Ver. 9.4 |
The Following User Says Thank You to bk.gsm For This Useful Post: |
04-18-2024, 14:09 | #12124 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,710 | Redmi Note 7 frp done Code: Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Auth Enabled Device! You may need Mi Auth Account to service! Skipping Auth...OK Detecting Storage Type...OK Hardware : MSM8996, EMMC, 64 GB LU Count : 4 [0x0747C000] [0x00002000] [0x00002000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : QKQ1.190910.002 V12.5.1.0.QFGEUXM, V12.5.1.0.QFGEUXM [Fri Sep 3 00:28:00 WIB 2021] Android Ver. : 10 Patch Level : 2021-08-01 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 9.4 |
04-19-2024, 07:12 | #12125 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,425 | Inifnix X6525 Frp Job: Remove FRP SELECTED: Tiger T606 Ver2 ACTION: Erase FRP Error open port!! Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key and insert usb cable. For some phones need to Long press "VOL -"+ "VOL +" key and insert usb cable. Detected: SPRD U2S Diag (COM34) Sending payload, keep boot key untill loader start. Exploiting phone..... Sending preloader 1 Sending preloader 2 Sending FDL 1..... Sending FDL 2..... New flash metod detected. [5f] 7435C1 [5e] 2340716 UID: M3G116_16_14_22 FileSystem: UFS Read partition info is supported by loader. CPU NAME: T606 Removing frp, wait... [1]FRP: persist Done. [can take 0-10 sec]Wait untill phone restart. Log saved: C:\UMT\unisoc_module\spreadtrum_module_backup_fold er\Saved_Logs\_erase_frp_5.txt Total Time: 00:00:37 Done. |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
04-19-2024, 07:21 | #12126 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,425 | Inifnix X6525 FOrmat Job: Safe Format Userdata SELECTED: Tiger T606 Ver2 ACTION: Wipe Userdata(misc) Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key and insert usb cable. For some phones need to Long press "VOL -"+ "VOL +" key and insert usb cable. Detected: SPRD U2S Diag (COM34) Sending payload, keep boot key untill loader start. Exploiting phone..... Sending preloader 1 Sending preloader 2 Sending FDL 1..... Sending FDL 2..... New flash metod detected. [5f] 7435C1 [5e] 2340716 UID: M3G116_16_14_22 FileSystem: UFS Read partition info is supported by loader. [misc]Formating userdata, wait... [can take 0-10 sec]Wait untill phone restart. Log saved: C:\UMT\unisoc_module\spreadtrum_module_backup_fold er\Saved_Logs\_format_userdata_misc_1.txt Total Time: 00:00:32 Done. |
04-19-2024, 10:12 | #12127 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,710 | Oppo A16 safe format done Code: Brand/Model : *Auto* / *Auto Detect* Operation : Safe Format (Oppo) Waiting for Device...Found Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM41) Device Path : \\?\usb#vid_22d9&pid_0006#6&1f73d83a&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.0.1504.0 [usb2ser.sys] Mode : PRELOADER Force Enter BROM...OK Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:False] [DAA:True] MEID : 4AAEB015BF5C02A20100FAC24749B41A SoC ID[0] : E616E13E80A3DB08132A483CF4817E3A SoC ID[1] : F59467D60AAD011747A8308D508B0A82 Running Exploit...Done Downloading Preloader...OK Saved as : preloader_oppo6765.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using Internal DA! DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 90014A68433861503E030048B4D6A83D [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x0000000000038000 [224.00 KB] Ext. RAM : 0x0000000100000000 [4.00 GB] Flash ID : hC8aP> CID : 90014A68433861503E030048B4D6A83D BOOT1 : 0x0000000000400000 [4.00 MB] BOOT2 : 0x0000000000400000 [4.00 MB] RPMB : 0x0000000001000000 [16.00 MB] USERAREA : 0x0000000E8F800000 [58.24 GB] PRE EOL : NORMAL Life. Est.A : UNDEFINED Life. Est.B : 0%-10% LIFE TIME USED Reading Partition Table...OK And. Ver. : 11 Build Dt. : Sun Oct 15 22:16:34 CST 2023 Display ID : RP1A.200720.011 release-keys Ver. Inc. : 1697378066956 Locale : en-US Patch : 2023-10-05 Bootloader : LOCKED Executing Safe Format (Oppo)...Done If phone stuck on recovery, try [Fix Recovery]. Operation Finished. [UltimateMTK2 v1.2] Code: Brand/Model : *Auto* / *Auto Detect* Operation : Reset FRP Waiting for Device...Found Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM41) Device Path : \\?\usb#vid_22d9&pid_0006#6&1f73d83a&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.0.1504.0 [usb2ser.sys] Mode : PRELOADER Force Enter BROM...OK Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:False] [DAA:True] MEID : 4AAEB015BF5C02A20100FAC24749B41A SoC ID[0] : E616E13E80A3DB08132A483CF4817E3A SoC ID[1] : F59467D60AAD011747A8308D508B0A82 Running Exploit...Done Downloading Preloader...OK Saved as : preloader_oppo6765.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using Internal DA! DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 90014A68433861503E030048B4D6A83D [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x0000000000038000 [224.00 KB] Ext. RAM : 0x0000000100000000 [4.00 GB] Flash ID : hC8aP> CID : 90014A68433861503E030048B4D6A83D BOOT1 : 0x0000000000400000 [4.00 MB] BOOT2 : 0x0000000000400000 [4.00 MB] RPMB : 0x0000000001000000 [16.00 MB] USERAREA : 0x0000000E8F800000 [58.24 GB] PRE EOL : NORMAL Life. Est.A : UNDEFINED Life. Est.B : 0%-10% LIFE TIME USED Reading Partition Table...OK And. Ver. : 11 Build Dt. : Sun Oct 15 22:16:34 CST 2023 Display ID : RP1A.200720.011 release-keys Ver. Inc. : 1697378066956 Locale : en-US Patch : 2023-10-05 Bootloader : LOCKED Resetting FRP...OK Operation Finished. [UltimateMTK2 v1.2] |
04-19-2024, 16:56 | #12128 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,710 | Huawei mediatab t5 frp done Code: Operation : Reset FRP Searching for COM1.0 Device...Found! COM82 : HUAWEI USB COM 1.0 (COM82) Opening Port...OK Platform : Kirin_659 Sending Loader...[1]..[2]..Done Searching for Device in FastBoot Mode...OK Model : AGS2-W09 Build : AGS2-W09 8.0.0.371(OCEC432) BL Status : Unlocked User Status : Locked Serial : V4Q********** IMEI1 : V4Q********** IMEI2 : Unknown MEID : Unknown Resetting FRP...Done Device will reboot and wipe. Operation Finished. UltimateHST v0.2 |
04-22-2024, 00:35 | #12129 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | Model : Samsung Operation : FRP Bypass [2023 New Method] Searching for Phone...Found Hw ID : USB\VID_04E8&PID_6860&REV_0400&Modem Port: : COM38 : SAMSUNG Mobile USB Modem #23 Checking for Device...Found [Normal Mode] Reading Phone Information...OK Model: : SM-J610G IMEI: : 351xxxxxxxxxxxx Software: : J610GUBS7CVJ9/J610GOWO7CVJ2/J610GUBS7CVJ1/J610GUBS7CVJ9 Product : BVO Enabling ADB (2023 New Method)...OK Searching for Device...Found Brand : samsung Model : SM-J610G Product : j6primelte Device : j6primelte Andriod Ver. : 10 Patch Level : 2022-06-01 PDA : J610GUBS7CVJ9 Bootloader : J610GUBS7CVJ9 Build ID : QP1A.190711.020.J610GUBS7CVJ9 Build Date : Sat Oct 22 08:02:25 KST 2022 Checking Root Status...Done Root : No Root Resetting FRP Lock...Done HINT : This method work for QC/Exynos model with Security Patch < June 2023 Elapsed Time 34:03 [UltimateSams v0.7] Saved to Logs\240421_193403.log |
04-22-2024, 22:58 | #12130 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | Device : Xiaomi Redmi Note 8 Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SDM665, EMMC, 64 GB LU Count : 4 [0x0747C000] [0x00002000] [0x00002000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : , V12.0.6.0.QCOMIXM [Sat Jul 24 13:53:24 WIB 2021] Android Ver. : 10 Patch Level : 2021-07-01 Reading Data[1]...Done. Patching Data...Done Writing Data...Done Reading Data[2]...Done Patching Data...Done Account : 6361185997 Phone : +59177****40 Display ID : 4SBV-UXCJ-EVHX-IAR Writing Data...Done Operation Finished. QcFire Ver. 9.5 |
04-22-2024, 23:54 | #12131 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | frp tecno spark 6 go done! Brand/Model : *Auto* / *Auto Detect* Operation : Reset FRP Waiting for Device...Found Port : MediaTek USB Port (COM16) Device Path : \\?\usb#vid_0e8d&pid_0003#5&237d5c64&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.2.0.0 [usb2ser.sys] Mode : BROM Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:False] [DAA:True] MEID : D6FEA6F56CB278CA8CADD50F4DC1CC74 SoC ID[0] : EEC88556AF557205AF855518DE4C6245 SoC ID[1] : 0200647BAC772923AB86E1F2AE8A10E9 Running Exploit...Done Downloading Preloader...OK Saved as : preloader_ke5k_h6122.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using Internal DA! DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 90014A6843396150330100A6E16778C7 [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x0000000000038000 [224,00 KB] Ext. RAM : 0x0000000100000000 [4,00 GB] Flash ID : hC9aP3 CID : 90014A6843396150330100A6E16778C7 BOOT1 : 0x0000000000400000 [4,00 MB] BOOT2 : 0x0000000000400000 [4,00 MB] RPMB : 0x0000000001000000 [16,00 MB] USERAREA : 0x0000000E8F800000 [58,24 GB] PRE EOL : NORMAL Life. Est.A : UNDEFINED Life. Est.B : 0%-10% LIFE TIME USED Reading Partition Table...OK And. Ver. : 10 Build Dt. : Mon Oct 10 17:06:58 CST 2022 Display ID : KE5k-H6122CD-Q-OP-221010V241 Ver. Inc. : CD-OP-221010V241 Locale : en-US Patch : 2022-10-05 Bootloader : LOCKED Resetting FRP...OK Operation Finished. [UltimateMTK2 v1.2] Log Saved : 20240422_185219.log |
04-23-2024, 00:31 | #12132 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | FRP TECNO SPARK 6 GO Done! Brand/Model : *Auto* / *Auto Detect* Operation : Reset FRP Waiting for Device...Found Port : MediaTek USB Port (COM16) Device Path : \\?\usb#vid_0e8d&pid_0003#5&237d5c64&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.2.0.0 [usb2ser.sys] Mode : BROM Hw ID : MT6761 [0717] Helio A20/P22/A22/A25/G25 Details : 8A00,CA01,0200 Sec. Config : [SBA:True] [SLA:False] [DAA:True] MEID : E300C547D8541B77A1FD3129563FD8C2 SoC ID[0] : 5A61E4108E0BE515956F3A9B1606FAB7 SoC ID[1] : 9EF209FD384F720B27075A78AEA2C4F1 Running Exploit...Done Downloading Preloader...OK Saved as : preloader_ke5_h6123go.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using Internal DA! DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 1501005158363341420397B8E4A5281F [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x0000000000039000 [228,00 KB] Ext. RAM : 0x0000000080000000 [2,00 GB] Flash ID : QX63AB CID : 1501005158363341420397B8E4A5281F BOOT1 : 0x0000000000400000 [4,00 MB] BOOT2 : 0x0000000000400000 [4,00 MB] RPMB : 0x0000000000400000 [4,00 MB] USERAREA : 0x0000000747C00000 [29,12 GB] PRE EOL : NORMAL Life. Est.A : 10%-20% LIFE TIME USED Life. Est.B : 10%-20% LIFE TIME USED Reading Partition Table...OK And. Ver. : 10 Build Dt. : Mon Aug 22 20:44:38 CST 2022 Display ID : KE5-H6123ABC-QGo-GL-220822V553 Ver. Inc. : ABC-GL-220822V553 Locale : en-US Patch : 2022-08-01 Bootloader : LOCKED Resetting FRP...OK Operation Finished. [UltimateMTK2 v1.2] Log Saved : 20240422_192838.log |
04-24-2024, 21:05 | #12133 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | frp tecno spark 6 (ke7) done Brand/Model : *Auto* / *Auto Detect* Operation : Reset FRP Waiting for Device...Found Port : MediaTek USB Port (COM16) Device Path : \\?\usb#vid_0e8d&pid_0003#5&237d5c64&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.2.0.0 [usb2ser.sys] Mode : BROM Hw ID : MT6768 [0707] Helio P65/G85 k68v1 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:False] [DAA:True] MEID : 9DE8927CFE13FB0DC1EC15ACAF945B9D SoC ID[0] : B62DEAEB7056BD1BE0D6B2E17891A75F SoC ID[1] : A0A082471AD13765276081BF10D525B0 Running Exploit...Done Downloading Preloader...OK Saved as : preloader_ke7_h693.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using Internal DA! DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 13014E47314A395339100B74500FA727 [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x0000000000070000 [448,00 KB] Ext. RAM : 0x0000000100000000 [4,00 GB] Flash ID : G1J9S9 CID : 13014E47314A395339100B74500FA727 BOOT1 : 0x0000000000400000 [4,00 MB] BOOT2 : 0x0000000000400000 [4,00 MB] RPMB : 0x0000000001000000 [16,00 MB] USERAREA : 0x0000001D1F000000 [116,48 GB] PRE EOL : NORMAL Life. Est.A : 10%-20% LIFE TIME USED Life. Est.B : 0%-10% LIFE TIME USED Reading Partition Table...OK Manuf. : TECNO MOBILE LIMITED Ven. Model : TECNO KE7 Platform : mt6768 Ven. Date : Fri Jul 29 23:40:35 CST 2022 Ver. Inc. : 220729V398 Bootloader : LOCKED Resetting FRP...OK Operation Finished. [UltimateMTK2 v1.2] Log Saved : 20240424_160244.log |
04-24-2024, 23:38 | #12134 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | FRP Honor X8b (LLY-LX3) done! Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1801B00 [SM6225] 0300A401 OPK_DATA : 489DD7DE2DB26F5DBD1CDF921F54B949A93388CEAEE92B0E80 5882C469B20EC3 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6225_004]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SM6225, UFS, 256 GB LU Count : 6 [0x03B51800] [0x00000800] [0x00000800] [0x00000800] [0x00040800] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK [Sign] Build : Int. Build : Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 9.5 |
The Following User Says Thank You to RMESystems For This Useful Post: |
04-25-2024, 16:02 | #12135 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 250 | frp tecno spark 6 go (ke5) done! Brand/Model : *Auto* / *Auto Detect* Operation : Reset FRP Waiting for Device...Found Port : MediaTek USB Port (COM16) Device Path : \\?\usb#vid_0e8d&pid_0003#5&237d5c64&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.2.0.0 [usb2ser.sys] Mode : BROM Hw ID : MT6761 [0717] Helio A20/P22/A22/A25/G25 Details : 8A00,CA01,0200 Sec. Config : [SBA:True] [SLA:False] [DAA:True] MEID : 2987797CEE9DDAC2406A316290C10117 SoC ID[0] : C929C97895DADF6F271AC2CDA9AEADC8 SoC ID[1] : C675AE021806B00F3D849D090CD550BC Running Exploit...Done Downloading Preloader...OK Saved as : preloader_ke5_h6123go.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using Internal DA! DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 15010051583633414203C322BCC6C789 [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x0000000000039000 [228,00 KB] Ext. RAM : 0x0000000080000000 [2,00 GB] Flash ID : QX63AB CID : 15010051583633414203C322BCC6C789 BOOT1 : 0x0000000000400000 [4,00 MB] BOOT2 : 0x0000000000400000 [4,00 MB] RPMB : 0x0000000000400000 [4,00 MB] USERAREA : 0x0000000747C00000 [29,12 GB] PRE EOL : NORMAL Life. Est.A : 10%-20% LIFE TIME USED Life. Est.B : 10%-20% LIFE TIME USED Reading Partition Table...OK And. Ver. : 10 Build Dt. : Wed Feb 16 22:53:42 CST 2022 Display ID : KE5-H6123ABC-QGo-GL-220216V490 Ver. Inc. : ABC-GL-220216V490 Locale : en-US Patch : 2022-02-05 Bootloader : LOCKED Resetting FRP...OK Operation Finished. [UltimateMTK2 v1.2] Log Saved : 20240425_110000.log |
