11-16-2018, 07:15 | #5581 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Android HS-USB QDLoader 9008 (COM390) Driver Info : TCL, qcusbser.sys, 6.0.0.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1723 Software : OPM1.171019.011 release-keys, eng.compil.20180828.181545 [Tue Aug 28 18:15:45 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-08-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
The Following User Says Thank You to dky_tel For This Useful Post: |
11-16-2018, 09:32 | #5582 (permalink) |
No Life Poster Join Date: Dec 2016 Location: .
Member: 2659717 Status: Offline Thanks Meter: 487 | G955U1 Reset FRP DONE Device: Operation: Reset FRP Searching for Device... Found Model: SM-G955U1 Baseband: G955U1UEU2AQK2 Bootloader: G955U1UEU2AQK2 PDA: G955U1UEU2AQK2 Android Version: 7.0 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:08 [Ultimate Samsung Flasher v1.4] |
The Following User Says Thank You to mickeybrown026 For This Useful Post: |
11-16-2018, 15:32 | #5585 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | frp neffos tp902a x1 Operation : Reset FRP CPU : MT6755 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM42) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Neffos Manufacturer : TP-Link Model : Neffos X1 Prod. Name : TP902A Device : X1 Platform : mt6755 Android Ver. : 7.0 Display ID : TP902R2429 Patch Level : 2018-05-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.5] |
The Following User Says Thank You to bruno santana For This Useful Post: |
11-17-2018, 00:08 | #5586 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Egypt Age: 37
Member: 710690 Status: Offline Thanks Meter: 907 | test report write full firmware for Note 3 N9005 thanks UMT team New SW have many a good options for Sam |
The Following User Says Thank You to amrMHF For This Useful Post: |
11-17-2018, 09:41 | #5589 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2351667 Status: Offline Thanks Meter: 3 | frp Port : Not Applicable Baud Rate : Not Applicable Device : Huawei Honor 7X BND-AL10 Operation : Remove FRP Enabling ADB Mode... OK Waiting for device... Found! Model : BND-AL10 Version : 8.0.0 Build : BND-AL10-user 8.0.0 HONORBND-AL10 320(C675) release-keys Hardware : hi6250 Removing FRP Lock... Done Operation Finished. Elapsed Time: 02:45 [Module Ver. 5.2] Log Saved to Logs\181117_14052 |
The Following User Says Thank You to jadhav2875 For This Useful Post: |
11-17-2018, 11:15 | #5590 (permalink) |
Freak Poster Join Date: Apr 2016 Location: GSM Forum Age: 27
Member: 2559216 Status: Offline Thanks Meter: 220 | Samsung S6 Edge plus(G928G) Flash Done By UMT Samsung 0.1 Code: Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM87 : SAMSUNG Mobile USB Modem #30 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI7420 [HiSpeed] Sending Partition [BOOTLOADER]...Done Sending Partition [PARAM]...Done Sending Partition [CM]...Done Sending Partition [BOOT]...Done Sending Partition [RECOVERY]...Done Sending Partition [SYSTEM]...Done Sending Partition [USERDATA]...Done Sending Partition [RADIO]...Done Sending Partition [CACHE]...Done Sending Partition [HIDDEN]...Done Closing Session...Done Operation Finished. Elapsed Time 03:22 Module Ver. 0.1 LOG Saved to !Logs\181117_154326.log |
The Following User Says Thank You to Riz_Mobile For This Useful Post: |
11-17-2018, 11:15 | #5591 (permalink) |
11-17-2018, 12:11 | #5592 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Ukraine
Member: 2750401 Status: Offline Thanks Meter: 134 | J500H FRP Data...OK Brand : Samsung Model : J500H Operation : Reset FRP Searching for Phone...Found Port: : COM43 : SAMSUNG Mobile USB Modem #7 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : MSM8916 [HiSpeed] Loading Data...OK Resetting FRP Data...OK Closing Session...Done |
The Following User Says Thank You to dimasc For This Useful Post: |
11-17-2018, 19:03 | #5593 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | Model : Samsung Universal Operation : Flash ByPass Firmware Searching for Phone...Found Port: : COM33 : SAMSUNG Mobile USB Modem #8 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI7870 [HiSpeed] Loading Data...Done Sending Data...Done Closing Session...Done Searching for Phone...Found Port: : COM33 : SAMSUNG Mobile USB Modem #8 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : LSI7870 [HiSpeed] Loading Data...Done Sending Data...Done Loading Data...Done Sending Data...Done Loading Data...Done Sending Data...Done Loading Data...Done Sending Data...Done Closing Session...Done Operation Finished. Elapsed Time 08:24 Module Ver. 0.1 LOG Saved to !Logs\181117_185753.log |
The Following User Says Thank You to atou For This Useful Post: |
11-17-2018, 19:34 | #5594 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Morocco
Member: 1712203 Status: Offline Thanks Meter: 354 | Model : J320FN Operation : FRP Reset (Format UD) Searching for Phone...Found Port: : COM4 : SAMSUNG Mobile USB Modem Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : SPRD8735 [HiSpeed] Loading Data...Done Sending Data...Done Closing Session...Done Operation Finished. Elapsed Time 00:12 Module Ver. 0.1 LOG Saved to !Logs\181117_183150.log |
The Following User Says Thank You to apologized For This Useful Post: |
