09-02-2020, 09:23 | #9046 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Oppo f3 frp fail in umt , driver issue pls fix it Model : F3 (CPH1609) Operation : Reset FRP Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM51) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connecting to HighSpeed Port... Waiting for HighSpeed Port.. Port : MediaTek DA USB VCOM (Android) (COM53) Connected to Download Agent.. Syncing with Target... Reading Partition Table... Failed! Please retry or update drivers! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.1] |
09-02-2020, 13:10 | #9047 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Vivo y69 lock removed in meta mode Operation : Factory Reset (New) Checking for existing META ports... Found MediaTek USB VCOM (Android) (COM61) on COM61 Device Path : usb\vid_0e8d&pid_2007&rev_???? Configuring Communication Channel... Reading phone information... CPU : MT6750 SW Ver. : MOLY.LR11.W1603.MD.MP.V44.P111 HW Ver. : BBK6750_66_N_HW Starting Factory Reset... Reset success Operation finished [UltimateMTK Ver. 3.1] |
09-02-2020, 14:30 | #9048 (permalink) |
Freak Poster Join Date: Jul 2009 Location: paraguay
Member: 1086987 Status: Offline Sonork: 1617504 Thanks Meter: 109 | redmi 8a reset mi account free auth DONE Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_035]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 8A [olivelite] Brand : Xiaomi Prod.Name : olivelite Software : ZQL2116-olivelite-build-20200530033821, V11.0.7.0.PCPMIXM [Sat May 30 03:40:08 CST 2020] Android Ver. : 9 Patch Level : 2020-05-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 6.0 |
The Following 3 Users Say Thank You to miguelcpm22 For This Useful Post: |
09-02-2020, 14:30 | #9049 (permalink) |
09-02-2020, 14:39 | #9050 (permalink) |
Member: 1086987 Status: Offline Sonork: 1617504 Thanks Meter: 109 | redmi 8a free auth reset frp done Device : Xiaomi Redmi 8A Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_035]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 8A [olivelite] Brand : Xiaomi Prod.Name : olivelite Software : ZQL2116-olivelite-build-20200530033821, V11.0.7.0.PCPMIXM [Sat May 30 03:40:08 CST 2020] Android Ver. : 9 Patch Level : 2020-05-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.0 |
The Following 2 Users Say Thank You to miguelcpm22 For This Useful Post: |
09-03-2020, 12:08 | #9058 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Redmi s2 mi account disable by umt Device : Xiaomi Redmi S2 Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM59) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi S2 [ysl] Brand : xiaomi Prod.Name : ysl Software : OPM1.171019.011, V10.3.1.0.OEFMIXM [Thu Apr 25 14:02:51 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-04-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. QcFire Ver. 6.0 |
09-03-2020, 12:09 | #9059 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | MI wt88047( 2014818) LOGO FIX BY UMT FLASHING IN ELD MODE Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM59) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D5A000] Payload Info : In: 262144 [4096], Out: 16384, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [splash.img] -> [splash] ...Done Writing [sec.dat] -> [sec] ...Done Writing [boot.img] -> [boot] ...Done Writing [system.img ] -> [system]...Done Writing [cache.img ] -> [cache]...Done Writing [persist.img ] -> [persist]...Done Writing [recovery.img] -> [recovery] ...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 6.0 |
09-04-2020, 12:49 | #9060 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: MALDIVES
Member: 1324837 Status: Offline Sonork: jisankhan Thanks Meter: 58 | ALHAMDULILLAH SUCCESSFULLY REMOVE FRP Xiaomi Redmi Go: Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM63) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 8 GB LU Count : 1 [0x00E90000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Go [tiare] Brand : Xiaomi Prod.Name : tiare Software : OPM1.171019.026.V10.2.19.0.OCLMIXM, V10.2.19.0.OCLMIXM [Mon Jul 20 10:00:15 WIB 2020] Android Ver. : 8.1.0 Patch Level : 2020-07-05 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.9 |
