11-16-2021, 08:41 | #10472 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 668748 Status: Offline Thanks Meter: 110 | Device : Huawei Y7 Prime 2019 (LDN-L21) Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM469) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 41001500 OPK_DATA : 3B48AE9023196AE5C8162BCE65CB66E9636C784CB52A55046D 15110FD8B11688 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_034]...Done Executing Loader...OK Hardware : 8937, EMMC, 32 GB LU Count : 3 [0x03A3E000] [0x00002000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : unknown Software : System 8.0.0.073(09YO), eng.root.20201027.024155 [Tue Oct 27 02:41:55 CST 2020] Android Ver. : 8.0.0 Patch Level : 2020-09-01 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 7.4 |
The Following User Says Thank You to imran_awan For This Useful Post: |
11-16-2021, 08:41 | #10473 (permalink) |
11-16-2021, 13:39 | #10474 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Redmi Note 10S bootloader unlocked Code: Operation : MTK Bootloader Unlock Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM7 [MediaTek USB Port_V1633 (COM7)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&3b2e6861&2&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0813, [MT6785] [Helio G90] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: True] [DA Auth: True] Preparing device... -- Success! Preloader saved as : preloader_k85v1_64_211116_151606.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM7) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : UFS Reading Information... -- Could not read! Platform : MT6785 Board : rosemary Platform : mt6785 Userdata is ENCRYPTED Reading Data... Bootloader Status : Locked [Default] Critical Lock Status : Locked [Default] Old Algo Detected! Unlocking Bootloader... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.5] |
The Following User Says Thank You to bk.gsm For This Useful Post: |
11-16-2021, 13:56 | #10475 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,706 | Redmi 8A reset efs done Code: Operation : Wipe EFS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_035]...Done Executing Loader...OK Auth Enabled Device! You may need Mi Auth Account to service! Skipping Auth...OK Hardware : 8937, EMMC, 32 GB LU Count : 3 [0x03A3E000] [0x00002000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : , V12.5.1.0.QCPMIXM [Tue Aug 3 22:20:49 CST 2021] Android Ver. : 10 Patch Level : 2021-07-01 Saving EFS Backup.......OK EFS Backup : EFS_Xiaomi_2021-07-01_211116_154509.ueb Reset EFS (Full).......Done Operation Finished. QcFire Ver. 7.4 |
11-17-2021, 09:42 | #10476 (permalink) |
Freak Poster Join Date: Aug 2010 Location: india, haryana,
Member: 1358048 Status: Offline Thanks Meter: 706 | Port : Fastboot Inteface Baud Rate : Not Applicable Device : Motorola Operation : New FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1922-10 Boot Ver. : MBM-2.1-aljeter_retail-b1f322d35c1-2 version-bootloader[1]: 00404 Done Baseband : M8937_34.42.05.98R JETER_INDIADSDS_CUST Software : Blur_Version.29.311.7.aljeter.retail.en.US IMEI : 355527091270317 CPU : MSM8937 RAM : 3GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=5F EMMC : 32GB SAMSUNG GX6BMB RV=08 PV=03 FV=0000000000000003 Setting Factory Mode... OK Searching Network Interface... Found Connecting to device... OK Model : moto g(6) play Bootloader : 0xB830 Baseband : M8937_34.42.05.98R JETER_INDIADSDS_CUST Build : Blur_Version.29.311.7.aljeter.retail.en.US Android : 9 Searching Network Interface... Found Connecting to device... OK Model : moto g(6) play Bootloader : 0xB830 Baseband : M8937_34.42.05.98R JETER_INDIADSDS_CUST Build : Blur_Version.29.311.7.aljeter.retail.en.US Android : 9 Resetting FRP... OK Searching for Device in FastBoot Mode... OK Removing Factory Mode... OK Operation Finished. Elapsed Time: 02:42 [Module Ver. 5.5.1] Log Saved to Logs\211117_141034.log |
The Following User Says Thank You to skakroliya For This Useful Post: |
11-17-2021, 09:42 | #10477 (permalink) |
11-17-2021, 13:18 | #10478 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,706 | Redmi Note 8 flash done Code: Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Hardware : SDM665, EMMC, 64 GB LU Count : 4 [0x0747C000] [0x00002000] [0x00002000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 512 Writing [qupv3fw.elf] -> [qupfw] ...Done Writing [qupv3fw.elf] -> [qupfwbak] ...Done Writing [vbmeta.img] -> [vbmeta] ...Done Writing [vbmeta.img] -> [vbmetabak] ...Done Writing [xbl_config.elf] -> [xbl_config] ...Done Writing [xbl_config.elf] -> [xbl_configbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [storsec.mbn] -> [storsec] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [km4.mbn] -> [keymaster] ...Done Writing [km4.mbn] -> [keymasterbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [BTFM.bin] -> [bluetoothbak] ...Done Writing [misc.img] -> [misc] ...Done Writing [imagefv.elf] -> [imagefv] ...Done Writing [imagefv.elf] -> [imagefvbak] ...Done Writing [uefi_sec.mbn] -> [uefisecapp] ...Done Writing [uefi_sec.mbn] -> [uefisecappbak] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [logfs_ufs_8mb.bin] -> [logfs] ...Done Writing [metadata.img ] -> [metadata]...Done Writing [dtbo.img] -> [dtbo] ...Done Writing [dtbo.img] -> [dtbobak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [dspso.bin] -> [dspbak] ...Done Writing [persist.img] -> [persist] ...Done Writing [boot.img] -> [boot] ...Done Writing [boot.img] -> [bootbak] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [NON-HLOS.bin] -> [modembak] ...Done Writing [cust.img ] -> [cust]...Done Writing [vendor.img ] -> [vendor]...Done Writing [system.img ] -> [system]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 7.4 |
11-17-2021, 13:23 | #10479 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,706 | Redmi note 8 imei repair done Code: Operation : Repair IMEI Port : COM17 : Qualcomm HS-USB Android DIAG 902D (COM17) Compile : Nov 30 2020 01:34:42 Release : Oct 24 2019 08:00:00 Hw. Ver. : nicobar. Software : ---- IMEI : 000000000000000 / 000000000000000 Preparing IMEI Data...Done QCN File : **:\**\**\**\redmi note8 2.29.qcn Restoring QCN Data...Done Syncing Data...Done Operation Finished. QcFire Ver. 7.4 |
The Following 2 Users Say Thank You to bk.gsm For This Useful Post: |
11-18-2021, 11:36 | #10480 (permalink) |
Member: 1358048 Status: Offline Thanks Meter: 706 | motorola xt1686 frp reset done Code: Port : Fastboot Inteface Baud Rate : Not Applicable Device : Motorola Operation : New FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1686 Boot Ver. : moto-msm8953-C0.8C Baseband : M8953_37.46.07.47.01R POTTER_INDIADSDS_CUST Software : Blur_Version.25.331.16.potter.retail.en.US IMEI : 3518########### CPU : MSM8953 RAM : 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=5F EMMC : 32GB SAMSUNG RX14MB RV=08 PV=07 FV=0000000000000007 Setting Factory Mode... OK Searching Network Interface... Found Connecting to device... OK Model : Moto G (5) Plus Bootloader : 0xC08C Baseband : M8953_37.46.07.47.01R POTTER_INDIADSDS_CUST Build : Blur_Version.25.331.16.potter.retail.en.US Android : 7.0 Searching Network Interface... Found Connecting to device... OK Model : Moto G (5) Plus Bootloader : 0xC08C Baseband : M8953_37.46.07.47.01R POTTER_INDIADSDS_CUST Build : Blur_Version.25.331.16.potter.retail.en.US Android : 7.0 Resetting FRP... OK Searching for Device in FastBoot Mode... OK Removing Factory Mode... OK Operation Finished. Elapsed Time: 03:11 [Module Ver. 5.5.1] Log Saved to Logs\211118_160349.log |
The Following 2 Users Say Thank You to skakroliya For This Useful Post: |
11-18-2021, 12:02 | #10481 (permalink) |
Member: 1358048 Status: Offline Thanks Meter: 706 | Motorola xt1643 frp reset done Code: Port : Fastboot Inteface Baud Rate : Not Applicable Device : Motorola Operation : New FRP Reset Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1643 Boot Ver. : moto-msm8952-B1.07 Baseband : M8952_70030.25.03.62.02R ATHENE_INDIA_DSDS_CUST Software : Blur_Version.25.236.3.athene.retail.en.US IMEI : 3581########### CPU : MSM8952 RAM : 3GB SAMSUNG LP3 DIE=6Gb M5=01 M6=05 M7=00 M8=7B EMMC : 32GB SAMSUNG RX1BMB RV=08 PV=07 FV=0000000000000007 Setting Factory Mode... OK Searching Network Interface... Found Connecting to device... OK Model : Moto G (4) Bootloader : 0xB107 Baseband : M8952_70030.25.03.62.02R ATHENE_INDIA_DSDS_CUST Build : Blur_Version.25.236.3.athene.retail.en.US Android : 7.0 Searching Network Interface... Found Connecting to device... OK Model : Moto G (4) Bootloader : 0xB107 Baseband : M8952_70030.25.03.62.02R ATHENE_INDIA_DSDS_CUST Build : Blur_Version.25.236.3.athene.retail.en.US Android : 7.0 Resetting FRP... OK Searching for Device in FastBoot Mode... OK Removing Factory Mode... OK Operation Finished. Elapsed Time: 04:10 [Module Ver. 5.5.1] Log Saved to Logs\211118_163031.log |
11-18-2021, 17:09 | #10482 (permalink) |
Freak Poster Join Date: Nov 2018 Location: Everywhere Your Not
Member: 2875052 Status: Offline Thanks Meter: 211 | Samsung Galaxy A11 (SM-A115F) FRP DONE Device: Samsung Galaxy A11 (SM-A115F) Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM32) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00002000 OPK_DATA : 7A1DF77CBFBB0788FC8EA8D75792F665B38495C74C24E98E59 08F89AAC71A27C Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_050]...Done Executing Loader...OK Hardware : 8953, EMMC, 32 GB LU Count : 3 [0x03A3E000] [0x00002000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Software : QP1A.190711.020.A115FXXU1ATG1, A115FXXU1ATG1 [Thu Jul 2 22:15:41 KST 2020] Android Ver. : 10 Patch Level : 2020-07-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.4 |
The Following 2 Users Say Thank You to Trapbay For This Useful Post: |
11-18-2021, 17:09 | #10483 (permalink) |
The Following 3 Users Say Thank You to Trapbay For This Useful Post: |
11-19-2021, 00:36 | #10484 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | Samsung SM-A037M FRP Unlock One Click Quote:
The Following 2 Users Say Thank You to daroas For This Useful Post: |
