06-10-2022, 07:31 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Redmi note 10 sunny/mojito flash eror Code: Operation : Multi Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1500900 [SM6150] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6150]...Done Executing Loader...OK Auth Enabled Device! You may need Mi Auth Account to service! Skipping Auth...OK Detecting Storage Type...OK Hardware : SM6150, UFS, 64 GB LU Count : 6 [0x00DD4000] [0x00000800] [0x00000800] [0x00000000] [0x00000000] [0x00000000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : , V13.0.1.0.SKGINXM [Fri Apr 1 11:08:55 CST 2022] Android Ver. : 12 Patch Level : 2022-03-01 Processing [rawprogram0.xml] Writing [super.img ] -> [super]...Done Writing [vbmeta_system.img] -> [vbmeta_system_a] ...Done Writing [metadata.img ] -> [metadata]...Done Writing [rescue.img ] -> [rescue]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram1.xml] Writing [xbl.elf] -> [xbl_a] ...Done Writing [xbl_config.elf] -> [xbl_config_a] ...Done Writing [gpt_main1.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup1.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram2.xml] Writing [xbl.elf] -> [xbl_b] ...Done Writing [xbl_config.elf] -> [xbl_config_b] ...Done Writing [gpt_main2.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup2.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram3.xml] Writing [gpt_main3.bin] -> [PrimaryGPT] ...Failed Operation Failed. QcFire Ver. 7.9 |
06-10-2022, 19:38 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,447 | It seems either this device has damaged storage chip or had been a lab rat in another shop. Last 3 physical partitions are showin 0 size which is not normal. Br, UMT |
The Following 4 Users Say Thank You to U.M.T For This Useful Post: |
06-11-2022, 11:14 | #3 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | Quote:
Code: [0x00000000] [0x00000000] [0x00000000] otherwise this phone will not be able to accept any firmware... b.r. | |
The Following User Says Thank You to bk.gsm For This Useful Post: |
