05-17-2018, 05:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | 10 or android phone please help me Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM60) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 66004600 OPK_DATA : 74F7C0FD512E9F64E141A5BC7CC1AAC20FE9EF7348FB6DD072 364C3F9715BB17 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8917.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.2 Operation : Reset Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM60) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 66004600 OPK_DATA : 74F7C0FD512E9F64E141A5BC7CC1AAC20FE9EF7348FB6DD072 364C3F9715BB17 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8917.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.2 Module Ver. 2.2 |
05-17-2018, 07:33 | #2 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | UMT check this |
05-17-2018, 09:20 | #7 (permalink) | |
Crazy Poster Join Date: Aug 2007
Member: 576943 Status: Offline Thanks Meter: 7 | Quote:
You should Give solution rather than giving unwanted info we just want to formate this device tell me process how to format - unlock password from this device Or simply just say that UMT doesnt have support to remove PASSWORD nor format this device Thanks | |
