01-26-2018, 05:35 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You need to put device in FTM mode. Alternatively, you can try in fastboot mode too. For this, enter recovery and then select reboot to bootloader. Br, Ultimate Multi Tool |
The Following User Says Thank You to U.M.T For This Useful Post: |
01-26-2018, 06:34 | #4 (permalink) |
Product Supporter Join Date: Sep 2017 Location: MH Unlocker Pro
Member: 2753718 Status: Offline Sonork: FB : MH Unlocker Pro Thanks Meter: 811 | HI Install Drivers for "ANDROID" yellow port..Its Diagnostic port...FRP reset in FTM mode is works on DIAGNOSTIC Port if iam not wrong BR. SeharH |
The Following User Says Thank You to SeharH For This Useful Post: |
03-16-2018, 06:14 | #7 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You can select any model. If both FTM and Fastboot method does not work, you may use EDL method in QcFire. Br, Ultimate Multi Tool |
