Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 10-15-2021, 10:54   #1 (permalink)
Member: 335008
Thanks Meter: 57
REDMI 5 PLus Stuck On 2nd Logo After Disable Locks...Any Solution Without Data Lose
Device : Xiaomi Redmi 5 Plus
Operation : Disable Screen Locks
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM67)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1600400 [8953] 00000000
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8953]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Skipping Auth...OK
Detecting Chip Type...OK
Hardware : 8953, EMMC, 64 GB
LU Count : 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi Redmi 5 Plus [msm8953] [vince]
Brand : xiaomi
Prod.Name : vince
Software : ZQL1711-vince-build-20191108142512, V11.0.2.0.OEGMIXM [Fri Nov 8 14:24:59 WIB 2019]
Android Ver. : 8.1.0
Patch Level : 2019-10-01
USERDATA : Encrypted
Disabling Screen Locks...
Directory Found, Erasing file...MiuiSystemUI.apk
Directory Found, Erasing file...MiuiSystemUI.apkDone
Operation Finished.
QcFire Ver. 7.3
after this device stuck on android logo..keeps moving after 10-12 minute it pop up with recovery mode..
The Following 2 Users Say Thank You to crazy_kamal For This Useful Post:
Old 10-15-2021, 15:00   #2 (permalink)
Member: 2067643
Sonork: 1611265
Thanks Meter: 474
just flash without data lose tick with mi flasher
The Following User Says Thank You to iftikharrana58 For This Useful Post:
Old 10-15-2021, 17:42   #3 (permalink)
Member: 335008
Thanks Meter: 57
Talking Solved
Did the process with QFill Firmware...Skip The User-data...
phone started in same condition....
The Following User Says Thank You to crazy_kamal For This Useful Post:
Page generated in 0.11616 seconds with 8 queries
