12-15-2018, 11:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2006
Member: 255072 Status: Offline Thanks Meter: 46 | Redmi 6 pro efs functions failed Operation : Full Reset EFS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Preparing Loader...Done Sending Loader [Mi6Pro]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.5 Tested with 3 different cable 2 from samsung original box Tested with tp non tp method also different usb ports but always failed on this point. Someone bricked imei on device (00000000000000) i have qcn backup from other handset and trying to repair imei numbers Regards |
12-15-2018, 12:17 | #3 (permalink) |
Member: 255072 Status: Offline Thanks Meter: 46 | Operation : Backup EFS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.5 This is report of default loader |
12-15-2018, 12:37 | #4 (permalink) |
Member: 255072 Status: Offline Thanks Meter: 46 | Port : ADB Interface Baud Rate : Not Applicable Device : Qualcomm Android Operation : Reset EFS Searching for Device... Found Model : Redmi 6 Pro Version : 8.1.0 Hardware : qcom Baseband : 953_GEN_PACK-1.152683.0.158868.2 CPU : arm64-v8a SIM Card : ABSENT,ABSENT Type : Unknown MEID(1) : Null/Empty Root : Rooted Gettting Partition Data... Not Found Creating EFS Backup (zip)... Pull Err! Operation Failed. Elapsed Time: 00:20 [Module Ver. 5.2] Log Saved to Logs\181215_133629.log Also report for efs backup etc all other imei repair functions did not work |
12-18-2018, 06:20 | #6 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | No, it will not be fixed. It is not supported with new anti level, and will not be supported until Xiaomi Release loader for Anti 4 level. Br, UMT |
12-18-2018, 11:25 | #7 (permalink) |
Member: 255072 Status: Offline Thanks Meter: 46 | C:\Windows\system32>cd.. C:\Windows>cd.. C:\>cd adb C:\adb>fastboot getvar anti anti: finished. total time: 0.005s C:\adb> Antirollback level is none so device never reach that position i just wrote before about it device chip and loader type looking wrong many users reported that but seems umt doesnt care about this product anymore |
03-26-2019, 15:34 | #8 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Gautam Buddha Nagar Age: 35
Member: 1291309 Status: Offline Sonork: [email protected] Thanks Meter: 58 | 1st umt qfire tool se Reset EFS then restore EFS file orignel then restore qcn file origneal but phale dig port banani hogi tabhi hoga 101% done if you have change imei so not posible tight secorty xiaomi compney i have 50 time try so don't try west time origneal hi chalenge |
