Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2014 Location: Samarqand.Otash Master
Member: 2279308 Status: Offline Thanks Meter: 9 | redmi 9a flash error Storage : EMMC Scatter : C:\Users\Otash\Desktop\dandelion_images_V12.5.18.0 .RCDCNXM_20220901.0000.00_11.0_cn_c02a4d9ee2\dande lion_images_V12.5.18.0.RCDCNXM_20220901.0000.00_11 .0_cn\images\MT6765_Android_scatter.txt DA Version : MTK_AllInOne_DA_v3.3001.2020/07/07.10:10 Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM205 [MediaTek USB Port_V1632 (COM205)] Device Path: \\?\usb#vid_0e8d&pid_0003#5&2e786fd2&0&14#{86e0d1e 0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: True] [DA Auth: True] MEID: 8F036157F9416143FC5B53C0EB612C17 Preparing device... -- Success! Waiting for Phone in Flash Mode... Connect Power Off phone now... Port : MediaTek USB Port_V1632 (COM205) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Failed to Connect DA: STATUS_DA_HASH_MISMATCH(-1073283068) Disconnect cable and Power ON phone. |
![]() | #2 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2008 Location: UMT Support section Age: 32
Member: 869809 Status: Offline Thanks Meter: 1,452 | did you check the new version of our mtk tool??? https://forum.gsmhosting.com/vbb/f97...tions-3102998/ |
![]() | #3 (permalink) |
Member: 2279308 Status: Offline Thanks Meter: 9 | Operation : Flash Scatter Using Preloader from Firmware Waiting for Device [BROM]...Found Port : MediaTek USB Port_V1632 (COM205) Device Path : \\?\usb#vid_0e8d&pid_0003#5&2e786fd2&0&14#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.0.1504.0 [usb2ser.sys] Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:True] [DAA:True] MEID : 8F036157F9416143FC5B53C0EB612C17 SoC ID[0] : D4E5F9C5F08226D9EC372B4BC4ED65A1 SoC ID[1] : C890146478426A6294E89F9AA21B2AE8 Running Exploit...Done Preloader : preloader_k62v1_64_bsp.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 450100444134303332014914E942B723 [EMMC] Initializing Storage...OK Sending 2nd DA...Failed! Operation Finished. [UltimateMTK2 v0.1] Log Saved : 20221228_170828.log |
![]() | #5 (permalink) |
Member: 2279308 Status: Offline Thanks Meter: 9 | another redmi 9a phone booting successfully but exactly one model is not working or is it possible that the processor in this model is different,,, I opened the phone, the type of chip, MTK 6762v is placed in it |
![]() | #7 (permalink) |
Member: 2279308 Status: Offline Thanks Meter: 9 | Operation : Flash Scatter Using Preloader from Firmware Waiting for Device [BROM]...Found Port : MediaTek USB Port_V1632 (COM270) Device Path : \\?\usb#vid_0e8d&pid_0003#5&2e786fd2&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver : MediaTek Inc., 3.0.1504.0 [usb2ser.sys] Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:True] [DAA:True] MEID : 8F036157F9416143FC5B53C0EB612C17 SoC ID[0] : D4E5F9C5F08226D9EC372B4BC4ED65A1 SoC ID[1] : C890146478426A6294E89F9AA21B2AE8 Running Exploit...Done Preloader : preloader_k62v1_64_bsp.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 450100444134303332014914E942B723 [EMMC] Initializing Storage...OK Sending 2nd DA...Failed! Operation Finished. [UltimateMTK2 v0.1] Log Saved : 20221229_100518.log anyway it is |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Santiago de Cuba
Member: 220595 Status: Offline Thanks Meter: 340 | same issue here redmi 9a fastboot: Code: A:\adb>fastboot getvar all (bootloader) fuse_state: 0xe (bootloader) max-download-size: 0x8000000 (bootloader) cpuid: a00ef73113a55c049b6f3013a3e3fa2de3d12c7d (bootloader) variant: (bootloader) logical-block-size: 0x200 (bootloader) erase-block-size: 0x80000 (bootloader) hw-revision: ca00 (bootloader) battery-soc-ok: yes (bootloader) battery-voltage: 4187mV (bootloader) partition-size:sgpt: 4200 (bootloader) partition-type:sgpt: raw data (bootloader) partition-size:flashinfo: 1000000 (bootloader) partition-type:flashinfo: raw data (bootloader) partition-size:otp: 2b00000 (bootloader) partition-type:otp: raw data (bootloader) partition-size:userdata: cf34fbe00 (bootloader) partition-type:userdata: f2fs (bootloader) partition-size:cache: 1b000000 (bootloader) partition-type:cache: ext4 (bootloader) partition-size:vbmeta: 800000 (bootloader) partition-type:vbmeta: raw data (bootloader) partition-size:super: 120000000 (bootloader) partition-type:super: raw data (bootloader) partition-size:tee2: 880000 (bootloader) partition-type:tee2: raw data (bootloader) partition-size:tee1: 500000 (bootloader) partition-type:tee1: raw data (bootloader) partition-size:dtbo: 800000 (bootloader) partition-type:dtbo: raw data (bootloader) partition-size:logo: 800000 (bootloader) partition-type:logo: raw data (bootloader) partition-size:boot: 4000000 (bootloader) partition-type:boot: raw data (bootloader) partition-size:lk2: 200000 (bootloader) partition-type:lk2: raw data (bootloader) partition-size:lk: 200000 (bootloader) partition-type:lk: raw data (bootloader) partition-size:nvram: 4000000 (bootloader) partition-type:nvram: raw data (bootloader) partition-size:gz2: 1000000 (bootloader) partition-type:gz2: raw data (bootloader) partition-size:gz1: 1000000 (bootloader) partition-type:gz1: raw data (bootloader) partition-size:sspm_2: 100000 (bootloader) partition-type:sspm_2: raw data (bootloader) partition-size:sspm_1: 100000 (bootloader) partition-type:sspm_1: raw data (bootloader) partition-size:scp2: 100000 (bootloader) partition-type:scp2: raw data (bootloader) partition-size:scp1: 100000 (bootloader) partition-type:scp1: raw data (bootloader) partition-size:spmfw: 100000 (bootloader) partition-type:spmfw: raw data (bootloader) partition-size:md1img: 6400000 (bootloader) partition-type:md1img: raw data (bootloader) partition-size:efuse: 80000 (bootloader) partition-type:efuse: raw data (bootloader) partition-size:proinfo: 300000 (bootloader) partition-type:proinfo: raw data (bootloader) partition-size:sec1: 200000 (bootloader) partition-type:sec1: raw data (bootloader) partition-size:persist: 3000000 (bootloader) partition-type:persist: ext4 (bootloader) partition-size:seccfg: 800000 (bootloader) partition-type:seccfg: raw data (bootloader) partition-size:protect2: ade000 (bootloader) partition-type:protect2: ext4 (bootloader) partition-size:protect1: 800000 (bootloader) partition-type:protect1: ext4 (bootloader) partition-size:metadata: 2000000 (bootloader) partition-type:metadata: raw data (bootloader) partition-size:md_udc: 169a000 (bootloader) partition-type:md_udc: ext4 (bootloader) partition-size:nvdata: 4000000 (bootloader) partition-type:nvdata: ext4 (bootloader) partition-size:nvcfg: 2000000 (bootloader) partition-type:nvcfg: ext4 (bootloader) partition-size:frp: 100000 (bootloader) partition-type:frp: raw data (bootloader) partition-size:vbmeta_vendor: 800000 (bootloader) partition-type:vbmeta_vendor: raw data (bootloader) partition-size:vbmeta_system: 800000 (bootloader) partition-type:vbmeta_system: raw data (bootloader) partition-size:cust: 34000000 (bootloader) partition-type:cust: raw data (bootloader) partition-size:ffu: 800000 (bootloader) partition-type:ffu: raw data (bootloader) partition-size:gsort: 1000000 (bootloader) partition-type:gsort: raw data (bootloader) partition-size:expdb: 1400000 (bootloader) partition-type:expdb: raw data (bootloader) partition-size:para: 80000 (bootloader) partition-type:para: raw data (bootloader) partition-size:recovery: 4000000 (bootloader) partition-type:recovery: raw data (bootloader) partition-size:boot_para: 100000 (bootloader) partition-type:boot_para: raw data (bootloader) partition-size:pgpt: 8000 (bootloader) partition-type:pgpt: raw data (bootloader) partition-size:preloader: 40000 (bootloader) partition-type:preloader: raw data (bootloader) serialno: ZXPRAQ4HYXIBOJUS (bootloader) off-mode-charge: 1 (bootloader) warranty: no (bootloader) unlocked: yes (bootloader) secure: no (bootloader) tokenversion: 2 (bootloader) crc: 1 (bootloader) kernel: lk (bootloader) product: dandelion (bootloader) is-userspace: no (bootloader) slot-count: 0 (bootloader) version-baseband: MOLY.LR12A.R3.MP.V107.5.P114 (bootloader) version-bootloader: k62v1_64_bsp-9ad9dae-20210819090548-202 (bootloader) version-preloader: (bootloader) anti: 1 (bootloader) version: 0.5 all: Done!! Finished. Total time: 0.291s Code: Operation : Read Info Waiting for Device...Found Port : MediaTek USB Port_V1632 (COM26) Device Path : \\?\usb#vid_0e8d&pid_0003#5&ea77e6&1&4#{86e0d1e0- 8089-11d0-9ce4-08003e301f73} Driver : MediaTek Inc., 3.0.1504.0 [usb2ser.sys] Mode : BROM Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:True] [DAA:True] MEID : AE8F0ED502FB36DC99AF4320F143FF27 SoC ID[0] : 3DE0CE62833401C41D4739EB7390D8F5 SoC ID[1] : 85A8E8F52E011A55FA5416132DE1F992 Running Exploit...Done Preloader : preloader_k62v1_64_bsp.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using DA : MTK_AllInOne_DA.bin DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 9B010059325030363400E3D12C7DC851 [EMMC] Initializing Storage...Failed! Please select correct preloader or from firmware. Operation Finished. [UltimateMTK2 v0.2] Log Saved : 20230124_012233.log |
![]() | #9 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 340 | Even though it looks like the same, IT IS NOT! I booted with this preloader I found laying on my computer old folders. Give it a try guys. Code: Operation : Read Info Waiting for Device...Found Port : MediaTek USB Port_V1632 (COM26) Device Path : \\?\usb#vid_0e8d&pid_0003#5&ea77e6&1&4#{86e0d1e0- 8089-11d0-9ce4-08003e301f73} Driver : MediaTek Inc., 3.0.1504.0 [usb2ser.sys] Mode : BROM Hw ID : MT6765 [0766] Helio P35/G35 Details : 8A00,CA00,0000 Sec. Config : [SBA:True] [SLA:True] [DAA:True] MEID : AE8F0ED502FB36DC99AF4320F143FF27 SoC ID[0] : 3DE0CE62833401C41D4739EB7390D8F5 SoC ID[1] : 85A8E8F52E011A55FA5416132DE1F992 Running Exploit...Done Preloader : preloader_k62v1_64_bsp.bin Loading EMI Config from Preloader...OK Sec. Config : [SBA:False] [SLA:False] [DAA:False] Using DA : MTK_AllInOne_DA.bin DA Security Patched Sending 1st DA...OK Jump DA Address...OK Syncing...OK Checksum Level is Storage Connection : brom Speed : HIGH-SPEED Reading RAM Configuration...OK Reading EMI Configuration...OK CID : 9B010059325030363400E3D12C7DC851 [EMMC] Initializing Storage...OK Sending 2nd DA...OK Initialize DA Extension...OK Int. RAM : 0x000000000003A000 [232,00 KB] Ext. RAM : 0x0000000100000000 [4,00 GB] Flash ID : Y2P064 CID : 9B010059325030363400E3D12C7DC851 BOOT1 : 0x0000000000400000 [4,00 MB] BOOT2 : 0x0000000000400000 [4,00 MB] RPMB : 0x0000000001000000 [16,00 MB] USERAREA : 0x0000000E8F800000 [58,24 GB] Connected to High-Speed DA Port Reading Partition Table...OK Manuf. : Xiaomi Ven. Model : M2006C3LG Platform : mt6765 And. Ver. : 10 Build Dt. : Mon Jan 17 19:19:46 CST 2022 Display ID : QP1A.190711.020 Ver. Inc. : V12.0.18.0.QCDMIXM Locale : en-GB Mod. Dev. : dandelion_global Patch : 2021-12-01 Operation Finished. [UltimateMTK2 v0.2] Log Saved : 20230124_013955.log |
