Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2019 Location: tajikistan kulob
Member: 2889825 Status: Offline Sonork: 100.650600 Thanks Meter: 106 | REDMI NOTE 5 UMT DONGLE Skipping Auth...Failed ![]() Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NkI0MjQxNDE0MTQxNDE0MTQxNDIzNTM3Mk QzMjc0NTg2RTc5NkY0ODZGNjM1RjcwNjI3NTUyNEI3ODU4Nzg3 Nz== User declined using UMT Server. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.7 |
![]() | #3 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2015 Location: Inside UMT
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 11,537 | Power off, remove battery, hold power button for 10 seconds. Short TP, connect cable, once port appear, connect battery, now again. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
