04-03-2020, 08:05 | #1 (permalink) |
Freak Poster Join Date: Oct 2018 Location: india,gujarat
Member: 2874024 Status: Offline Thanks Meter: 488 | redmi note 7 bootloader unlock success with umt qcfire v5.3 first Xiaomi Boot Patch Operation : Xiaomi Boot Patch Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM6) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 7 [lavender] Software : PKQ1.180904.001, V11.0.5.0.PFGMIXM [Tue Jan 14 22:51:30 WIB 2020] Android Ver. : 9 Patch Level : 2020-01-05 Processing Redmi_Note7........Done Rebooting to Fastboot...Done Put phone in Fastboot mode if it is not in Fastboot Mode. Then try Unlock BL in Fastboot Mode. Operation Finished. QcFire Ver. 5.3 now Bootloader Unlock (Fastboot) Operation : Bootloader Unlock (Fastboot) Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : GetVar Variable Not found Product : wayne Bootloader : Locked Unlocking Bootloader...Done QcFire Ver. 5.3 caution:if after bootloader unlock phone stuck in blue screen flash the phone in edl mode thats it phon will be on with normal boot and bootloader unlocked GRATE UMT KING br. SARFARAZ. |
The Following 3 Users Say Thank You to raz007 For This Useful Post: |
04-06-2020, 03:17 | #4 (permalink) |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | first try phon unlock bootlaoder with edl point or fastboot mode find test point in google area you can find eazly B,R Unlockinfo |
04-06-2020, 08:17 | #5 (permalink) |
Member: 2874024 Status: Offline Thanks Meter: 488 | as u can see guys in the log how to do it then also let me explain how to do it. first step:select redmi note 7 in boot patch menu then put the phone in edl mode and click on patch it will write patch and automatically it will enter in fastboot mode second step:now just click on unlock thats it your boot loader will be unlocked. third step:in some case after unlock bootloader if your phone show only blue light and doesnt switch on (dont worry) just flash your phone in edl mode. BR. SARFARAZ. |
The Following User Says Thank You to raz007 For This Useful Post: |
04-06-2020, 18:12 | #6 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Can you please check and confirm if you can flash phone in blue light after BL Unlock, in fastboot mode using QcFire? Br, UMT |
04-07-2020, 17:40 | #7 (permalink) | |
Member: 2874024 Status: Offline Thanks Meter: 488 | Quote:
here is the flashing log Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM6) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Writing [vbmeta.img] -> [vbmeta] ...Done Writing [vbmeta.img] -> [vbmetabak] ...Done Writing [storsec.mbn] -> [storsec] ...Done Writing [storsec.mbn] -> [storsecbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecappbak] ...Done Writing [km4.mbn] -> [keymaster] ...Done Writing [km4.mbn] -> [keymasterbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [dtbo.img] -> [dtbo] ...Done Writing [dtbo.img] -> [dtbobak] ...Done Writing [splash.img] -> [splash] ...Done Writing [persist.img] -> [persist] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img ] -> [cache]...Done Writing [system.img ] -> [system]...Done Writing [vendor.img ] -> [vendor]...Done Writing [cust.img ] -> [cust]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 5.3 | |
04-07-2020, 19:38 | #8 (permalink) | |
No Life Poster Join Date: Dec 2015
Member: 2494408 Status: Offline Thanks Meter: 110 | Quote:
## Good work Sent from my iPhone using Tapatalk | |
04-07-2020, 23:19 | #9 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
The Following User Says Thank You to U.M.T For This Useful Post: |
04-08-2020, 05:57 | #10 (permalink) |
Junior Member Join Date: Oct 2017 Location: Ecuador Age: 29
Member: 2768743 Status: Offline Thanks Meter: 6 | As it is on the blue screen, of course a restart is forced or the battery is disconnected, you enter fastboot as well as it will remain with the blue screen, there is a flash in fastboot mode or only certain files are passed x cmd. |
