05-08-2019, 16:45 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Armenia Yerevan
Member: 1801587 Status: Offline Thanks Meter: 230 | Redmi Note 7 flash fail Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM120) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Writing [vbmeta.img] -> [vbmeta] ...Done Writing [vbmeta.img] -> [vbmetabak] ...Done Writing [storsec.mbn] -> [storsec] ...Done Writing [storsec.mbn] -> [storsecbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecappbak] ...Done Writing [km4.mbn] -> [keymaster] ...Done Writing [km4.mbn] -> [keymasterbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [dtbo.img] -> [dtbo] ...Done Writing [dtbo.img] -> [dtbobak] ...Done Writing [splash.img] -> [splash] ...Done Writing [persist.img] -> [persist] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img ] -> [cache]...Done Writing [system.img ] -> [system]... Operation Finished. QcFire Ver. 4.1 Give me link or fix bug new version |
05-08-2019, 18:29 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,533 | Hi, please send us link for the firmware you used. We will check for this error. However, you can try to untick all partitions flashed, and flash only system and rest partitions and tell result. Br, UMT |
05-09-2019, 07:56 | #3 (permalink) |
Member: 1801587 Status: Offline Thanks Meter: 230 | Firmware link https://mirom.ezbox.idv.tw/en/phone/...oms-ru-stable/ |
The Following User Says Thank You to usta arman For This Useful Post: |
05-09-2019, 08:12 | #4 (permalink) |
Member: 1801587 Status: Offline Thanks Meter: 230 | Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM120) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Writing [system.img ] -> [system]... Operation Finished. QcFire Ver. 4.1 |
11-23-2019, 20:02 | #5 (permalink) |
Insane Poster Join Date: May 2014 Location: CUBA
Member: 2188300 Status: Offline Thanks Meter: 11 | Error flash xiaomi redmi note 7 xiaomi not flash and my credits no refund Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM13) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ0MzA0MjQxNDE0MjU4MzY0OTZGMzc2NDYyMz A1MzU1NTI2NzdBNjc1OTRDNzU0NDRFNjQ1RjU2NzI1MzZBNzk2 Nz== Requesting UMT Server for Auth Data...OK Credits Left: 0 Authenticating...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, ERASED GPT WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [vbmeta.img] -> [vbmeta] ...Failed Operation Finished. QcFire Ver. 5.0 |
