Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 11-12-2021, 11:38   #1 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
redmi note 7s The System Has Been Destroyed(Solved)
how to fixed please
Model ID : QKQ1.190910.002 V12.5.1.0.QFGINXM
PDA :
Platform : arm64-v8a
language : en-GB
Security Patch : 2021-08-01
Root State : No Root!
Encryption State : encrypted
Bootloader State : unknown
description : lavender-user 10 QKQ1.190910.002 V12.5.1.0.QFGINXM release-keys
Old 11-12-2021, 19:50   #2 (permalink)
Member: 2928910
Thanks Meter: 21
this is (Indian) rom
1 unlock bootloader select note 7
2 make factory reset
3 reboot
The Following 2 Users Say Thank You to moh-and For This Useful Post:
Old 11-13-2021, 08:13   #3 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
same probleme
Searching for phone in sideload mode...Found
Device Id : lavender_in_global
Version : V12.5.1.0.QFGINXM
Code Base : 10
Ext Info : GB, en, F
Formatting Data...Done
Rebooting device...Done
Operation Finished.
QcFire Ver. 7.3
Old 11-13-2021, 09:03   #4 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
Originally Posted by rai14 View Post
how to fixed please
PDA :
language : en-GB
if support flashing with UMT,,rry full flashing first.
Old 11-13-2021, 09:35   #5 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
same probleme
Operation : Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM44)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1C00800 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8996_022]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Skipping Auth...OK
Detecting Chip Type...OK
Hardware : MSM8996, EMMC, 64 GB
LU Count : 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512
Writing [vbmeta.img] -> [vbmeta] ...Done
Writing [vbmeta.img] -> [vbmetabak] ...Done
Writing [storsec.mbn] -> [storsec] ...Done
Writing [storsec.mbn] -> [storsecbak] ...Done
Writing [rpm.mbn] -> [rpm] ...Done
Writing [rpm.mbn] -> [rpmbak] ...Done
Writing [hyp.mbn] -> [hyp] ...Done
Writing [hyp.mbn] -> [hypbak] ...Done
Writing [pmic.elf] -> [pmic] ...Done
Writing [pmic.elf] -> [pmicbak] ...Done
Writing [cmnlib.mbn] -> [cmnlib] ...Done
Writing [cmnlib.mbn] -> [cmnlibbak] ...Done
Writing [cmnlib64.mbn] -> [cmnlib64] ...Done
Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done
Writing [abl.elf] -> [abl] ...Done
Writing [abl.elf] -> [ablbak] ...Done
Writing [devcfg.mbn] -> [devcfgbak] ...Done
Writing [devcfg.mbn] -> [devcfg] ...Done
Writing [tz.mbn] -> [tz] ...Done
Writing [tz.mbn] -> [tzbak] ...Done
Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done
Writing [mdtpsecapp.mbn] -> [mdtpsecappbak] ...Done
Writing [km4.mbn] -> [keymaster] ...Done
Writing [km4.mbn] -> [keymasterbak] ...Done
Writing [BTFM.bin] -> [bluetooth] ...Done
Writing [xbl.elf] -> [xbl] ...Done
Writing [xbl.elf] -> [xblbak] ...Done
Writing [dspso.bin] -> [dsp] ...Done
Writing [mdtp.img] -> [mdtp] ...Done
Writing [splash.img] -> [splash] ...Done
Writing [persist.img] -> [persist] ...Done
Writing [NON-HLOS.bin] -> [modem] ...Done
Writing [boot.img] -> [boot] ...Done
Writing [recovery.img] -> [recovery] ...Done
Writing [cache.img ] -> [cache]...Done
Writing [system.img ] -> [system]...Done
Writing [vendor.img ] -> [vendor]...Done
Writing [cust.img ] -> [cust]...Done
Writing [userdata.img ] -> [userdata]...Done
Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup0.bin] -> [BackupGPT] ...Done
Applying Patches................Done
Reading Partition Table...OK
Resetting FRP Lock.......Done
Resetting device...Done
Operation Finished.
Old 11-13-2021, 11:30   #6 (permalink)
bk.gsm's Avatar
Member: 869809
Thanks Meter: 1,701
hello
post here fastboot info and send me in private message phone's imei..I will check it for you..
b.r.
The Following 3 Users Say Thank You to bk.gsm For This Useful Post:
Old 11-13-2021, 12:27   #7 (permalink)
bk.gsm's Avatar
Member: 869809
Thanks Meter: 1,701
1-do patch unlock then put your phone in fastboot mode(maybe u will not be able to see anything on phone's screen but it's ok)then do unlock bootloader..
2-flash this rom with edl mode:
https://mifirm.net/download/2736
post results here..
b.r.
The Following 10 Users Say Thank You to bk.gsm For This Useful Post:
Old 11-13-2021, 14:34   #8 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
flash done solved 1000thanx
Operation	: Flash
OPK_DATA	: F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1
Skipping Auth...OK
Writing [dtbo.img] -> [dtbo] ...Done
Writing [dtbo.img] -> [dtbobak] ...Done
Operation Finished.
QcFire Ver. 7.3
The Following 2 Users Say Thank You to rai14 For This Useful Post:
Page generated in 0.23302 seconds with 9 queries
