10-04-2021, 21:04 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Türkiye
Member: 946678 Status: Offline Thanks Meter: 69 | redmi note 8 ginkgo flash failed it only sees it as edl mod. I try to flash global,cn, eng rom but it gives error as below. If I wait 12 hours without battery , I can get the phone to fast boot mode , but again flash fail because bootloader closed. how to solution. ? can you help me ? Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.5 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Using Alternate Method... DebugData : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJJTkZPOiBDYWxsaW5nIGhh bmRsZXIgZm9yIGNvbmZpZ3VyZSIgLz48L2RhdGE+PD94bWwgdm Vyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRh Pgo8bG9nIHZhbHVlPSJJTkZPOiBTdG9yYWdlIHR5cGUgc2V0IH RvIHZhbHVlIFVGUyIgLz48L2RhdGE+PD94bWwgdmVyc2lvbj0i MS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIH ZhbHVlPSJXQVJOOiBOQUs6IE1heFBheWxvYWRTaXplVG9UYXJn ZXRJbkJ5dGVzIHNlbnQgYnkgaG9zdCAxMDQ4NTc2IGxhcmdlci B0aGFuIHN1cHBvcnRlZCAxNjM4NCIgLz48L2RhdGE+PD94bWwg dmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYX RhPgo8cmVzcG9uc2UgdmFsdWU9Ik5BSyIgTWVtb3J5TmFtZT0i VUZTIiBNaW5WZXJzaW9uU3VwcG9ydGVkPSIxIiBWZXJzaW9uPS IxIiBNYXhQYXlsb2FkU2l6ZVRvVGFyZ2V0SW5CeXRlcz0iMTYz ODQiIE1heFBheWxvYWRTaXplVG9UYXJnZXRJbkJ5dGVzU3VwcG 9ydGVkPSIxNjM4NCIgTWF4WE1MU2l6ZUluQnl0ZXM9IjQwOTYi IERhdGVUaW1lPSJKdWwgIDMgMjAxOSAtIDIyOjIzOjU2IiAvPj wvZGF0YT5= Error getting Payload Information! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJJTkZPOiBDYWxsaW5nIGhh bmRsZXIgZm9yIGNvbmZpZ3VyZSIgLz48L2RhdGE+PD94bWwgdm Vyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRh Pgo8bG9nIHZhbHVlPSJJTkZPOiBTdG9yYWdlIHR5cGUgc2V0IH RvIHZhbHVlIFVGUyIgLz48L2RhdGE+PD94bWwgdmVyc2lvbj0i MS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIH ZhbHVlPSJXQVJOOiBOQUs6IE1heFBheWxvYWRTaXplVG9UYXJn ZXRJbkJ5dGVzIHNlbnQgYnkgaG9zdCAxMDQ4NTc2IGxhcmdlci B0aGFuIHN1cHBvcnRlZCAxNjM4NCIgLz48L2RhdGE+PD94bWwg dmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYX RhPgo8cmVzcG9uc2UgdmFsdWU9Ik5BSyIgTWVtb3J5TmFtZT0i VUZTIiBNaW5WZXJzaW9uU3VwcG9ydGVkPSIxIiBWZXJzaW9uPS IxIiBNYXhQYXlsb2FkU2l6ZVRvVGFyZ2V0SW5CeXRlcz0iMTYz ODQiIE1heFBheWxvYWRTaXplVG9UYXJnZXRJbkJ5dGVzU3VwcG 9ydGVkPSIxNjM4NCIgTWF4WE1MU2l6ZUluQnl0ZXM9IjQwOTYi IERhdGVUaW1lPSJKdWwgIDMgMjAxOSAtIDIyOjIzOjU2IiAvPj wvZGF0YT5= Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.3 |
10-04-2021, 21:29 | #2 (permalink) |
Member: 946678 Status: Offline Thanks Meter: 69 | Did you mean loader? I cant find redmi note 8 64 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiNote8_ginkgo]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.3 |
10-04-2021, 21:40 | #3 (permalink) |
Member: 946678 Status: Offline Thanks Meter: 69 | if i get a credit will the problem be solved ? Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDZFNzMzODMzMzAzMjUyNE Q0QjZCNkI2NTRGMzQ3MjQ5NDEzNjVGNzYzNDQ0MzM3MzREMzE1 MT== Requesting UMT Server for Auth Data...NOT_ENOUGH_CREDIT Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. |
10-05-2021, 10:32 | #4 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
b.r. | |
The Following User Says Thank You to bk.gsm For This Useful Post: |
