Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 02-20-2021, 14:06   #16 (permalink)
Member: 2325887
Thanks Meter: 134
Adres download firmware plz
Old 03-23-2021, 09:11   #17 (permalink)
Member: 2948336
After bypass mi redmi note 8 I have problem network . But read well sim card but not network signal
Old 03-23-2021, 09:59   #18 (permalink)
Member: 1170951
Thanks Meter: 11
go in to xiamoi special tab select your model in fix wifi /network tab and click on fix button your problem will be solved
The Following User Says Thank You to LAXMANMALI For This Useful Post:
Old 03-23-2021, 10:00   #19 (permalink)
Member: 1170951
Thanks Meter: 11
Old 03-23-2021, 10:01   #20 (permalink)
Member: 1170951
Thanks Meter: 11
Originally Posted by lalit bisht View Post
HERE IS LOG
BEFORE RESET ACCOUNT NETWORK OK
Device : Xiaomi Redmi Note 8
Operation : Read Information
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : HS-USB Diagnostics 9008 (COM8)
Driver Info : Mobile, qcusbser.sys, 2.1.0.3
Connecting to phone...OK
Waiting for response...Ignored
Init Handshake Sequence...OK
Hardware ID : E1A01000 [SDM665] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [SDM665]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : SDM665, eMMC, 32 GB
LU Count : 1 [0x03A3E000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi Redmi Note 8 [ginkgo]
Brand : xiaomi
Prod.Name : ginkgo
Software : PKQ1.190616.001, V11.0.6.0.PCOINXM [Tue Sep 8 19:55:56 WIB 2020]
Android Ver. : 9
Patch Level : 2020-08-01
USERDATA : Encrypted
You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss.
Operation Finished.
QcFire Ver. 6.2
Old 03-29-2021, 08:29   #21 (permalink)
tausifawais's Avatar
Member: 1242837
Sonork: 100.1653310
Thanks Meter: 53
redmi note 8 no service after remove mi account. and fix this method.
thank u sir this. 1000% working for me..
ok...
my phone working fine..
here is log file.
Device : Xiaomi Redmi_Note8_ginkgo
Operation : Fix Wifi / Network
Found Port : Qualcomm HS-USB QDLoader 9008 (COM83)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5
Waiting for response...OK
Hardware : SDM665, EMMC, 64 GB
LU Count : 1 [0x0747C000]
Brand : xiaomi
Prod.Name : ginkgo
Software : PKQ1.190616.001, V11.0.12.0.PCOMIXM [Thu Nov 19 14:49:05 WIB 2020]
Android Ver. : 9
Patch Level : 2020-11-01
Loading data...Done
Fixing Wifi / Network...Done
Resetting FRP Lock.......Done
Operation Finished.
QcFire Ver. 6.6
The Following User Says Thank You to tausifawais For This Useful Post:
Old 03-31-2021, 08:57   #22 (permalink)
sandeep56's Avatar
Member: 699762
Thanks Meter: 66
problem solve
no need flashing only one click
The Following User Says Thank You to sandeep56 For This Useful Post:
Page generated in 0.15618 seconds with 10 queries
