03-23-2021, 09:59 | #18 (permalink) |
Major Poster Join Date: Nov 2009
Member: 1170951 Status: Offline Thanks Meter: 11 | go in to xiamoi special tab select your model in fix wifi /network tab and click on fix button your problem will be solved |
The Following User Says Thank You to LAXMANMALI For This Useful Post: |
03-23-2021, 10:01 | #20 (permalink) | |
Member: 1170951 Status: Offline Thanks Meter: 11 | Quote:
03-29-2021, 08:29 | #21 (permalink) | |
Freak Poster Join Date: Feb 2010 Location: P A K I S T A N Age: 43
Member: 1242837 Status: Offline Sonork: 100.1653310 Thanks Meter: 53 | redmi note 8 no service after remove mi account. and fix this method. Quote:
thank u sir this. 1000% working for me.. ok... my phone working fine.. here is log file. Device : Xiaomi Redmi_Note8_ginkgo Operation : Fix Wifi / Network Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM83) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, EMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 8 [ginkgo] Brand : xiaomi Prod.Name : ginkgo Software : PKQ1.190616.001, V11.0.12.0.PCOMIXM [Thu Nov 19 14:49:05 WIB 2020] Android Ver. : 9 Patch Level : 2020-11-01 Loading data...Done Fixing Wifi / Network...Done Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 6.6 | |
The Following User Says Thank You to tausifawais For This Useful Post: |
