03-08-2021, 11:49 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: india
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | Redmi note 8 pro pattern lock not remove new update mtk 3.9 Model : Note 8 Pro Operation : Format FS Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM17 Port Name: MediaTek USB Port (COM17) Path: \\?\usb#vid_0e8d&pid_0003#5&105948fe&1&5#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0813, [MT6785] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM17) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : UFS Reading Device Information... Manufacturer : Xiaomi Android Ver. : 10 Display ID : QP1A.190711.020 Patch Level : 2021-01-01 Userdata is NOT ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.9] |
03-08-2021, 12:06 | #2 (permalink) |
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | REDMI NOTE 8 PRO FRP RESET SHOW DONE BUT NOT DONE.... Brand : Xiaomi Model : Note 8 Pro Operation : Reset FRP Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM17 Port Name: MediaTek USB Port (COM17) Path: \\?\usb#vid_0e8d&pid_0003#5&105948fe&1&5#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0813, [MT6785] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM17) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : UFS Reading Device Information... Manufacturer : Xiaomi Android Ver. : 10 Display ID : QP1A.190711.020 Patch Level : 2021-01-01 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.9] |
03-08-2021, 12:48 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | As per your log it shows that Userdata is already formatted because it is not encrypted. Also we have checked it with our test phone, and works OK. Better make a video of this issue where we can see phone screen and software log both at the sametime to understand your issue. Br, UMT |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
03-08-2021, 15:00 | #4 (permalink) | |
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | thanks for reply.. Quote:
