09-30-2020, 19:32 | #1 (permalink) |
No Life Poster Join Date: Jul 2012 Location: tunisia
Member: 1788877 Status: Offline Thanks Meter: 481 | redmi note 8 relock after reset account i tried to reset and i tried to disable mi account but in bouth cases i got the same result after i connect to wifi it relock Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 8 [ginkgo] Brand : xiaomi Prod.Name : ginkgo Software : PKQ1.190616.001, V11.0.9.0.PCOMIXM [Mon Jun 1 11:37:49 WIB 2020] Android Ver. : 9 Patch Level : 2020-05-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. QcFire Ver. 6.1 Device : Xiaomi Redmi Note 8 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM118) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 8 [ginkgo] Brand : xiaomi Prod.Name : ginkgo Software : PKQ1.190616.001, V11.0.9.0.PCOMIXM [Mon Jun 1 11:37:49 WIB 2020] Android Ver. : 9 Patch Level : 2020-05-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 6.1 |
10-01-2020, 05:50 | #3 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | Quote:
New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 6.1 | |
10-01-2020, 07:40 | #4 (permalink) | |
Member: 1788877 Status: Offline Thanks Meter: 481 | Quote:
I was talking about how to fix relock after reset mi account when i use wifi I did everything reset account, disable account, anti relock, but always the same when i connect to wifi So please how to fix this | |
10-01-2020, 08:04 | #5 (permalink) | |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Quote:
1st reset account or write persist then follow my solution https://forum.gsmhosting.com/vbb/f97...-here-2858760/ Job 100% done Any MIUI | |
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post: |
10-01-2020, 14:49 | #6 (permalink) | |
waiting for umt team to give sollution because i was waiting for this update and they said it's for redmi note 8 | |
03-01-2021, 22:43 | #9 (permalink) |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | helpme please Operation: Disable Auth Waiting for device in BROM mode... Port: COM40 Port Name: MediaTek USB Port (COM40) Path: \\?\usb#vid_0e8d&pid_0003#5&30622325&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0813, [MT6785] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Read Failed! [UltimateMTK Ver. 3.8] |
03-02-2021, 01:42 | #10 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
Nothing to do with this MTK Log You will most likely not receive a reply ... Enviado desde mi SM-G975U1 mediante Tapatalk | |
