03-17-2024, 13:26 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,339 | [17/03/2024] UMTv2 / UMT Pro iOSTool v4.0 Update Released - iCloud Open Menu NEW Sec. UMT iOSTool v4.0 The Ultimate iOSTool This is For Checkm8 Vulnerable iDevices & Open Menu iCloud Remove by Token Requirements: - PWNDFU For (Mac or Windows) using Winra1n or gaster etc... - Win7-X64 / Win8-X64 / Win10-X64 / Win11-X64 - Microsoft NetFramework 4.7.2 - iTunes Installed Supported iOS Versions For Ramdisk Operations : Up to 16.X Features:
Added: Remove iCloud Open Menu by Token - FMI OFF
Starting from:
Supported Models for FMI OFF Open Menu
Supported Models list For Ramdisk Operations. Boot IOS 11x to 15x
Boot iOS 16.0-16.X (No Boot Loop)
UMT IOS TOOL MANUALS HERE Important Note 2: This Module is based on EMMC/HST Addon activation. Your card must have this activation in order for this module to work for you. Official Website: Ultimate Multi Tool Ultimate Multi Tool Pro TELEGRAM OFFICIAL Group: https://t.me/umtdongles Download From Updated v4.1 Fixed FMI: https://drive.google.com/file/d/1vn0...usp=drive_link Password for Archive: UmtTeam Last edited by Fast Unlocking; 04-17-2024 at 14:08. |
The Following 12 Users Say Thank You to Fast Unlocking For This Useful Post: |
03-17-2024, 20:08 | #2 (permalink) |
Junior Member Join Date: Jul 2006 Location: egypt-alexandria
Member: 315913 Status: Offline Thanks Meter: 17 | Starting from: iPhone 5s - Till iPhone 15 Pro Max in data base from iphone 5s till iphone x only can not found this model in this version from iphone xs till iphone 15 pro max and what function support for this models? |
04-14-2024, 19:44 | #6 (permalink) |
Crazy Poster Join Date: Aug 2020 Location: zimbabwe, harare
Member: 2964366 Status: Offline Thanks Meter: 28 | Se ramdisk failed [*]==> Operation : RAMDISK-BOOT[*]==> Reading Device Infos [ DFU Mode ] CPID : 0X8000 ECID : 0X00000576C8CED414 PWND: IKEYM8 MODE: DFU PRODUCT : iPhone8,4 MODEL : n69uap[*]==> Device : iPhoneSE(iPhone8,4 n69uap)[*]==> Device is in PWNDFU Mode: IKEYM8[*]==> Preparing DATA..... Will use: RAMDISK_1_iPhone8,4-n69uap-15.zip Downloading ramdisk, wait....error: Error making request with Error Code Forbidden and Http Status Code Forbidden. No further error information was returned by the service. Error processing ramdisk file, posible not supported!!!Process ramdisk fail, aborting |
04-16-2024, 20:38 | #10 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 417 | RAMDISK-BOOT OK OK BY umt ios Pad Pro(9.7-inch)(iPad6,3-j127ap) ios 16.7.7 [*]==> Reading Device Infos [ DFU Mode ] CPID : 0X8001 ECID : 0X000D58EE10042226 PWND: GASTER MODE: DFU PRODUCT : iPad6,3 MODEL : j127ap[*]==> Device : iPad Pro(9.7-inch)(iPad6,3-j127ap)[*]==> Device is in PWNDFU Mode: GASTER[*]==> Preparing DATA..... Will use: RAMDISK_6_iPad6,4-j128ap-16.zip Processing ramdisk, wait.... Ramdisk Name: iPad6,4-j128ap[*]==> Exploiting phone, wait...[*]==> If Phone does not enter recovery then Press Power Button one time now...[*]==> Sending iBss... Fail[*]==> Sending iBss... OK[*]==> Sending iBec... OK[*]==> Sending ramdisk... OK[*]==> Sending devicetree... OK[*]==> Sending trustcache... OK[*]==> Sending kernelcache... OK[*]==> Booting Device...SUCCESS ================================================== ===================[*]==> Device is Ready For [ Backup | Activate | Read Apple ID | Read WiFi/BT ]. ================================================== =================== Exe version: UMT iOS Ramdisk Activator V4.0 Log saved to: Logs\boot_ramdisk_0X8001_iPad Pro 9.7-inch (WiFi)_j127ap_0X000D58EE10042226_2024_04_17_02_35_ 39.txt ================================================== =================== [*]==> Opening SSH Tunnel Proxy...[*]==> [auto]Mounting FileSystem...[*]==> Creating Backup Folder...OK[*]==> Getting Activation DATA Stage #1... step1[*]==> Getting Activation DATA Stage #2...[*]==> Getting Activation DATA Stage #3...[*]==> Faild To Get Activation DATA at Stage #3 ![*]==> Fixing FairPlay DATA...[*]==> FairPlay FIX Done.[*]==> Now, Repeat The Backup Process Once Again. Exe version: UMT iOS Ramdisk Activator V4.0 Log saved to: Logs\get_activation_passcode_0X8001_iPad Pro 9.7-inch (WiFi)_j127ap_0X000D58EE10042226_2024_04_17_02_36_ 45.txt |
04-16-2024, 20:47 | #11 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,339 | Now, Repeat The Backup Process Once Again. So repeat couple of times if same then flash device and try again |
04-16-2024, 21:16 | #13 (permalink) |
Member: 1327392 Status: Offline Thanks Meter: 417 | https://i.imgur.com/lqW7LWb.png Please fix the driver stuck error in picture driver in picture ...... : cannot boot ramdisk ______ _______________________________ Fix driver : = boot ramdisk OK UMT ios : add automatically Fix driver after pwn Operation: Installing(fixing) iPhone drivers. Microsoft PnP Utility Driver package uninstalled. Driver package deleted successfully. Installing iphone driver. Microsoft PnP Utility Processing inf : usbaapl64.inf Successfully installed the driver. Driver package added successfully. Published name : oem61.inf Scan for hardware changes..... Microsoft PnP Utility Scanning for device hardware changes. Scan complete. Done ______________________________________ |
04-17-2024, 14:06 | #14 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,339 | New Update fix with version 4.1 FMI fix is out, Download here: https://drive.google.com/file/d/1vn0...usp=drive_link Pass: UmtTeam |
04-17-2024, 14:08 | #15 (permalink) | |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,339 | Quote:
so it s ok to click one button extra ? Operation: Pwning DFU using CHECKM8 exploit. Checking for connected phone, wait. Microsoft PnP Utility Driver package uninstalled. Driver package deleted successfully. Microsoft PnP Utility Driver package uninstalled. Driver package deleted successfully. [1]libusbK driver installed ok. Microsoft PnP Utility Scanning for device hardware changes. Scan complete. Executing CHECKM8 Exploit... Please wait, this may take few minutes, do not close or abort.... Device is now PWNED, Fix drivers and continue... this is how we do things, so we cannot do our work how you wish, if find or have other tool that does that pls use it. Last edited by Fast Unlocking; 04-17-2024 at 18:51. | |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
