Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 10-10-2020, 06:55   #1 (permalink)
Member: 1030568
Thanks Meter: 67
vivo v15 pro only recovery after flash
i just flash v15 pro with qcfire 6.1 after that only recovery mode show
Old 10-10-2020, 07:49   #2 (permalink)
Member: 2876711
Thanks Meter: 27
try to format without using safe mode
when ask to safe mode format, choose no
Sent from my SM-A505F using Tapatalk
Old 10-10-2020, 13:25   #3 (permalink)
Member: 1030568
Thanks Meter: 67
well try and post result
Old 10-10-2020, 13:32   #4 (permalink)
Member: 2876711
Thanks Meter: 27
k
Old 10-10-2020, 14:19   #5 (permalink)
Member: 1030568
Thanks Meter: 67
no luck here is log
Operation : Format FS
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM29)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.3
Connecting to phone...OK
Waiting for response...Ignored
Init Handshake Sequence...OK
Hardware ID : E1500900 [SM6150] 03007300
OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A53 9670EA259771BA
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [SM6150_001]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : SM6150, UFS, 128 GB
LU Count : 1 [0x01D83800]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 4096
Reading Partition Table...OK
Reading Device Information...Failed
Preparing Data...Done
Formatting Userdata...Done
Resetting FRP Lock.......Done
Operation Finished.
QcFire Ver. 6.2
Old 10-10-2020, 14:23   #6 (permalink)
Member: 2876711
Thanks Meter: 27
try with ota update
download from official site
Old 10-10-2020, 14:38   #7 (permalink)
Member: 1030568
Thanks Meter: 67
try with ota update
i try ota but show ota install from memory card only phone memory show but ota update in memory card
Old 10-10-2020, 16:22   #8 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,467
Contact me on Skype.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 10-11-2020, 11:57   #9 (permalink)
Member: 1030568
Thanks Meter: 67
Originally Posted by u.m.t View Post
contact me on skype.
Br,
umt
ok now i try on skype
Old 10-12-2020, 05:44   #10 (permalink)
Member: 1030568
Thanks Meter: 67
thanks team its done finaly love your support
Old 10-12-2020, 05:44   #11 (permalink)
Member: 1030568
Thanks Meter: 67
The Following User Says Thank You to sudheer1816 For This Useful Post:
Old 10-26-2020, 12:04   #12 (permalink)
Member: 2876711
Thanks Meter: 27
can you explain how you done it?
Old 10-26-2020, 14:52   #13 (permalink)
U.M.T's Avatar
Member: 2465108
Use Multi Program Mode for Flashing.
Br,
UMT
Old 10-26-2020, 22:55   #14 (permalink)
Member: 2556882
Thanks Meter: 24
What's multi program mode.
Is there any option in umt pls clarify it
How vivo v15 pro hai g on recovery was solved pls clarify it so that other user may solve this problem.
There is bug in qcfire 6.2 I also formatted vivo v9 youth afterformat hangs on logo.
Pls make qcfire problem free in next update sir.
Old 10-27-2020, 21:02   #15 (permalink)
U.M.T's Avatar
Member: 2465108
In Flash tab, you can find Radio Button, Single Program and Multi Program.
Br,
UMT
Page generated in 0.27031 seconds with 8 queries
