07-05-2022, 08:39 | #1 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1532909 Status: Offline Thanks Meter: 6 | Requesting UMT Server for Auth Data...Connection Error! Server status is online. Check credits working, but not working 2 lays ago and finaly: Requesting UMT Server for Auth Data...Connection Error! You write there at least in the server status page, when, what and how? What could we say the same to people who are waiting for their phones to be repaired. |
07-05-2022, 08:41 | #2 (permalink) |
Member: 1532909 Status: Offline Thanks Meter: 6 | Operation : Reset Mi Account (New) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM221) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6250]...Done Executing Loader...OK Auth Enabled Device! You may need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0NDY5Njc2NDM1MzEzNTUyNT QyRDMyNEI2RjMzNjc2QjM2Mzk3NzMyNjc0RDRCMzE1MjM1Njk2 Nz== Requesting UMT Server for Auth Data...Connection Error! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 8.0 FULL log |
The Following User Says Thank You to Typapbek For This Useful Post: |
07-05-2022, 10:59 | #3 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
b.r. | |
The Following User Says Thank You to bk.gsm For This Useful Post: |
07-06-2022, 09:36 | #5 (permalink) |
Member: 1532909 Status: Offline Thanks Meter: 6 | Nobody is answering. Please unsubscribe, is it possible to unlock Redmi note 9s model m2003j6a1g from our favorite programmer |
07-09-2022, 11:32 | #6 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Connection error can be due to AV blocking your connection or some other reason. From last 2 days, server is working stable. If you want, you can check now. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
07-10-2022, 11:35 | #7 (permalink) | |
Member: 1532909 Status: Offline Thanks Meter: 6 | Quote:
check is works fine: Checking for Available Credits....OK Available Credits : 10 I turned off the antivirus, just in case I installed VPN - activated it, the same problem: Operation : Reset Mi Account (New) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM221) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6250]...Done Executing Loader...OK Auth Enabled Device! You may need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0NDY5Njc2NDM1MzEzNTVBMz EzMjM4NzY0Rjc4MzY2MjU5MzgzNzQ1Mzc0MjYyNzA3OTQzNTQ0 MT== Requesting UMT Server for Auth Data...Connection Error! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 8.0 please help!!!! | |
07-26-2022, 11:45 | #10 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,706 | hi there don't show attitude here cuz we can show more attitude more than you.. we clarified that Reset Mi account operation will not work when you have new Xiaomi device with Find device ON..The server will not give auth data due to Xiaomi newest security I hope you could understand closed b.r. |
