10-09-2021, 13:58 | #1 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | reset frp asus zenfone max shot failure Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM34) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Invalid response from device! Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 66063606 OPK_DATA : 831CA445DED30DCA6A668654A732522C66C83B2C60237AF12B CF9EBB1596820C Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [8953_009]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.3 |
10-09-2021, 15:27 | #2 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,695 | hello.. try this attached loader and post results here b.r. |
The Following 2 Users Say Thank You to bk.gsm For This Useful Post: |
06-07-2022, 21:28 | #3 (permalink) |
Member: 2235684 Status: Offline Thanks Meter: 417 | Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM119) Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 66063606 OPK_DATA : 831CA445DED30DCA6A668654A732522C66C83B2C60237AF12B CF9EBB1596820C Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr.mbn]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : 8953, EMMC, 64 GB LU Count : 3 [0x0747C000] [0x00002000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : asus ASUS_A001D [ASUS_A001D_2] Brand : asus Prod.Name : WW_Phone Software : , 16.14.2005.298-20200417 [Fri Apr 17 18:15:18 CST 2020] Android Ver. : 9 Patch Level : 2020-05-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.9 done |
