03-14-2023, 04:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | samsung a035f frp faild Code: Phone Storage: EMMC SELECTED: SM-A035F ACTION: Erase FRP Loader format:NEW Start Detect phone. Testpoint image link for this model is located in utils tab Phone must be off with battery inside. Connect Testpoint while inserting usb cable. After booting, testpoint can be removed. Detected: SPRD U2S Diag (COM20) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. [2]Error write mod: 00000008 |
03-14-2023, 07:57 | #2 (permalink) |
Product Supporter Join Date: Sep 2015 Location: Moldova
Member: 2465199 Status: Offline Sonork: 100.1669899 Thanks Meter: 248 | You must follow exe hint. You must perform testpoint opperation to service this phone. Testpoint is located in utils tab. Phone battery must be charged. Code: Phone Storage: EMMC SELECTED: SM-A035F ACTION: Erase FRP Loader format:NEW Start Detect phone. Testpoint image link for this model is located in utils tab Phone must be off with battery inside. Connect Testpoint while inserting usb cable. After booting, testpoint can be removed. Detected: SPRD U2S Diag (COM6) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. Read partition info is supported by loader. UID: 00741948002b8e8a *************** [S]Manufacturer: samsung [S]Brand: samsung [S]Device: a03 [S]Model: SM-A035F Build ID: RP1A.200720.012 CPU arhitecture: arm64-v8a Build product name: a03 Build description: a03nnxx-user 11 RP1A.200720.012 A035FXXU1AVB1 release-keys Build Id: RP1A.200720.012 Android Release: 11 Android Version: RP1A.200720.012.A035FXXU1AVB1 Security patch: 2022-02-01 CPU NAME: UMS9230 Removing frp, wait... Found [persistent] [persistent] Size to download: 1024 KB [1]FRP: persistent Format OK. [can take 0-10 sec]Wait untill phone restart. Log saved: C:\sprd_backup\Saved_Logs\samsung_RP1A_200720_012_A035FXXU1AVB1_erase_frp_1.txt Total Time: 00:00:22 Done. If booting fail because of incorrect testpoint or other reasons after sending loaders, need to reinsert battery also. To allow phone to exist from flash mode. Last edited by U.M.T Manager; 03-14-2023 at 08:06. |
The Following User Says Thank You to U.M.T Manager For This Useful Post: |
03-15-2023, 05:07 | #3 (permalink) | |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
The Following User Says Thank You to kothamamun For This Useful Post: |
