10-23-2021, 03:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: World
Member: 792851 Status: Offline Thanks Meter: 136 | samsung a31 (A315f) after reset phone stuck on samsung logo i can not put phone in download mode, here is the log Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM11 [MediaTek USB Port (COM11)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&2c24ce2e&0&1#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0707, [MT6768] [Helio P65/G85 k68v1] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] Preparing device... -- Success! Preloader saved as : preloader_k68v1_64_titan_211023_124613.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM11) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Tue Feb 2 15:40:29 +07 2021 Build Flavor : a31nsdx-user Build Desc. : a31nsdx-user 10 QP1A.190711.020 A315GDXU1BUA1 release-keys Android Ver. : 10 Display ID : QP1A.190711.020.A315GDXU1BUA1 Patch Level : 2021-02-01 Userdata is ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! - Resetting FRP[2]... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.5] Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM11 [MediaTek USB Port (COM11)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&2c24ce2e&0&1#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0707, [MT6768] [Helio P65/G85 k68v1] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] Preparing device... -- Success! Preloader saved as : preloader_k68v1_64_titan_211023_124658.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM11) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Tue Feb 2 15:40:29 +07 2021 Build Flavor : a31nsdx-user Build Desc. : a31nsdx-user 10 QP1A.190711.020 A315GDXU1BUA1 release-keys Android Ver. : 10 Display ID : QP1A.190711.020.A315GDXU1BUA1 Patch Level : 2021-02-01 Userdata is ENCRYPTED Formatting Userdata... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.5] |
10-23-2021, 06:44 | #2 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Quote:
try with force restart bro..... | |
The Following User Says Thank You to Deni's For This Useful Post: |
10-26-2021, 22:33 | #9 (permalink) |
Member: 792851 Status: Offline Thanks Meter: 136 | bro problem is i can not put phone in recovery so how can i format? it can not even go to download mode when i got the phone it has same issue it had mdm lock i think can not factory reset can not go to download mode so i decie to do test point and did frp and format now stuck, i think i need a315f scatter file if i flash should be ok |
10-26-2021, 23:25 | #12 (permalink) | |
Member: 792851 Status: Offline Thanks Meter: 136 | Quote: Code: CPU : ELBRUS Storage : EMMC Scatter : C:\Users\Mps 10\Downloads\A315F U1 Dead Boot Repair Without Jtag\A315F U1 Dead Boot Repair Without Jtag\MT6752_Android_scatter.txt DA Version : MTK_AllInOne_DA_v3.3001.09/05/2021.11:40 Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM11 [MediaTek USB Port (COM11)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&2c24ce2e&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0707, [MT6768] [Helio P65/G85 k68v1] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] Preparing device... -- Success! Scatter file which is loaded has been phased out! | |
10-27-2021, 05:58 | #13 (permalink) | |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
10-27-2021, 18:12 | #14 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | This is due to updated flash engine, we will fix things soon. Br, |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
10-28-2021, 05:30 | #15 (permalink) | |
Hi thanks for reply with 4.4 I get this error now some time dont give this error but stuck here do nothing Code: CPU : MT6752 Storage : EMMC Scatter : C:\Users\MPs88\Desktop\A315F U1 Dead Boot Repair Without Jtag\A315F U1 Dead Boot Repair Without Jtag\MT6752_Android_scatter.txt DA Version : MTK_AllInOne_DA_v3.3001.01/21/2021.12:51 Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM6 Port Name: MediaTek USB Port (COM6) Path: \\?\usb#vid_0e8d&pid_0003#6&2c24ce2e&0&1#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0707, [MT6768] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k68v1_64_titan_211028_173247.bin | |
