12-07-2019, 22:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2017
Member: 2737570 Status: Offline Thanks Meter: 117 | Lenovo vibe2 pattern lock Any idea ur help will be highly appreciate it . Sent from my iPhone using Tapatalk |
The Following User Says Thank You to princemeedo For This Useful Post: |
12-08-2019, 00:59 | #2 (permalink) | |
Member: 2737570 Status: Offline Thanks Meter: 117 | Quote:
Operation : Disable Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.8.7 Opening Port...OK Invalid response from device! Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.8.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : C94306FF09FC94E60BC36DBEFB7F88648D7764E5313003FECA 69404ACB06A874 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...Failed USERDATA : Encrypted Disabling Android Locks...Failed If Locks are already disabled, please use Restore Locks option. Operation Failed. ------------------------------------------------------------------ Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.8.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : C94306FF09FC94E60BC36DBEFB7F88648D7764E5313003FECA 69404ACB06A874 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK USERDATA : Encrypted Reading USERDATA will cause large firmware size and slow read speed. Reading Device Information...Failed Reading [boot]...Done Reading [userdata]...Read Error! Saved to : C:\UMTool\QcFire\Read\8953\ Operation Finished. ------------------------------------------------------- Operation : Reset Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.8.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : C94306FF09FC94E60BC36DBEFB7F88648D7764E5313003FECA 69404ACB06A874 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr_lenovo.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...Failed USERDATA : Encrypted Encrypted USERDATA is NOT SUPPORTED Use [Disable Locks] function for Encrypted Userdata Operation Finished. -------------------------------------------------------------- Operation : Disable Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.8.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : C94306FF09FC94E60BC36DBEFB7F88648D7764E5313003FECA 69404ACB06A874 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr_lenovo.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...Failed USERDATA : Encrypted Disabling Android Locks...Failed If Locks are already disabled, please use Restore Locks option. Operation Failed. ------------------------------------------------------------------- | |
12-08-2019, 18:17 | #3 (permalink) | |
No answering till now what is this ?!!!!!! Sent from my iPhone using Tapatalk | |
12-09-2019, 07:24 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You read these lines but forgot to read yellow line below those white lines. |
The Following User Says Thank You to U.M.T For This Useful Post: |
