12-13-2021, 18:36 | #1 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | [SOLUTION] MTK Bypass Error, Stuck on Preparing Device... Preparing Device... then please follow these steps: 1. Go to Add Remove Program -- Uninstall libusb0, libuskDk and others like libusbK etc. -- Uninstall MTK Driver package -- Uninstall UltimateMtK Module 2. Reboot your PC. 3. Install UltiamteMTK setup. -- When setup prompts for libusb0 Driver Installation, click Next and continue until it is successfully installed. If libusb0 Driver Installer starts Filter Driver Wizard, you can simply close Installer Wizard and continue to UltimateMTK setup. 4. Once UltimateMTK setup is complete you should be able to use it without any issue. Br, UMT |
The Following 5 Users Say Thank You to U.M.T For This Useful Post: |
12-13-2021, 18:58 | #2 (permalink) |
Freak Poster Join Date: Nov 2021 Location: azerbaijan Age: 33
Member: 3001616 Status: Offline Sonork: NULL Thanks Meter: 30 | I did all of these but it didn't work. Those prior to version 4.6 are working. but 4.6 and 4.7 also have this problem. I tried it on another computer, same result. please help me. I haven't been able to work for a long time because of this problem. |
12-13-2021, 19:37 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | I have been trying this on 3 PCs, 1 was just installed Windows 10 to test this and it worked out of the box. Make sure you followed all steps correctly and there is nothing like magic which worked for 1 and not for another one. Br, UMT |
12-14-2021, 05:34 | #4 (permalink) |
Freak Poster Join Date: Jun 2011 Location: kolkata Age: 39
Member: 1596162 Status: Offline Sonork: 100.1616391 Thanks Meter: 146 | same problem..................... Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM3 [MediaTek USB Port_V1633 (COM3)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&226836f9&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: True] [DA Auth: True] MEID: 0EB746F141D73A1BDB013FEE182FAB24 Preparing device... |
12-14-2021, 05:49 | #5 (permalink) |
Insane Poster Join Date: May 2010
Member: 1294901 Status: Offline Thanks Meter: 12 | i too face same problem.. i tried all what need even tried 3 PC but samr error preparing device.. stuck.. while 4.3 working well in all PC .. team plz give soution..as fast as possible |
12-14-2021, 13:55 | #7 (permalink) |
Junior Member Join Date: Dec 2020 Location: karachi Age: 24
Member: 2976709 Status: Offline Thanks Meter: 1 | U.m.t mtk 4.7 Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM32 [MediaTek USB Port_V1632 (COM32)] Device Path: \\?\usb#vid_0e8d&pid_0003#5&3029f02f&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x6580, [MT6580] [Unknown] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: False] [SLA: False] [DA Auth: False] MEID: A1DF40CCF8FD552633D6C459130BC4C8 Preparing device... |
The Following User Says Thank You to 0malika0 For This Useful Post: |
12-14-2021, 14:39 | #9 (permalink) |
Member: 3001616 Status: Offline Sonork: NULL Thanks Meter: 30 | U.M.T. is it necessary to install windows 10 for this? I tried 2 windows 7, but it didn't work. I formatted and reinstalled but still the same problem. The device is being prepared. |
12-14-2021, 14:49 | #10 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
b.r. | |
12-14-2021, 16:59 | #13 (permalink) |
Member: 3001616 Status: Offline Sonork: NULL Thanks Meter: 30 | U.M.T answer give exact solution. Many people have the same problem. I formatted the computer but still the same problem. why is version 3.8 running? am 4.6 version 4.7 is not working. |
12-14-2021, 17:07 | #14 (permalink) | |
let me tell you there is no issue from our side and this is a prove of that: https://forum.gsmhosting.com/vbb/f97...l#post14492077 for your problem check the firs post...no other solution cuz this is a drivers issue... and check this user post too: https://forum.gsmhosting.com/vbb/f97.../#post14492041 he is using win 7 without any problem with our software.. so plz follow the steps from first post... b.r. Last edited by bk.gsm; 12-14-2021 at 17:38. | |
12-14-2021, 18:36 | #15 (permalink) |
Member: 3001616 Status: Offline Sonork: NULL Thanks Meter: 30 | b.r.[/QUOTE] What should I do after removing all mtk drivers from the computer? ultimate mtk will install its own mtk drivers? No need to install mtk driver? |
