08-03-2020, 08:16 | #136 (permalink) |
No Life Poster Join Date: Jul 2013 Location: ROGER/BELL/TELUS/NTT/AU KDDI Age: 38
Member: 1981870 Status: Offline Thanks Meter: 16,502 | MMX_Q402 Frp Remove Done With Great Umt King Code: Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Huawei SPD FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 1.0 Product Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:14 [Module Ver. 5.5] Log Saved to Logs\200730_161801.log |
The Following 2 Users Say Thank You to UnlockwithCode For This Useful Post: |
08-03-2020, 08:18 | #137 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Nokia 1 Android Ver 10 Frp Reset Done With Great Umt King Code: Brand : Nokia Model : Nokia 1 Operation : Read Info Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Android Ver. : 10 Display ID : 00WW_3_090 Patch Level : 2020-06-05 Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.1] Brand : Nokia Model : Nokia 1 Operation : Reset FRP Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Android Ver. : 10 Display ID : 00WW_3_090 Patch Level : 2020-06-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.1] |
08-03-2020, 08:19 | #138 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | ASUS_X00TD Pattern Lock/Frp Remove Done With Great Umt King Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : 2C58A12EBD1022BD5DBD5D937D1E2451092F62C202525FFCF06EB106DBF93155 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_019]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : asus ASUS_X00TD [ASUS_X00TD] Brand : asus Prod.Name : WW_X00TD Software : OPM1.WW_Phone-15.2016.1902.340-20190216, 15.2016.1902.340-20190216 [Sat Feb 16 11:49:40 CST 2019] Android Ver. : 8.1.0 Patch Level : 2019-02-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.7 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : 2C58A12EBD1022BD5DBD5D937D1E2451092F62C202525FFCF06EB106DBF93155 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_019]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : asus ASUS_X00TD [ASUS_X00TD] Brand : asus Prod.Name : WW_X00TD Software : OPM1.WW_Phone-15.2016.1902.340-20190216, 15.2016.1902.340-20190216 [Sat Feb 16 11:49:40 CST 2019] Android Ver. : 8.1.0 Patch Level : 2019-02-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 5.7 |
08-03-2020, 08:20 | #139 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Itel IT 1508 Frp Remove Done With Great Umt King Code: Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Huawei SPD FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 1.0 Product Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:18 [Module Ver. 5.5] Log Saved to Logs\200731_173840.log |
08-03-2020, 08:21 | #140 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | COMIO P1 Pattern Lock Remove Done With Great Umt King Code: Operation : Factory Reset (New) Checking for existing META ports... No existing META port found. Connect powered off phone... Found MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) on COM4 Device Path : \\?\usb#vid_0e8d&pid_2000#5&212ac8fc&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Rebooting to META mode... Waiting for phone in META mode... Found MediaTek USB VCOM (Android) (COM20) on COM20 Device Path : \\?\usb#vid_0e8d&pid_2007#_#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Configuring Communication Channel... Reading phone information... CPU : MT6735, E00 SW Ver. : MOLY.LR9.W1444.MD.LWTG.MP.V117.P23 HW Ver. : TOP6737M_65_A_N_HW Starting Factory Reset... Reset success Operation finished [UltimateMTK Ver. 3.1] |
08-05-2020, 10:14 | #141 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi Go [tiare] Dead Recover Done With Great Umt King Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 8 GB LU Count : 1 [0x00E90000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Go [tiare] Brand : Xiaomi Prod.Name : tiare_in Software : OPM1.171019.026.V10.2.11.0.OCLINXM, V10.2.11.0.OCLINXM [Wed Sep 4 16:46:18 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-09-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.8 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 8 GB LU Count : 1 [0x00E90000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Go [tiare] Brand : Xiaomi Prod.Name : tiare_in Software : OPM1.171019.026.V10.2.11.0.OCLINXM, V10.2.11.0.OCLINXM [Wed Sep 4 16:46:18 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-09-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.8 |
The Following User Says Thank You to UnlockwithCode For This Useful Post: |
08-05-2020, 10:32 | #142 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi 5 [msm8953] [rosy] Reset Mi Account/Reset FRP Done With Great Umt King Code: Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_009]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 [msm8953] [rosy] Brand : Xiaomi Prod.Name : rosy Software : CUSTOMER_VERSION_rosy, V11.0.2.0.ODAMIXM [Fri Jan 3 19:06:22 WIB 2020] Android Ver. : 8.1.0 Patch Level : 2019-12-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 5.8 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_009]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 [msm8953] [rosy] Brand : Xiaomi Prod.Name : rosy Software : CUSTOMER_VERSION_rosy, V11.0.2.0.ODAMIXM [Fri Jan 3 19:06:22 WIB 2020] Android Ver. : 8.1.0 Patch Level : 2019-12-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.8 |
08-12-2020, 07:25 | #143 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Honor 9i RNE-L22 Reset FRP Done with Great Umt King Code: Brand : Huawei Model : Honor 9i RNE-L22 Operation : Reset FRP Enabling ADB Mode...OK Waiting for device...Found! Model : RNE-L22 Version : 7.0 Build : RNE-L22-user 7.0 HONORRNE-L22 C675B160 release-keys Hardware : hi6250 Removing FRP Lock...Done Operation Finished. UltimateFRP Ver. 0.5 |
08-12-2020, 07:28 | #144 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | OPPO F3 (CPH1609) Pattern Lock/Frp Remove Done With Great Umt King Code: Brand : Oppo Model : F3 (CPH1609) Operation : Format FS Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM3) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connecting to HighSpeed Port... Waiting for HighSpeed Port.. Port : MediaTek DA USB VCOM (Android) (COM4) Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : OPPO Manufacturer : OPPO Model : CPH1609 Prod. Name : CPH1609 Device : CPH1609 Board : full_oppo6750_16391 Platform : mt6750 Android Ver. : 6.0 Display ID : CPH1609EX_11_A.31_190722 Patch Level : 2018-06-05 Userdata is NOT ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.1] Brand : Oppo Model : F3 (CPH1609) Operation : Reset FRP Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM3) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connecting to HighSpeed Port... Waiting for HighSpeed Port.. Port : MediaTek DA USB VCOM (Android) (COM4) Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : OPPO Manufacturer : OPPO Model : CPH1609 Prod. Name : CPH1609 Device : CPH1609 Board : full_oppo6750_16391 Platform : mt6750 Android Ver. : 6.0 Display ID : CPH1609EX_11_A.31_190722 Patch Level : 2018-06-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.1] |
08-12-2020, 07:30 | #145 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Micromax Q4204 Pattern Lock Remove Done With Great Umt King Code: Operation : Read Info CPU : MT6739 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM5) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Micromax Manufacturer : Micromax Model : Micromax Q4204 Prod. Name : Q4204 Device : Q4204 Android Ver. : 8.1.0 Display ID : MMX_Q4204_SW_V09_HW_V2.0_20180927 Patch Level : 2018-08-05 Userdata is ENCRYPTED Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.1] Operation : Format FS CPU : MT6739 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM5) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Micromax Manufacturer : Micromax Model : Micromax Q4204 Prod. Name : Q4204 Device : Q4204 Android Ver. : 8.1.0 Display ID : MMX_Q4204_SW_V09_HW_V2.0_20180927 Patch Level : 2018-08-05 Userdata is ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.1] |
08-13-2020, 06:46 | #146 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Lave P7 Invalid Imei Repair Done With Great Umt King Code: Operation : IMEI Reapir [META (Old)] Checking for existing META ports... No existing META port found. Connect powered off phone... Found MediaTek PreLoader USB VCOM (Android) (COM5) on COM5 Device Path : \\?\usb#vid_0e8d&pid_2000#5&212ac8fc&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Rebooting to META mode... Waiting for phone in META mode... Found MediaTek USB VCOM (Android) (COM29) on COM29 Device Path : \\?\usb#vid_0e8d&pid_2007#5&212ac8fc&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Reading Phone Information... CPU: SW Ver.: 0.00 Hw Ver.: Reading Data.... Repairing IMEI[1] to 9115xxxxxxxxxxx.... Repair success Repairing IMEI[2] to 9115xxxxxxxxxxx.... Repair success Operation Finished. [UltimateMTK Ver. 3.1] |
08-13-2020, 06:49 | #147 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Itel A41 Plus Pattern Lock/Frp Reset Done With Great Umt King Code: Connect power off phone, DO NOT PRESS any button... Device Found Path : \\?\USB#VID_1782&PID_4D00#5&212ac8fc&0&4#{4d36e978-e325-11ce-bfc1-08002be10318} Switching to Diag Mode... Done Wait for port to appear, then click [Scan] and select Port. Listing Available Ports... Done Port : COM6 : SCI USB2Serial (COM6) Baud Rate : 921600 Device : Spreadtrum Operation : Read Info Opening Port... OK Reading Phone Information... OK Platform Ver. : MOCORTM_15C_W16.39.3_P3.09_Debug Project Ver. : sharkl_cp1 Base Ver. : FM_BASE_15C_W16.39.3_P3.09 Hw. Ver. : sc9630_modem Build : u268_tsl_412-user 6.0 MRA58K eng.root.20170711.212118 release-keys Reading IMEI Information... IMEI[1] : 9115xxxxxxxxxxx IMEI[2] : 9115xxxxxxxxxxx Reading BT/WIFI Information... BT MAC : 741C278092D1 WIFI MAC : 741C27815621 Operation Finished. Elapsed Time: 00:04 [Module Ver. 5.5] Log Saved to Logs\200812_171849.log Port : COM6 : SCI USB2Serial (COM6) Baud Rate : 921600 Device : Spreadtrum Operation : Factory Reset Opening Port... OK Reading Phone Information... OK Platform Ver. : MOCORTM_15C_W16.39.3_P3.09_Debug Project Ver. : sharkl_cp1 Base Ver. : FM_BASE_15C_W16.39.3_P3.09 Hw. Ver. : sc9630_modem Build : u268_tsl_412-user 6.0 MRA58K eng.root.20170711.212118 release-keys Reading IMEI Information... IMEI[1] : 9115xxxxxxxxxxx IMEI[2] : 9115xxxxxxxxxxx Reading BT/WIFI Information... BT MAC : 741C278092D1 WIFI MAC : 741C27815621 Resetting Factory Settings... Done Operation Finished. Elapsed Time: 00:05 [Module Ver. 5.5] Log Saved to Logs\200812_171902.log Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Huawei SPD FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 1.0 Product Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:14 [Module Ver. 5.5] Log Saved to Logs\200812_172232.log |
08-17-2020, 09:49 | #148 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Xiaomi Redmi Note 6 Pro Reset Mi Account Reset FRP Done With Great Umt king Code: Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiNote7_64]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro [tulip] Brand : xiaomi Prod.Name : tulip Software : PKQ1.180904.001, V10.3.5.0.PEKMIXM [Fri Jun 28 19:22:47 WIB 2019] Android Ver. : 9 Patch Level : 2019-06-05 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 5.8 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro [tulip] Brand : xiaomi Prod.Name : tulip Software : PKQ1.180904.001, V10.3.5.0.PEKMIXM [Fri Jun 28 19:22:47 WIB 2019] Android Ver. : 9 Patch Level : 2019-06-05 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 5.8 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro [tulip] Brand : xiaomi Prod.Name : tulip Software : PKQ1.180904.001, V10.3.5.0.PEKMIXM [Fri Jun 28 19:22:47 WIB 2019] Android Ver. : 9 Patch Level : 2019-06-05 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 5.8 |
08-17-2020, 09:55 | #149 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | TECNO Spark 4 Lite Dead Recover Done With Great Umt King Code: Flash files count is :24 Action : Firmware update. Selected Model: Tecno: Spark 4 Exe version: Avengers Box MTK 0.7.1 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM5) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6761 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM4) Starting flash helio. [4] WRITE TO PARTITION [ md1img ] [5] WRITE TO PARTITION [ spmfw ] [6] WRITE TO PARTITION [ scp1 ] [7] WRITE TO PARTITION [ scp2 ] [8] WRITE TO PARTITION [ sspm_1 ] [9] WRITE TO PARTITION [ sspm_2 ] [13] WRITE TO PARTITION [ lk ] [14] WRITE TO PARTITION [ lk2 ] [15] WRITE TO PARTITION [ boot ] [16] WRITE TO PARTITION [ logo ] [17] WRITE TO PARTITION [ dtbo ] [18] WRITE TO PARTITION [ tee1 ] [19] WRITE TO PARTITION [ tee2 ] [20] WRITE TO PARTITION [ vendor ] [21] WRITE TO PARTITION [ system ] [22] WRITE TO PARTITION [ vbmeta ] [26] WRITE TO PARTITION [ cache ] [27] WRITE TO PARTITION [ recovery ] [28] WRITE TO PARTITION [ tkv ] [37] WRITE TO PARTITION [ userdata ] [helio]Wait untill phone will start charging. [0]All done. |
08-17-2020, 09:57 | #150 (permalink) |
Member: 1981870 Status: Offline Thanks Meter: 16,502 | TECNO Spark 4 Lite Reset FRP Done With Great Umt King Code: Exe version: Avengers Box MTK 0.7.1 Selected model: Tecno Spark 4 [auto]Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM5) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Sending loader..... BBCHIP MT6761 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Phone have OTP partition. Modem version: MOLY.LR12A.R3.MP.V75.5.P9 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Wait untill phone will start charging. [0]All done. |
