11-06-2019, 16:50 | #4 (permalink) |
No Life Poster Join Date: Mar 2019 Location: saturn
Member: 2901996 Status: Offline Thanks Meter: 917 | reply Oneplus 7 pro already done with UMT Gsm Module. so oneplus 7t/7t pro can also be done,just give it a try bro. Worlds 1st Oneplus 7-GM1901 IMEI Repair Done by Great UMT GSM V5.3 Diag port code: *#801# if this not work then use *#8011# and install driver manually. |
11-06-2019, 17:10 | #5 (permalink) |
Blocked Join Date: Jan 2004 Location: PAKISTAN Age: 52
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | 1st root https://forum.xda-developers.com/one...-twrp-t3979307 2nd enable diag adb shell su setprop sys.usb.config diag,serial_cdev,rmnet,adb 3rd Enjoy Already Teasted on One Plus 7T |
The Following 3 Users Say Thank You to xtreme For This Useful Post: |
11-18-2019, 08:41 | #7 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,447 | |
10-13-2020, 10:04 | #13 (permalink) |
Freak Poster Join Date: Feb 2004 Location: izmir Age: 48
Member: 53215 Status: Offline Thanks Meter: 17 | one plus 7t sm 855 not imei? oneplus 7t edl mode ? error ? Reading QCN Data...Done Saved As : C:\UMTool\QcFire\QCN_Backup\sm8150.g_----_3553xxxxxxxxxx_201013_115416.qcn Switching to EDL Mode...Failed Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port Driver Info : Quectel Incorporated, qcusbser.sys, 5.0.1.3 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500A00 [SD855] 85495100 OPK_DATA : 7A44FD44C35394DC10E1B910D525491DA862D0E420FE0BEF04 0FECF30032DA08 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SD855]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : BAAAABAAAAANAAAAAQAAAA== Using Alternate Method... DebugData : BAAAABAAAAANAAAAAQAAAA== Error getting Payload Information! Error Log : BAAAABAAAAANAAAAAQAAAA== Please use correct loader and check USB port / cable. Operation Failed. QcFire Ver. 5.3 |
10-13-2020, 14:36 | #14 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,447 | You can try directly using Code, to enable Diag, please check previous posts. Also, why you are using obsolete QcFire version? Br, UMT |
