12-21-2021, 12:28 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,333 | [21-12-21] UMTv2 / UMTPro UltimateMTK v4.8 - Oppo ID Remove, Huawei ID Remove & more UltimateMTK v4.8 Supported functions: - Read Info - Reset FRP (For devices supporting this feature) - Reset Locks (All Android Versions, Encrypted Userdata NOT Supported) - Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported) - Format FS - Format FS (Advance) - IMEI Repair in META / Boot Mode - Backup NVRAM - Restore NVRAM - Reboot to META / FACTORY / FASTBOOT Mode - Added Support for Helio CPU (MT6750, MT6755, MT6763, MT6739 etc) - Disable Lock / Restore Lock for Encrypted Userdata - Remove Lcoks for Encrypted Userdata for Vivo - Factory Reset in META Mode (Vivo, Oppo and others) - SafeFormat Option to let device format itself safely in recovery - Added Support for Helio X20 (MT6797) - Oppo/Realme Safe Factory Reset in META Mode - Added Disable Auth to disable SLA/DAA - Added Mi Account Reset - Xiaomi IMEI Repair - NVRAM/NVDATA Format - META Reboot for SLA Enabled Devices - MTK One Click Function Added - Crash Preloader Added - Added More Options in MTK One Click - Added Bootloader Unlock / Relock - Added RPMB Read/Write - Added Vivo Security Repair - Added Samsung Knox Guard (KG) Status Change - Added Oppo ID Remove - NEW!!! - Added Huawei ID Remove - NEW!!! MTK One Click - No need to select any model. - No need to select any DA/preloader. - Simply tick required options and execute. Supported SOCs for DAA/SLA Bypass: - MT6261 - MT6572 - MT6580 - MT6582 - MT6735 - MT6737 - MT6739 - MT6753 - MT6755 - MT6757 - MT6761 - MT6763 - MT6765 - MT6768 - MT6771 - MT6779 - MT6785 - MT6795 - MT6797 - MT6799 - MT6873 - MT8127 - MT8163 - MT8173 - MT8695 - MT6885 - MT6595 - MT8167 - MT6592 - MT6833 (Dimensity 700 5G) - MT6853 (Dimensity 720 5G) - MT8590 - MT6758 (Helio P30) - MT6781 (Helio G96) - MT6877 (Dimensity 900) - MT6893 (Dimensity 1200) Added Oppo ID Remove Added Huawei ID Remove - Do not use this function for Non-Huawei Devices Added Samsung New FRP Method - New Method added in FRP Reset in MTK One Click - Tested on Samsung Galaxy M32 5G Improved MTK One Click functions - Improved Format FS / Erase FS - Improved FRP Reset Function Fixed Hang on Preparing Device - This issue was caused by libusb driver installed on class level or for all devices. - Now device will be scanned properly avoiding hang Some cosmetic changes - Now Read RPMB, Write RPMB, Remove Oppo ID and Remove Huawei ID are combined in combobox. Thanks to: - nand kishor gup - raz007 MTK One Click supports most phones regardless of Brand and Model Important - Features introduced may work on other devices too, which are not litsed here. - User needs to untick By Model checkbox to be able to select Platform manually. - For manual work, just select Platform and DA. - For new secured devices, use Disable Auth, and select Preloader. - Rest operations will work same. Note : Some features are device/OS specific and may not work on all devices. WARNING : ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI. ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS. WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE. Download using Support Access or Mirrors Official Website |
The Following 52 Users Say Thank You to Fast Unlocking For This Useful Post: |
12-21-2021, 12:56 | #2 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2220699 Status: Offline Thanks Meter: 143 | Nice update. Plz team make disable Micloud into Brom method... make patch dual imei for Xiaomi phones. |
The Following 8 Users Say Thank You to jerrsoftware For This Useful Post: |
12-21-2021, 14:16 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | A10s reset FRP successful Thank you so much UMT TEAM.............. Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 Port Name: MediaTek PreLoader USB VCOM_V1633 (Android) (COM4) Path: \\?\usb#vid_0e8d&pid_2000#5&1f775297&1&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Preloader Mode Detected, Trying to crash... - Success! Port: COM3 [USB Serial Device (COM3)] Device Path: \\?\usb#vid_0e8d&pid_0003#5&1f775297&1&2#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] MEID: DB140F8CC134F8E14E58107E03C00E1B Preparing device... -- Success! Preloader saved as : preloader_s96116ra1_211221_171511.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : USB Serial Device (COM3) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Wed Sep 15 18:46:45 +07 2021 Build Flavor : a10sxx-user Build Desc. : a10sxx-user 11 RP1A.200720.012 A107FXXU8CUI2 release-keys Android Ver. : 11 Display ID : RP1A.200720.012.A107FXXU8CUI2 Patch Level : 2021-09-01 Platform : MT6765 Board : S96116RA1 Platform : mt6765 Userdata is NOT ENCRYPTED Seeking FRP Data... - Resetting FRP... - Success! - Resetting FRP... - Success! Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] No more preparing Device ...................... |
The Following 6 Users Say Thank You to killme12 For This Useful Post: |
12-21-2021, 14:53 | #5 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,729 | Honor 8A Frp done Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM7 [MediaTek USB Port_V1633 (COM7)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&3b2e6861&2&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] MEID: 21A98952638AE9DC2D52149FDD7BB1E3 Preparing device... -- Success! Preloader saved as : preloader_k62v1_64_mexico_211221_164321.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM7) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... -- Could not read! Userdata is ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] |
The Following 7 Users Say Thank You to bk.gsm For This Useful Post: |
12-21-2021, 18:15 | #7 (permalink) |
Freak Poster Join Date: Dec 2010 Location: cairo Age: 44
Member: 1468987 Status: Offline Thanks Meter: 163 | RMX2180.Realme C15 unlock pattern without lost data RMX2180.Realme C15 unlock pattern without lost data Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM3 [MediaTek USB Port_V1633 (COM3)] Device Path: \\?\usb#vid_0e8d&pid_0003#5&376aba2d&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] MEID: 1F6E9B0078979C867F2192C4EADC37AA Preparing device... -- Success! Preloader saved as : preloader_oppo6765_211221_173606.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM3) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Wed Jun 16 01:53:02 CST 2021 Build Flavor : full_oppo6765-user Build Desc. : full_oppo6765-user 10 QP1A.190711.020 bedd37e98646d3a1 release-keys Android Ver. : 10 Display ID : QP1A.190711.020 release-keys Patch Level : 2021-06-05 Userdata is NOT ENCRYPTED Formatting Userdata [SafeMode]... - Success! ---IMPORTANT--- Start phone directly in Recovery to complete operation. Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] |
The Following 3 Users Say Thank You to hamada yousri For This Useful Post: |
12-21-2021, 19:37 | #8 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | done moto c w7 pc Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM72 Port Name: MediaTek PreLoader USB VCOM (Android) (COM72) Path: \\?\usb#vid_0e8d&pid_2000#6&df2ee03&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Preloader Mode Detected, Trying to crash... - Success! Port: COM82 [MediaTek USB Port (COM82)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&df2ee03&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0335, [MT6737M] [Unknown] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] MEID: C7957EC0DDBC451544AE6B4F39367DF1 Preparing device... -- Success! Preloader saved as : preloader_a158_211221_163607.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM82) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connecting to HighSpeed Port... Waiting for HighSpeed Port.. Port : MediaTek DA USB VCOM (Android) (COM89) device path: \\?\usb#vid_0e8d&pid_2001#6&df2ee03&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Brand : motorola Manufacturer : motorola Model : Moto C Plus Prod. Name : panell_26_dt Device : panell_dt Board : MT6737 Build Date : Tue Mar 19 13:45:26 CST 2019 Build Flavor : full_A158-user Build Desc. : panell_26_dt-user 7.0 NRD90M.06.046 release-keys Platform : mt6737m Android Ver. : 7.0 Display ID : NRD90M.06 046 Patch Level : 2018-09-05 Data missing! Could not read extended information! Userdata is NOT ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] |
The Following 3 Users Say Thank You to bruno santana For This Useful Post: |
12-22-2021, 13:27 | #10 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Samsung A12 SM-A125F KG Status Done in 1clic Operation : Samsung Knox Guard Status Change Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM22 [MediaTek USB Port_V1632 (COM22)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&3999aca5&0&5#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] MEID: F4F7B3A9B3614CD2B27108A7910C274F Preparing device... -- Success! Preloader saved as : preloader_k65v1_64_bsp_titan_rat_211222_141221.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM22) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Mon Mar 15 11:00:46 KST 2021 Build Flavor : a12nsxx-user Build Desc. : a12nsxx-user 10 QP1A.190711.020 A125FXXU1AUC3 release-keys Android Ver. : 10 Display ID : QP1A.190711.020.A125FXXU1AUC3 Patch Level : 2021-02-01 Platform : MT6765 Board : k65v1_64_bsp_titan_rat Platform : mt6765 Userdata is ENCRYPTED Reading Backup... - Done Saved as: RPMB_Unknown_Unknown_mt6765_20212212_141258.bin Changing Knox Guard Status to Completed... - KG Status is already Completed, Aborted! - Successfully changed Knox Guard to Completed Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] |
The Following 5 Users Say Thank You to Arafat Mashaka For This Useful Post: |
12-22-2021, 14:54 | #11 (permalink) |
Member: 2235684 Status: Offline Thanks Meter: 417 | samsung a10s frp done Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM72 Port Name: MediaTek PreLoader USB VCOM (Android) (COM72) Path: \\?\usb#vid_0e8d&pid_2000#6&df2ee03&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Preloader Mode Detected, Trying to crash... - Success! Port: COM82 [MediaTek USB Port (COM82)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&df2ee03&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] MEID: 3128DCAA219BD39523C008D10EA6E208 Preparing device... -- Success! Preloader saved as : preloader_s96116ra1_211222_114527.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM82) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Fri Sep 10 08:15:12 KST 2021 Build Flavor : a10sub-user Build Desc. : a10sub-user 11 RP1A.200720.012 A107MUBU5CUI1 release-keys Android Ver. : 11 Display ID : RP1A.200720.012.A107MUBU5CUI1 Patch Level : 2021-09-01 Platform : MT6765 Board : S96116RA1 Platform : mt6765 Userdata is NOT ENCRYPTED Seeking FRP Data... - Resetting FRP... - Success! - Resetting FRP... - Success! Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] |
12-22-2021, 18:04 | #12 (permalink) |
Member: 2220699 Status: Offline Thanks Meter: 143 | redmi 9A Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 [MediaTek USB Port (COM4)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&3057e40a&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] [Helio P35/G35] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: True] [DA Auth: True] MEID: ABD7D8EF1E9B61F73F39D6872BB209AF Preparing device... -- Success! Preloader saved as : preloader_k62v1_64_bsp_211222_124610.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... -- Could not read! Userdata is ENCRYPTED Formatting Userdata... - Failed! Trying Erase Method... Verify Data Error - Success! Seeking FRP Data... Resetting FRP... - Failed! Seeking Mi Account Data... Resetting Mi Account... - Failed! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] unlock bootloader same error plz help team |
The Following User Says Thank You to jerrsoftware For This Useful Post: |
12-23-2021, 13:58 | #13 (permalink) |
Insane Poster Join Date: Jul 2015 Location: syria damascus
Member: 2424415 Status: Offline Thanks Meter: 21 | Is there a solution to bypass my account, after turning on the Wi-Fi, the account lock screen appears again redmi 9 prime Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 [MediaTek USB Port_V1633 (COM4)] Device Path: \\?\usb#vid_0e8d&pid_0003#5&25eb3f3f&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0707, [MT6768] [Helio P65/G85 k68v1] Hardware Info: 0x8A00, 0xCA00, 0x00 Config : [SecureBoot: True] [SLA: True] [DA Auth: True] MEID: E19DA297F2505B64206C340C16DCDBE5 Preparing device... -- Success! Preloader saved as : preloader_lancelot_211223_144020.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... -- Could not read! Userdata is NOT ENCRYPTED Formatting Userdata [SafeMode]... - Success! ---IMPORTANT--- Start phone directly in Recovery to complete operation. Seeking FRP Data... Resetting FRP... - Success! Seeking Mi Account Data... Resetting Mi Account... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] |
The Following User Says Thank You to gostarstar For This Useful Post: |
12-23-2021, 14:10 | #14 (permalink) |
Member: 2235684 Status: Offline Thanks Meter: 417 | a01 core frp done Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM94 [MediaTek USB Port (COM94)] Device Path: \\?\usb#vid_0e8d&pid_0003#6&13f4c3e&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0699, [MT6739/MT6731] [Unknown] Hardware Info: 0x8A00, 0xCB00, 0x02 Config : [SecureBoot: True] [SLA: False] [DA Auth: True] MEID: B5133735083FB93A19B1056A1A98D856 Preparing device... -- Success! Preloader saved as : preloader_k39tv1_bsp_1g_titan_211223_110905.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM94) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Wed Sep 1 07:42:32 KST 2021 Build Flavor : a01coreub-user Build Desc. : a01coreub-user 10 QP1A.190711.020 A013MUBU3AUI1 release-keys Android Ver. : 10 Display ID : QP1A.190711.020.A013MUBU3AUI1 Patch Level : 2021-09-01 Userdata is ENCRYPTED Seeking FRP Data... - Resetting FRP... - Success! - Resetting FRP... - Success! Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.8] |
12-27-2021, 20:11 | #15 (permalink) |
Member: 1468987 Status: Offline Thanks Meter: 163 | RMX2180.Realme C15 unlock pattern without lost data RMX2180.Realme C15 unlock pattern without lost data |
