01-21-2016, 07:58 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Delhi
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | cg220 please contact reliance customer care Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Jan 08 2013 20:20:18 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S00 Reading Extended Information... ESN : 80ED26DC MEID : A1000025A5ADAF IMEI : 867280013814553 BT Addr : 452125452545 BUILD : HC-CG220_HW2_R-S002B Lock Code : 0000 Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] unlock Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Unlock Opening Port... OK Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] flash Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Flash Opening Port... OK Reading Information... OK Compile : Jan 08 2013 20:20:18 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S00 Reading Extended Information... ESN : 80ED26DC MEID : A1000025A5ADAF IMEI : 867280013814553 BT Addr : 452125452545 BUILD : HC-CG220_HW2_R-S002B Lock Code : 0000 Setting Download Mode... OK Reconnecting Phone... OK Preparing Phone.. OK Sending Bootloader... OK Executing Bootloader... OK Syncing Phone... OK Initializing Flash Chip... OK Flash Chip : NUMONYX PF38F4060M0Y3DFA Chip Size : 32 MB Firmware : CG220_SP_Q1105-CG220_R-P2.02.62_S050_OMH_RELIANCE_130122_Lock.bin Fw. Size : 32 MB Writing Firmware... Write flash finished. nvm repair Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Repair NVM Port opened. Repairing NVM, please wait... Port closed Time Taken: 00:14 Module Ver. [1.4] meid or imei repair Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Repair MEID/IMEI/BT Port opened. Reading information... Reading Information... OK Compile : Dec 31 2012 18:09:10 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S05 Reading Extended Information... ESN : 00000000 MEID : 00000000000000 IMEI : 000000000000000 BT Addr : 000000000000 BUILD : HC-CG220_R-S050 Lock Code : 0000 Switching to Offline mode... Writing MEID... New MEID : A1000025A5ADAF Writing IMEI... New IMEI : 867280013814553 Resetting phone... Port closed. Operation finished. Time Taken: 00:02 Module Ver. [1.4] bluetooth repair Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Repair MEID/IMEI/BT Port opened. Reading information... Reading Information... OK Compile : Dec 31 2012 18:09:10 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S05 Reading Extended Information... ESN : 80ED26DC MEID : A1000025A5ADAF IMEI : 867280013814553 BT Addr : 000000000000 BUILD : HC-CG220_R-S050 Lock Code : 0000 Switching to Offline mode... Writing MEID... Failed! Read Only! Writing IMEI... Failed! Read Only! Writing BT Address... OK New BT Addr : 252522525252 Resetting phone... Port closed. Operation finished. Time Taken: 00:02 Module Ver. [1.4] again unlock Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Unlock Opening Port... OK Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] only efs part flash Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Flash Opening Port... OK Reading Information... OK Compile : Dec 31 2012 18:09:10 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S05 Reading Extended Information... ESN : 80ED26DC MEID : A1000025A5ADAF IMEI : 867280013814553 BT Addr : 252522525252 BUILD : HC-CG220_R-S050 Lock Code : 0000 Setting Download Mode... OK Reconnecting Phone... OK Preparing Phone.. OK Sending Bootloader... OK Executing Bootloader... OK Syncing Phone... OK Initializing Flash Chip... OK Flash Chip : NUMONYX PF38F4060M0Y3DFA Chip Size : 32 MB Firmware : CG220_SP_Q1105-CG220_R-P2.02.62_S050_OMH_RELIANCE_130122_Lock.bin Fw. Size : 32 MB Writing Only EFS Part... Write flash finished. repair again imei and meid Port : COM114 : HS-USB Wireless Diagnostics 3004 (COM114) Baud Rate : 921600 Device : Haier CG220 Operation : Repair MEID/IMEI/BT Port opened. Reading information... Reading Information... OK Compile : Dec 31 2012 18:09:10 Release : Oct 18 2011 00:00:00 Hw Ver. : CG220S05 Reading Extended Information... ESN : 00000000 MEID : 00000000000000 IMEI : 000000000000000 BT Addr : 000000000000 BUILD : HC-CG220_R-S050 Lock Code : 0000 Switching to Offline mode... Writing MEID... New MEID : A1000025A5ADAF Writing IMEI... New IMEI : 867280013814553 Writing BT Address... OK New BT Addr : 252522525252 Resetting phone... Port closed. Operation finished. Time Taken: 00:02 Module Ver. [1.4] all stap done and chk after all stap but same problem 'please contact reliance customer care' is umt can do resolve is problem team plz tell now what i do .. reg abhishek |
01-21-2016, 09:51 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Just for info, we dont support unlocking of CG220 at the moment. If Contact Cutomer Care message is appearing without RUIM, then EFS Write should solve it. If this message is coming with different RUIM inserted, then its normal. You can't unlock this model at the moment bcoz its not supported at the moment. Br, Ultimate Multi Tool |
